Old 12-23-2009, 11:28 PM   #1
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Default 2006 sti VF39 E85 4400' Elevation
I can't make 350 hp on cobbs dyno. BUT I did make 371 TQ
Event: Cobb Dyno
Ambient Temp: 38*F
Elevation: 4400'
Weather: Snowing outside
Track and Conditions: NA
Tires: Potenza RE019 225/45R 17 (Brand new)
Car: 2006 STI
Tuner:Keith Astley
Peak HP at RPM: 312
Peak Torque at RPM: 371
STi 2.5L
Target Boost: 27 psi (Accident, stock MAP won't keep up) Shooting for 24psi
Target AFR: 11.7
Fuel: E85
Engine/Power Modifications: 3" APS TBE Ceramic coated and heat wrapped
65mm APS CAI
3" APS inlet
Stock header ported Ceramic coated and heat wrapped
Grimmspeed Crossover pipe Ceramic coated and heat wrapped
Grimmspeed 38mm EWG up pipe Ceramic coated and heat wrapped
Tial 38mm EWG
Grimmspeed EBC
Grimmspeed MBC
Grimmspeed 8mm phenolic spacers
TGV deletes ported polished and Ceramic coated
20x7.5x4.5 TMIC (Core measurements)
830cc injectors
1 step colder plugs
Suspension Modifications:
17x8 45 offset RFP1 PC black
H brace
Front and rear strut town bars
Tanabe GF210 springs (stock struts)
27mm WL front Sway
22mm WL rear Sway
WL end links
Stainless brake lines
DBA 2 piece slotted Rotors
Hawk Blue pads
600* Brake fluid
CT Front splitter
255 40r 17 NT01 (track only tires on stock BBS)
Just another dyno with another set of numbers.... 312hp 371tq holding 18psi at redline on the stock BPV not crushed.
Oh, and I am maxing out my MAP sensor, so I can't read relative pressure right. I am hitting 27.1 psi on the stock turbo, knock free!
After talking with Christian, I need to take 10% out of my WGDC and buy a new MAP sensor so it will measure correctly. It should add another 10+Hp Too bad the dyno is going away. So nothing to compare it too.
AB spread sheet reads exactly the same numbers. My ECU Edit reads about 30hp more but same TQ. Now I know how to adjust my software to read exactly the same as Cobbs.
Too many variables they all can make huge differences. Just like from 1 dyno brand to another. That was my whole goal for running on Cobbs dyno. Now I have something to compare all my logs too.
medamullet is offline   Reply With Quote
Old 12-23-2009, 11:43 PM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
nice. I was on a mustang dyno once when i had my stock turbo. I hit 28.0 psi exactly. Holding boost on the vf doesnt seem to increase performance as it is just hot air that is moving at that point. I made 304 whp and 383 trq, it was quick. Even falling off to 14psi, I held 285.
What type of timing do you see at redline?? Im assuming your right around 21-23* at peak torque and run 31-33 at redline?
STi Mikey is offline   Reply With Quote
Old 12-24-2009, 12:08 AM   #3
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I would have to look at my logs. I thought I was hitting 24psi. I had no idea I was maxing out the MAP sensor until I hooked up to the dyno. I will make necessary changes and lower it down to something reasonable. I just think its weird that at 27psi I don't knock at all.
Old 12-24-2009, 12:24 AM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
E85 antiknock properties
I tough the MAP sensor only read to 22.7psi?
Old 12-24-2009, 12:28 AM   #5
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I get 24.38 on my logs. But once we hooked it to the dyno that **** went crazy to 27.1 psi. Obviously the sensor is maxed out. Haha oh well I will fix it.
Old 12-24-2009, 12:30 AM   #6
juanmedina
Member#: 133146
07 FPgreen 7.37@95
What are you logging with?
Old 12-24-2009, 12:38 AM   #7
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
OS and ecuedit. I have both I use. now knowing its wrong it kinda sucks, I wonder what else the stock ecu and sensors can't keep up with.
Old 12-24-2009, 12:45 AM   #8
fourmicah
Member#: 128760
2015 STI
Nice Jason
fourmicah is offline   Reply With Quote
Old 12-24-2009, 01:56 AM   #9
Deuce Cam
Member#: 130444
'85 AE86 GTS
That seems like an odd hp curve (peak @ 4800, and then falls off). Am I reading that correctly?
Deuce Cam is offline   Reply With Quote
Old 12-24-2009, 02:16 AM   #10
CatfaceType-R
Member#: 81102
nice man, I bet she rips!
