Old 05-20-2002, 08:54 PM   #1
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Default What would keep an engine from cranking?
Scenerio:
I put the key in the ignition, push in the clutch, turn the key to start, but there's nothing but a very loud clicking sound. The engine does not even turn over.
What do I need to check?
Impreza Rider is offline   Reply With Quote
Old 05-20-2002, 09:03 PM   #2
aigburth
Member#: 8619
1996 RHD GC '96
http://spookyempire.com
This is very basic but if you don't even have a click,is your battery connected?sounds silly,do your dash light's come on,if so check the ignition wire on the starter,do you have power?
let me know,
Alan
p.s. check all fuses.
aigburth is offline   Reply With Quote
Old 05-20-2002, 09:26 PM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yeah, I have power...it does click...about 10-15 times a sec when the key is in the start position.
Old 05-20-2002, 09:38 PM   #4
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Is your starter spinning? (Have a friend crank the engine and listen for a whir -)
It could be a number of things, the first of which I'd check is whether or not your starter has any gears left on it. If it does, it's possible that it is only partially engaging the flywheel. It's pretty easy to get out of the engine (on a stock EJ25).
You can test cranking it with any 12V supply. If it's not spinning, replace it. If it's not extending so that it would engage the flywheel, tear it appart and grease it with white lithium grease.
Now, if it's not spinning you could have a short (and that ticking would coincide with some sparks flying under your hood). Make sure you're getting all the normal sounds and lights you expect when you turn the key into the ignition on position (radio etc). If that all checks out, check the wiring in and around your starter. Make sure all the insulation is there and that there are no burn marks etc.
If none of this helps, pop back on here and I'm sure some people could offer up some other ideas.
Really_Soaked is offline   Reply With Quote
Old 05-20-2002, 09:49 PM   #5
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Have you had you're motor apart recently? Check cam, and crank sensors. also check you're ignitor make sure they are all plugged in.
Old 05-20-2002, 10:08 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I just thought of something...how many volts does the engine need to crank? My car has been sitting for awhile, and I've been doing some electrical stuff to it, so I've had the lights on, etc.
My volt gauge reads about 10.5 before I try to crank it...could this be my problem?
Old 05-20-2002, 10:16 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
It should be no lower than 12.0 and 8.5 under load. But it should still start though. I have had em as low as 9.0 start the car. Still though that is a good place to start. Try jumping it or charging you're battery.
Old 05-20-2002, 10:21 PM   #8
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Well I feel like a jackass...car started right up when the battery had power
Nothing to see here, move along
Thanks for the help anyway...I'll remember that when I have a problem the next time.
Old 05-20-2002, 10:25 PM   #9
Hondaslayer
Member#: 4562
1995 Legacy LSi
Kool just dont belete the thread I have too many posts in it
Old 05-20-2002, 11:10 PM   #10
Legacy GTR
Member#: 9316
1997 Legacy GT
[email protected]
hahaha, glad you got it fixed
Mike
Legacy GTR is offline   Reply With Quote
What would be an upgrade from Teins for a spirited DD? EdHilario Brakes, Steering & Suspension 11 11-03-2008 09:34 AM
What would cause an engine to sieze? tverdek Subaru Conversions 19 12-30-2007 07:54 PM
aside form a bent shift fork, what could keep 3rd gear from engaging all the way? Matt K New England Impreza Club Forum -- NESIC 5 08-23-2005 12:28 PM
How do I keep the engine from corroding? Undepelo Interior & Exterior Modification 7 05-02-2003 02:46 AM
If u had an engine from an 850i, what would you put it in? dcoty Off-Topic 50 04-03-2003 08:19 PM
