Old 12-23-2009, 10:20 PM   #1
Maxwell Power
Member#: 190729
Default Maxwell Power Dyno Tune: 2.5L Hybrid + GT35R = 588whp
Event: dyno tune
Ambient Temp: 46
Elevation: 200ft
Weather: Freakin' Cold
Car: 2002 WRX
Owner: Wesley D.
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 588whp uncorrected, 562whp SAE corrected @ 6550
Peak Torque at RPM: 503 ftlbs uncorrected, 480.9 SAE Corrected @ 6000rpm
Baseline hp/tq for a stock on same dyno: 165-170whp
Target Boost: 27psi
Target AFR: 12
Fuel: Sunoco 110oct (leaded)
Method: Factory ecu equipped with Speed Density.
Engine/Power Modifications:
*Custom built 2.5L shortblock: JE Pistons, MPS Rods, OEM crank etc
*Mild hand porting on S20 heads (EJ20), Kelford 272 Cams, Enlarged Combustion chambers, Supertech valve springs, factory valves.
*GT35R w/ 1.06 turbine housing in custom rotated setup and the factory header.
*TurboXS FMIC w/ blow thru MAF housing
*ID 1000cc injectors, Perrin Fuel Rails, Walbro
*AEM 3.5bar MAP Sensor
Driveline Modifications:
*05 STi 6 speed and R180 swap w/ brembos/hubs etc
*Exedy Twin Plate Clutch
Suspension Modifications:
*05 STi stock components.
Just wanted to share what Wes's car did on the speed density ROM. The car screams when the turbo finally kicks in.
thanks for looking,
Dominic Acia
Arlington, WA
360-474-8225
Maxwell Power is offline   Reply With Quote
Old 12-23-2009, 10:29 PM   #2
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Nice work DOM! I am saving for your motor
medamullet is offline   Reply With Quote
Old 12-23-2009, 10:37 PM   #3
4eatFp68
Member#: 216913
2002 WRX AUTO
Wow, can you say company loaner car! MPS FTW, keep up the goodwork guys!
4eatFp68 is offline   Reply With Quote
Old 12-23-2009, 10:42 PM   #4
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
what ems did you guys use? i see it says Factory ecu equipped with Speed Density? piggyback?
ownnij is offline   Reply With Quote
Old 12-23-2009, 10:51 PM   #5
Maxwell Power
Member#: 190729
awesome, I look forward to blueprinting it.
LOL, no the loaner is a 98 L with 306k miles! It's about to be stripped and converted into a car like Craig's RS.
Factory 02 WRX ECU with a Speed Density enabled rom. No piggy backs. The rom has LC and a soft AntiLag setup, but it's a BLAST to drive. No MAF headaches.
Old 12-23-2009, 10:59 PM   #6
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
power drops a lot after 6.5K, I was expecting to hold a lot more power up top, with the nice heads and cams + the 1.06 AR. Is down like 30whp by 7K and 60whp by 7.5K
Is that normal?
Old 12-23-2009, 11:14 PM   #7
Maxwell Power
Member#: 190729
Is that normal?
factory valves and only a little bit of blending by hand. Heads really choke out around 550whp regardless of cams. You got to have a little more work done to them to get the flow up top.
I probably could have added a degree or two of timing up top to help, but it was getting late.
Old 12-23-2009, 11:18 PM   #8
Maxwell Power
Member#: 190729
Also, it's my opinion that the 1.06 is just too big for this setup. The IC piping is pretty rough, the heads and valves like I said before don't flow enough, and it still has the factory header.
Old 12-23-2009, 11:47 PM   #9
ownnij
Member#: 70459
man this is pretty awesome... i'm going to have to see if my tuner could do something like this for me. i was wondering how you guys were using a map sensor.
Old 12-24-2009, 01:00 AM   #10
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Very nice! So this was 27psi, what does this dyno compare to numbers wise on a chart of 1-10, 1 is a mustang dyno and 10 is dynojet? Also has anything been modified oil wise for 8000rpm? SICK work !
TDagen is offline   Reply With Quote
Old 12-24-2009, 01:17 AM   #11
silversubiedude
Member#: 182010
2002 slow wrx
psm
Um I believe its some where in the middle Dom will have more info on that.
Nothing was modified on the oiling system. They can hold 8k if they are built right BLUE PRINTED and balanced.
Huge thanks to Craig for showing me how to blue print the engine and Dom for the countless hours and hundred's of reflash's we have done over the last year. Seriously the two guys to have build and tune your car hands down!
