Old 12-22-2009, 06:32 PM   #1
frankensubie
Member#: 220236
97 impreza obs
green
Default has anyone done? or know if....
there are any issues with installing 2.5l phase 2 dohc cylinder heads onto a 2.5l phase 2 shortblock?
I am working on a set of phase 1 heads...doing a mild port and polish and will be installing some delta cams ( unless someone has a good affordable alternative ) i have a perfectly serviceable phase 2 shortblock that i will rebuild if the heads will work...i already know the head gaskets line up perfectly...i am more concerned with piston clearances in the combustion chambers of the phase 1 heads...
i have pretty realistic expectations in terms of power and performance IF the combo will work
doing the work is no issue as i have more than my fare share of experience working on subies ( see my location on my profile )
the reason i'm asking is that I'm not as up to speed on the inner workings of some of the earlier N/A engines ...when i worked as a tech for subaru almost all I worked on was phase 2 engines and turbo models...my experience on the finer points of the turbo motors mod wise has been working @ EPIC motorsports with robbie
frankensubie is offline   Reply With Quote
Old 12-22-2009, 08:42 PM   #2
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
you would have better luck in the built motor discussion which is right below N/A w/ forced induction.
legacydreamz is offline   Reply With Quote
Old 01-03-2010, 11:30 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Phase II DOHC heads? Like, from a WRX?
As far as I know, and have built..... EJ25D heads (phase I) work well, make that really well, on the phase II bottom end.
Jay Storm
Old 01-04-2010, 08:47 AM   #4
rsdog
Member#: 215687
2002 STI
Jay Storm
Plus one on this comment
Was my next upgrade when I turbo charged the 2.5 RS I had.
rsdog is offline   Reply With Quote
has anyone done? or know if frankensubie Normally Aspirated Powertrain 6 12-23-2009 11:25 AM
has anyone heard or know where to find ctskydive Off-Topic 0 01-31-2006 07:17 AM
Has anyone tried or know if a 255/35-18 will fit an 18x8 on a WRX? disque71 Tire & Wheel 1 06-15-2005 11:39 AM
Has anyone used / have the TurboPac 1500 or know if it's even available BrysImpreza Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-20-2002 03:10 PM
Has anyone purchased or know about hesitation mod. v6scoobie Technical Forum Archive 13 08-20-2000 04:12 AM
