Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 12-23-2009, 11:26 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default James you were right :(
I can't make 350 hp on cobbs dyno. BUT I did make 371 TQ
Just another dyno with another set of numbers.... 312hp 371tq holding 18psi at redline on the stock BPV not crushed.
Oh, and I am maxing out my MAP sensor, so I can't read relative pressure right. I am hitting 27.1 psi on the stock turbo, knock free!
After talking with Christian, I need to take 10% out of my WGDC and buy a new MAP sensor so it will measure correctly. It should add another 10+Hp Too bad the dyno is going away. So nothing to compare it too.
AB spread sheet reads exactly the same numbers. My ECU Edit reads about 30hp more but same TQ. Now I know how to adjust my software to read exactly the same as Cobbs.
Too many variables they all can make huge differences. Just like from 1 dyno brand to another. That was my whole goal for running on Cobbs dyno. Now I have something to compare all my logs too.
medamullet is offline   Reply With Quote
Old 12-23-2009, 11:38 PM   #2
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
how much does a run cost down there?
im assuming you have to have an appointment also?
801_STi is offline   Reply With Quote
Old 12-23-2009, 11:54 PM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
For what I did it was 125 an hour. No wide band, nothing just an hour worth of dyno pulls.
Yes, you have to have an appointment. I was told the dyno might be gone by the first of the year. They are closed for business until the 4th so that's why I booked and did it today it was way short notice.
Old 12-24-2009, 12:05 AM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Still very impressive numbers for a vf39
Why do the Cleverley brothers motors hold together so well?. Im surprised its staying together at 27psi.
bhhamblin is offline   Reply With Quote
Old 12-24-2009, 12:13 AM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Ya, we were all completely shocked. I will fix the MAP sensor problem and lower things down a bit. I am shocked I don't knock pushing that much boost.
Old 12-24-2009, 12:17 AM   #6
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Which MAP you going with?
Old 12-24-2009, 12:29 AM   #7
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Overall, VERY NICE!!! I knew your torq would be up there, I honestly thought torq would be closer to 400. For HP there is no way the VF can throw enough air, just not possible.
Boost doesn't kill motors, it is knock. Now if you have a knock event at those boost levels then you are done for. Think of your pistons like an egg. If you apply equal pressure around the egg you can squeeze till your hearts content and it will hold. But if one spot has more pressure (knock) then... crack.
Stames_wiltz is offline   Reply With Quote
Old 12-24-2009, 12:39 AM   #8
MXJS
Member#: 129793
2004 STI
LSX RX-7
Some badass numbers for a vf39! Can't wait to play with E85 again
MXJS is offline   Reply With Quote
Old 12-24-2009, 12:43 AM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I don't know. I haven't even thought about it until today. I talked to christan about cobbs. I will do some looking around and see what I shall do.
Old 12-24-2009, 12:47 AM   #10
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
Awesome jason-you had the balls to go get it done.
your motor is solid dude.
If you are too concerned about your boost down low then wind that MBC out a turn or two ;-)
Kastley85891 is offline   Reply With Quote
Old 12-24-2009, 12:51 AM   #11
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
I dont see how you are maxing out the MAP. Mine on my wrx is still fine.. Im hitting about the same boost level. But im assuming the tuner was reading off my AVCR boost gauge rather than the computer.
Maybe mine is maxed out idk. I was confused with what MAP you were talking about...My defi gauge came with as well as my AVCR boost controller. Then i realized you were talking about the stock one on the throttle body.
It all makes sense now!
Old 12-24-2009, 12:52 AM   #12
Sports Wagon
Member#: 43081
Nice!
Sports Wagon is offline   Reply With Quote
Old 12-24-2009, 01:04 AM   #13
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
27 psi with altitude would get close to maxing out the the sensor. get that 3 bar goin!!!
azn2nr is offline   Reply With Quote
Old 12-24-2009, 01:09 AM   #14
ashergrey
Member#: 174533
0694 WRXLtd/LegWagon
WRB/Pure White
Freaking sweet Jason. So you ended up ditching out on work, eh?
ashergrey is offline   Reply With Quote
Old 12-24-2009, 01:17 AM   #15
PCSkiBum_21
Member#: 164437
EVO IX - Track Car
BRZ - Daily
i want to run e85 now so bad! holy balls, 370tq on a vf39
PCSkiBum_21 is offline   Reply With Quote
Old 12-24-2009, 01:48 AM   #16
soob noob
Member#: 220158
02 bugeye
medamullet tuned
hell yeah jason thats SWEET!
soob noob is offline   Reply With Quote
Old 12-24-2009, 02:00 AM   #17
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Another question. How much tuning is needed for an aftermarket MAP sensor.
Old 12-24-2009, 02:30 AM   #18
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I have no idea brody. I haven't even looked in to a MAP sensor nor thought about how they worked until now.
Old 12-24-2009, 03:56 AM   #19
godfather2112
Papi Chulo
Member#: 53794
.... OT Supplement
Testing Division.
I barely hit 300whp on a fp green ;(
godfather2112 is offline   Reply With Quote
Old 12-24-2009, 08:53 AM   #20
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I'm sorry Dan. I can't do any logging until it dries out. 3rd gear I can cut all 4 tires loose when I hit about 4k. I wanted a bunch of logs to compare before and after but it was impossible.
Old 12-24-2009, 10:47 AM   #21
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
very impressive!!!! This makes me want to go with a bigger top mount, bigger injectors and E85, but alas it is very hard to find down in this neck of the woods
06HAWKMAN is offline   Reply With Quote
Old 12-24-2009, 11:55 AM   #22
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Looks nice Jason. I was at 300WHP and 360WTQ on 100ctane on my stg2 with headers, DP, and drop in filter running 23psi on a VF48. Stupid corn juice
For the MAF. Look into the Cobb Big maf. 72mm, mated up with a mode racing air box should work out nice.
Wonder how that turbo will hold up on your car at that boost level.
snowman4us is offline   Reply With Quote
Old 12-24-2009, 12:19 PM   #23
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
Nice that AB dyno is pretty close to COBB dyno, well at your altitude and all...
Makes my Corn munchin 08 look even better at 403/418
Jason you need a 20G on that thing and we can really get it dancing in third....
Side note as usual - got my AP for my Z, it is currently a paper weight as my ECU is not recognised.... it will take a good time in to the new year, possibly Feb till I can use it so the most expensive 'idle' tool I have at this time...lol I did how ever get my COBB post MAF tubes and they DID make a difference, Hopefully my INVIDIA CB will turn up today, Jason, I will post in car vids, sadly at 7600 rpm not the intended 8300!!!
Oh - Happy xmas to you all and good new year
Old 12-24-2009, 12:34 PM   #24
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Why the wait on the A.P.? software update?
Old 12-24-2009, 01:36 PM   #25
Kastley85891
Member#: 127704
2013 Hybrid
Needs an 05STI
My ECU version is not supported, I pulled my rom and am sending it back but adding my rom to database will take a bit, then I will need an update to firmware on AP,Dongle and a new version of race tuner software, so at the moment I have a idle AP and stock rom
OT, geeks. you were right MikeCee Off-Topic 22 10-05-2009 11:10 AM
REX8, I was wrong you were right. SCRAPPYDO General Community 63 04-01-2008 12:29 PM
kingsti, you were right. But not about citi. Indocti Discant Off-Topic 98 03-24-2008 11:20 AM
You were right about STi power increase! STi300 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 04-17-2005 01:22 AM
DuBYARX, you were right about the Bosch wipers Scoob Mid West Subaru Owners Club Forum -- MWSOC 28 12-15-2001 05:39 PM
