Old 05-20-2002, 09:41 PM   #1
6Pack
Member#: 13901
2002 WRX Sedan
Default Failed stealth defi HUD install
Not liking the way the Defi heads up display (HUD) sat on my dash like a sore thumb, I wanted it hidden. So I came up with this idea. I recess mounted the display unit underneath the gauge pod (I used silicon sealant). However it does not work as expected. The angle the unit is mounted causes slight dimming. Plus it's too far away from the windshield which also causes more dimming. The display is impossible to see during bright day light and dusk. So thought I'd at least share my idea to those who may have considered the same thing.
(pic taken through windshield, so that's what those specs are).
6Pack is offline   Reply With Quote
Old 05-20-2002, 09:43 PM   #2
6Pack
Member#: 13901
2002 WRX Sedan
A close up. Looks really nice and hidden, pretty impressed with my dremel work too. Too bad I lost functionality.
Old 05-20-2002, 10:00 PM   #3
Precentor
Member#: 14794
2002 Subaru WRX
WR Blue
try bringing it out a bit, so that its more surface mounted on the pod. It'll still look like part of the pod, and be slightly hidden behind it.
Also, try using the a tint square on that area.
Precentor is offline   Reply With Quote
Old 05-20-2002, 10:16 PM   #4
sherifx
Member#: 10780
---- BRZ
Galaxy Blue Silica
I can't remember if there is a "ridge" between the upper and lower casing. If so you could possibly dremel the hole a bit larger and have it sit slightly elevated on that "ridge." This would bring it slightly closer improving fuctionality. If not, then I guess yer SOL buddy j/k. Nice work... maybe the tint film would help... who knows
sherif
sherifx is offline   Reply With Quote
Old 05-20-2002, 10:22 PM   #5
6Pack
Member#: 13901
2002 WRX Sedan
Tried all that. It pretty much functions best 'as is' on the dash. Maybe if I put it in the actual dash itself closer to the window, but that'll be a hella lot harder to do.
Defi VSD Concept HUD install help silmarilion Electrical & Lighting 3 05-05-2010 12:22 PM
pics of Defi HUD? bleuquila Interior & Exterior Modification 24 11-27-2004 04:59 AM
WTB Locally: WRX manifold & door handle ring & defi HUD stand 6Pack New England Impreza Club Forum -- NESIC 0 12-10-2002 04:58 PM
defi hud boost owners help! 6Pack Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-10-2002 09:05 AM
Should I return my Defi HUD? Sooberman Car Audio, Video & Security 4 08-08-2001 03:59 PM