Thanks guys!
Heres a video from one of the first pulls. Gotta love antileg.
silversubiedude is offline   Reply With Quote
Old 12-24-2009, 01:23 AM   #12
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Nice! That sounds like a beast (Not talking about the AL either)...
Old 12-24-2009, 07:47 AM   #13
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Nice peak power but for something to play with on the street I'd take that 30R car you also posted
Steve.804 is offline   Reply With Quote
Old 12-24-2009, 08:11 AM   #14
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
588whp on 1 walbro?
wrxwhat is offline   Reply With Quote
Old 12-24-2009, 01:48 PM   #15
Maxwell Power
Member#: 190729
proper clearances go a long way. Combine that with a polished oil pump and you're good to go for most cars.
I hear that. However, Wes is looking for drag racing performance. That's why we're trying to find him a nice cheap, used header to throw on it. More top end power should come out of that.
Originally Posted by wrxwhat View Post
588whp on 1 walbro?
Couldn't go any higher on the boost because we tapped out the fuel pump. Also, remember this is on race gas which is less of a load on the pump due to leaner AFRs. Could never do this much power on pump gas with just one walbro.
His fuel system has larger lines as well. This helps lower total flow restriction and gives you a little extra overhead.
Old 12-24-2009, 03:24 PM   #16
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
My walbro was out of steam at 475whp on c16, it just baffles me how I see all these cars with 1 ****ty walbro making huge numbers.
Old 12-24-2009, 04:18 PM   #17
Maxwell Power
Member#: 190729
you sure you have the right Walbro? there are two or three available for our cars. Some vendors sell the wrong pump.
Old 12-24-2009, 05:48 PM   #18
juanmedina
Member#: 133146
he probably got the 190phl
Old 12-24-2009, 06:29 PM   #19
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
So what's the fuel setup besides the ID 1k's and fuel rail?
You mentioned larger diameter lines? This seems kinda interesting
verc is offline   Reply With Quote
Old 12-24-2009, 07:20 PM   #20
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
lol I work at a shop, I had the 255lph pump. I have a Denso Supra pump now.
Old 12-24-2009, 07:22 PM   #21
juanmedina
Member#: 133146
lol so why are you running out of injector?
Old 12-24-2009, 07:29 PM   #22
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
lol it was running out of pump bud, I have 1000's.. fuel pressure was dropping
Old 12-24-2009, 08:25 PM   #23
1_STi_2NV
Member#: 197567
Wow those are some good numbers. Have you guyz take it to the track?
1_STi_2NV is offline   Reply With Quote
Old 12-25-2009, 01:19 PM   #24
Maxwell Power
Member#: 190729
there are two 255lph pumps. One is the high pressure pump and flows about 50lph more at boosted pressure levels. That's what I asking.
that's it. Walbro, -6 lines, fuel rails and injectors.
Race gas is the big factor. Couldn't flow enough fuel at the richer afrs that pump gas requires.
I wish. It's cold as heck up here in Washington State and there aren't any open tracks that I'm aware of. Trust me, when we get the chance, Wes will be there.
Old 12-25-2009, 03:05 PM   #25
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
I'm wondering if Maxwell Power can chime in on why this is? I never really got the deal with 1000cc maxing out a single Walbro because at the standard 43/43.5 psi,
1000cc injectors @ standard 43.5psi: 4 x 1000cc/min = 4 liters/minute = 240 liters/hour, matches up pretty perfectly with
Single Walbro: 255 liters/hour
And I know this car isn't doing meth injection, but if it were, an M10/15 nozzle theoretically takes away 38/56 lph (plus any fuel savings from leaning it out) of load from the fuel pump - should be plenty of overhead! (basically the same for the M10 nozzle as going to the Denso Supra pump)
Dyno Tune: 2.5L, GT35R, E85-Tuned STI Makes 540whp! Cobb Tuning Proven Power Bragging 45 04-25-2013 04:42 AM
Maxwell Power Dyno Tune: 2.5L SOHC + GT3071R = 512ftlbs of torque Maxwell Power Proven Power Bragging 102 12-11-2012 09:19 PM
Dyno Tune: 2.5L + GT35R + AEM EMS = 505whp wrspeed Proven Power Bragging 10 03-28-2010 07:17 PM
Dyno Tune: 2.5L, GT35R, makes 439whp apexslider Proven Power Bragging 6 02-09-2010 10:29 AM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
