Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 12-23-2009, 07:56 PM   #1
DrumNWReX
Member#: 99119
2006 WRX Cobb Stg. 2
OBP Clark Turner tuned!
Default Epic engineering springs and sway bar combo
Has anyone seen this? It seems like a good deal to me, but are both sways necessary? This is supposed to replace the rear and can be used with stock endlinks (not sure how much I'd actually want to use those after replacing). I am just curious what the consensus on these are, if it's a good deal, if they are decent springs, if the sway bar is better than most out there, and if keeping stock endlinks is a good idea.
DrumNWReX is offline   Reply With Quote
Old 12-23-2009, 08:26 PM   #2
davis10
Member#: 70011
Just keep the stock endlinks till you break them then buy new ones, unless you have the cash then just buy solid Al ones because the plastic ones do flex quite a bit. Just depend if you worried about cost or if you want the best performance
Snapping a endlink is not too big of a deal but it would suck if you were at a event with no spares and had to run effectively no sway bar for the rest of the day.
davis10 is offline   Reply With Quote
Old 12-23-2009, 08:35 PM   #3
DrumNWReX
Member#: 99119
Sorry, forgot to mention this would be for a DD. I do want better performance, but it's not like I'm going to autoX or anything like that, just want better handling, more neutral, etc...
Epic's springs are based on now-defunct prodrive's, right?
Old 12-23-2009, 10:17 PM   #4
davis10
Member#: 70011
Not sure About the springs, but I wouldn't worry about the endlinks too much you will notice a big improvement from a DD standpoint from just the springs and swaybars.
FS: Epic Engineering 22mm rear sway bar WRX 02-07 NEW wrxtasy555 Suspension/Brakes/Handling 6 04-09-2009 03:28 PM
March Madness! EPIC Springs and Sway Bar Combos! Stance Coilovers! StopTech Brakes! WorldOne Suspension/Brakes/Handling 28 03-31-2009 03:13 PM
FS: Epic Engineering 22mm rear sway bar WRX 02-07 EPME Suspension/Brakes/Handling 16 03-24-2009 05:46 PM
Epic Engineering springs and Cusco suspension sale! WorldOne Suspension/Brakes/Handling 35 02-25-2009 01:13 PM
2002 OEM WRX Springs and Sway Bars (Front and Rear) Uber-Cheap!!!! jmeltzer4 Private 'For Sale' Classifieds 10 08-22-2005 12:02 PM