CatfaceType-R is offline   Reply With Quote
Old 12-25-2009, 11:53 AM   #11
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Thank you for editing your opening post to reflect the new format
Audiosavvy is offline   Reply With Quote
Old 12-25-2009, 12:52 PM   #12
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
I m with you on that. I think that it can still read ~23psi but then its not accurate much after that. I don't recall ever hearing anyone reading up to 27psi on a stock MAP sensor though.
4ST-AIR is offline   Reply With Quote
Old 12-25-2009, 01:02 PM   #13
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I obviously found out the stock MAP doesn't read 27.1. All my logs show 24.58 as the max. I was logging AND hooked up to the dyno so I could compare logs. The dyno would read 27 and the logs read 24. I am not sure where the cutoff is for accuracy. I was trying to run 24psi, so time for upgrade to at least a 3bar MAP I guess.
Old 12-25-2009, 01:12 PM   #14
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
yeah, you need a boost gage after 24psi. Im right at 23 now, and for race gas I have to use my in car gage, or the if on the dyno, ill use that boost gage. But with the stock map sensor your laptop wont help when your leaning on your turbo.
Old 12-25-2009, 06:55 PM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I have a defi red racer boost gauge. I should pugrade to something that can hold a peak boost number so I don't have to watch it while I am logging. Too dangerous for my liking. I will upgade the map as soon as I can make up my mind on which one to get. Then fix my WGDC and lower my boost a bit.
Old 12-25-2009, 07:12 PM   #16
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I have the same problem I never know what I am really boosting .
I am getting the glowshift ELITE [FLAME SUIT ON] with recall feature
Old 12-25-2009, 09:05 PM   #17
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
From memory Jason is around 28-30 degs up top, 22 ish at peak,, Medamullet , told ya dude, get that cheap ass SRTI mech boost gauge...
Like I said dude, that car gets up and goes
Kastley85891 is offline   Reply With Quote
Old 12-25-2009, 11:05 PM   #18
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
It is a rocket ship. I tell people and they don't believe me. From my road logs I hit full boost at 3100rpms. Its fast that's for sure. With my stig driver I am pretty sure I can hit low 12's. He was high 12's with 70 less tq.
The defi registers fine. I just need a new map sensor. I only hit 27 for a second in 4th gear. The defi actually reads correctly. I can see it spike in 4th then it drops. In 3rd gear it just hits 24 right where I want it to be.
Old 12-25-2009, 11:46 PM   #19
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
Cobbs dyno is not for the faint of heart if you care about #'s. First time I got my car tuned was on that dyno with John. Made some insignificant stock-ish # with my VF39 swap, got in the car after the tune a little disappointed and sad, that lasted exactly 1.5 minutes. The time it took me to make the right turn, go through the light, and hit the onramp, lol.
Krang is offline   Reply With Quote
Old 12-26-2009, 01:59 PM   #20
fourmicah
Member#: 128760
2015 STI
That's exactly what happened to me. I had a little more than a VF39, but I was expecting more from my set up and then I drove it and was smiling ear to ear.
Old 12-27-2009, 04:57 PM   #21
FORCFED
Member#: 231014
04 STI
AW
Where do you live? The reason i ask is that in PA where i live E85 is available but the mixture chnages to E70 or E75 in the winter. Do you run E85 all year with the same map or do you have a different one for the winter?
FORCFED is offline   Reply With Quote
Old 12-28-2009, 12:07 PM   #22
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
i live in utah. I hear rumors and such that our fuel is actually E75 all year long. I have no data to back that up. When I start my car in the winter I have to let it sit for a few minutes and warm up. It doesn't like to run in the winter when the car is cold. We goofed around with my ROM a few months ago to see if it would make a difference if we adjusted the fuel table. I think it helped a bit, but I still let it sit and warm up. It was 18* yesterday when my wife and I went to the movies and it started just fine. It's not that big of a deal really.
EQ: 05 STI, VF39, E85 - 352whp/434ft-lbs @ 21psi! UPDATE: 119.7mph Trap! Equilibrium Tuning Proven Power Bragging 180 10-15-2010 02:43 PM
2006 STI VF39 w/ Perrin Headers - 285whp on 91, 309whp on 98! Equilibrium Tuning Proven Power Bragging 29 05-29-2008 08:35 PM
2006 sti VF39 turbo scooter29 Private 'For Sale' Classifieds 6 07-16-2006 07:41 PM
WTB 2006 STI VF39 Turbo West Coast...? Evil_STI Private 'Wanted' Classifieds 0 07-16-2006 02:46 AM
2006 sti vf39 and STI up pipe 3200 miles on both!!! Great wrx upgrades kccobra Private 'For Sale' Classifieds 25 05-18-2006 01:08 AM
