Old 05-20-2002, 11:17 PM   #1
StewPiddass
Member#: 18867
Default Wheel/Tire sizes for WRX Wagon
I know that a 225 45 17 on a 7.5 inch rim will go on a WRX sedan but will it fit OK on the wagon with the narrower fenders?
If not, which size / offset will fit best? especially if the car will be lowered (just a bit)
StewPiddass is offline   Reply With Quote
Old 05-20-2002, 11:33 PM   #2
Z1 Performance
Member#: 9327
17x7, at least 48 offset, 215/45 tires.
Please do searches guys.....
Z1 Performance is offline   Reply With Quote
Old 05-20-2002, 11:57 PM   #3
ToddStratton
Member#: 8351
2002 WRX Wagon
Also, 225/45 17 should be fine. I run it (55mm offset on 17x7 UK rims) on the stock suspension every day and have tried it on the SPT/STi setup--no problems.
May have problems with lowered suspension.
TRS
ToddStratton is offline   Reply With Quote
Old 05-21-2002, 01:36 AM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
17x7.5 Rota Subzeros with 215/45R17 Kumho 712s fit fine for me on stock 02 TS suspension.
AllWheelDrift is offline   Reply With Quote
Old 05-21-2002, 09:27 AM   #5
melfammy
Member#: 15530
2002 WRX Wagon
Midnight Black
I have 225/45/17 azenis on 17.5 with 48 offset on my wagon. Stock suspension no problem. Lowered you will rub
melfammy is offline   Reply With Quote
Old 05-21-2002, 05:46 PM   #6
sport
Member#: 11376
2002 WRX Sport Wagon
Default 225s
My WRX Wagon came with 17" Konig Imagines which are 40mm offset if I remember correctly and 225x45x17 tires.
They have aways rubbed slightly in the rear with someone in the back seat..
I was at the tire shop just this morning where they were purchased and they are exchanging the tires for 215s for me.
S.
sport is offline   Reply With Quote
Old 05-21-2002, 06:27 PM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
There are a lot of factors to take into account.
1.) Wheel Offset. The lower the offset, the more chance you'll rub the fenders.
2.) Suspension. If you have the car lowered, obviously there's going to be less room to play with. Also, be careful about rubbing on the coilovers if you run them with high offset wheels.
3.) Tires. I have 225/45/17 Falken Azenis on Rota Subzeros (17x7.5 +48mm), and they rubbed in the rear with Tein Wagon suspension, and the car lowered ~1.75 inches. Had to get the fenders rolled to stop the rubbing. I also just got a set of 225/40/18 Yokohama Parada Spec-2 tires on 5Zigen Fighters (18x7.5 +50mm) and they are noticably thinner than the Falkens. I'd say the Azenis are about .5" wider than the Yoko's, even though they're both a 225 width tire.
Tallest tire size for '07 Wagon lord8track Tire & Wheel 0 10-16-2007 09:36 PM
Correct Wheel/Tire Size for 99 Impreza jersey315 Tire & Wheel 10 02-13-2007 04:27 AM
Suggestions on wheel/tire size for dry weather/track fenix327 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-30-2004 07:57 PM
Tire Size for WRX Wagon Family Truckster Brakes, Steering & Suspension 15 12-31-2002 11:21 AM
Largest wheel/tire combo for WRX wagon on stock suspension? well_armed Brakes, Steering & Suspension 3 08-02-2002 09:29 PM
