Old 12-23-2009, 08:03 PM   #1
__TT__
Member#: 136256
Default flexplate bolts
how many are in there. its a 94 t leg with a 4eat
__TT__ is offline   Reply With Quote
Old 12-24-2009, 11:58 AM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
8 holding it to the crank. If the trans is out of the car, look at the converter...I think there's only 4 holding it to the flexplate, but it might be 6. Been awhile since I pulled a 4EAT.
Jay
Old 12-24-2009, 02:51 PM   #3
BruceD_500
Member#: 233041
I found 4 bolts attaching the flex-plate to torque converter on my 2000 Outback two nights ago. Gave the first bolt a shot of white spray paint and started taking them out until I got back to the paint.
I don't think it relay matters but now I can line it up the same way for reassembly.
BruceD_500 is offline   Reply With Quote
Old 10-09-2012, 10:40 AM   #4
Captain Haddock
Member#: 289018
Does it make it easier to separate the engine and auto trans if you remove the bolts holding the torque converter to the flex plate?
Captain Haddock is offline   Reply With Quote
Old 10-09-2012, 12:15 PM   #5
dragoontwo
Member#: 275500
1992 SVX
I believe that is the way it's supposed to be done.
dragoontwo is offline   Reply With Quote
Old 10-09-2012, 03:42 PM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
No it does not, but you do NOT want to pull the TQ off the trans if you dont have too...
I did and its a deep hole to dig (requiring special tools that arent easily found)
WTB: Flexplate for auto Impreza kcpaz Private 'Wanted' Classifieds 1 03-29-2010 07:00 PM
HELP! Flexplate to Flywheel Torque specs!!! spyders03 Factory 2.0L Turbo Powertrain 3 09-19-2009 11:17 AM
Rounded a flexplate bolt on 4EAT mc2 Normally Aspirated Powertrain 1 04-05-2009 01:34 PM
WTB: 95-97 4eat flexplate and flywheel NicFunkadelic Private 'Wanted' Classifieds 1 05-13-2008 08:52 PM
Flexplate Legacy2 Legacy Forum 5 12-14-2004 04:43 PM
Message Board Statistics All times are GMT -4. The time now is 11:51 AM.
