Old 05-20-2002, 09:57 PM   #1
go go go
Member#: 2784
Default How can you tell JDM or US motor?
I have a JDM EJ205 motor waiting to be swapped on my car.
I was looking around the engine and came up with a question,
How can DMV/police/smog station/etc. can tell if this is a JDM motor? it could be USDM WRX motor. Same EJ205.
I think I can just say this is from USDM WRX and register my car legally in California, if it passes smog.
any thoughts?
go go go is offline   Reply With Quote
Old 05-20-2002, 10:00 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
I would assume that they could detect the higher octane level? correct me if I'm wrong I live in MI land of no testing. Join Us Today!!!
Old 05-20-2002, 10:01 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I don't recognize that engine code.... Are you sure it's a EJ205?
kastle is offline   Reply With Quote
Old 05-20-2002, 10:07 PM   #4
go go go
Member#: 2784
yes EJ205, well it is EJ20 and the sub code is 5
same as US WRX motor.
The block only says EJ20 but the VIN plate says EJ205
There are EJ20G/EJ20K/EJ205/and STi's EJ207 used in Impreza.
Old 05-20-2002, 10:08 PM   #5
Gerry
Member#: 1829
It's a STI engine..It's out of a F,Gtype STi,R/RA-STi ..
Now for the question.. As far as I know.. You will have to use a USDM ecu. When cali plugs into the ecu they should get the OBD2 info from the ecu. I'm not really sure if your EJ205 has those flapper valves on the intake manifold.If you hook the engine up to the ecu without the flapper valves connected I don't know if it will throw a code or not.."probally will though" As for a visual inspection..They would have no idea that it's a JDM engine...Gerry
Gerry is offline   Reply With Quote
Old 05-20-2002, 10:21 PM   #6
go go go
Member#: 2784
yeah visually they can't tell, I think. They haven't seen JDM motor probably.
If they find a difference, I think it'll be codes from OBD2, just like Gerry says...
But I wonder if they nit-pick on codes... if it is within legal emission spec, I think it's fine.
hmmm.....
Old 05-20-2002, 10:26 PM   #7
go go go
Member#: 2784
I'm gonna use JDM ECU. It should be OBD2 from ver5.
There is a guy in factory forced forum plugged JDM GDB ECU on US WRX and it works he says so I assume there is a compatibility between JDM and US ECU after OBD2 standards.
Old 05-20-2002, 10:38 PM   #8
Gerry
Member#: 1829
OK..If you use a JDM OBD2 comp the info that the US inspector reads off the ecu might not work.. Meaning that it would probally say that it is a JDM ecu.Also it won't say that it's smog legal..Gerry
Old 05-20-2002, 10:46 PM   #9
go go go
Member#: 2784
I see,
not that simple, huh?
Old 05-20-2002, 11:00 PM   #10
Gerry
Member#: 1829
nah...You could see if you could swap the ROM's ...I'm not sure but it might work..Also you will need someone with soldering skills since the new ecu's are not removeable chips..Gerry
Old 05-20-2002, 11:11 PM   #11
christoph1371
Member#: 1090
either they can run the VIN (very slim) or they can tell by OBDII.
DO you have a VIN for a USDM? That might be useful, cough cough.
christoph1371 is offline   Reply With Quote
Old 05-21-2002, 02:41 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you will definitely need to have a USDM ECU...most of the programming languauge in japan is the same but just remember Japan had Catalyst effiency monitors on cars in the early 90's...who knows what they have that we don't.
jeremy
Old 05-23-2002, 07:36 PM   #13
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
You only have to worry about this if you're in California, correct?
garface is offline   Reply With Quote
Old 05-25-2002, 12:02 AM   #14
Greg Sharpe
Member#: 741
04 EVO SSL
Asphalt Black
Right, cali is annoying like this. Two places had a hard time smogging my L-coupe a while back in Cali because they didn't have some sort of reference material for which to check the engine against. They kept asking me what engine code it was and where it came from ... silly really, it was stock, 1.8L, 50-state car.
Greg Sharpe is offline   Reply With Quote
bride brix2 real or fake? how can you tell? rjrutzky Interior & Exterior Modification 8 09-20-2007 04:25 PM
how can you tell whether strut or spring is broken? projectrally Brakes, Steering & Suspension 7 11-20-2004 06:58 PM
How can you tell if you have phase I or phase II block ? zaidallas Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-26-2002 06:04 PM
how can you tell if you have a blown strut? FatCatTurbo Brakes, Steering & Suspension 4 01-24-2002 04:54 PM
How can you tell how the engine is running? DDMan Normally Aspirated Powertrain 10 01-06-2002 04:06 AM
