Old 12-23-2009, 10:45 PM   #1
Maxwell Power
Member#: 190729
Default Maxwell Power Dyno Tune: 2.5L SOHC + GT3071R = 512ftlbs of torque
Let me start by saying, I LOVE THIS CAR. Over 500 ftlbs of torque at 4000RPM is just an awesome ride. This car only weighs 2840lbs and with this power it's a ROCKETSHIP!! I think this is also a testament to the ability of the Albins gears. We spent the last few weeks pounding on this transmission with this power.
Event:
dyno tune
Ambient Temp: 32F 51%humidity
Elevation: 200ft
Weather: Freakin' Cold Still
Car: 2000 2.5RS Coupe
Owner: Craig Woolman of Maxwell Power Services
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 433.5 whp uncorrected, 403whp SAE corrected @ 5600rpm
Peak Torque at RPM: 512 ftlbs uncorrected, 475.6 SAE Corrected @ 4000rpm
Baseline hp/tq for a stock on same dyno: 125whp
Target Boost: 23psi
Target AFR: 12
Fuel: Sunoco 110oct (leaded)
Method: Hydra Nemesis
Engine/Power Modifications:
*Custom built 2.5L shortblock: JE Pistons, MPS Long Rods, Billet Crank
*Hand ported SOHC EJ251 Heads, 2000/1000 Custom Cams ground by Delta Cam, Ferrea Valves and Springs
*Precision Turbo GT3071R w/ 0.63 turbine housing in custom rotated setup.
*Custom TMIC
*92lb/hr injectors, Outfront Motorsports Fuel Rails
Driveline Modifications:
*Albins Off Road Gear 1-5 Helical/Synchro gearset in 2000 RS 5MT Box
*Kaaz Front, Center and Rear Diffs
*ACT 6-puck copper clutch with XTreme Duty pressure plate and 14lb flywheel.
Suspension Modifications:
*Racing Logic Coilovers
*Whiteline Suspension goodies (bars, links, roll center adj, etc.)
thanks for looking,
Dominic Acia
Arlington, WA
360-474-8225
Maxwell Power is offline   Reply With Quote
Old 12-23-2009, 11:02 PM   #2
dothespeedlimit
Member#: 55980
car. car!
car?
very nice.. you wouldn't happen to have gear ratios at hand?
dothespeedlimit is offline   Reply With Quote
Old 12-23-2009, 11:08 PM   #3
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
WOW crazy spool,
Old 12-23-2009, 11:12 PM   #4
Maxwell Power
Member#: 190729
http://forums.nasioc.com/forums/show....php?t=1890270
Old 12-23-2009, 11:15 PM   #5
AwaySooner
Member#: 151964
2007 Forester XT Lim
CGM
Come on Dom, I thought you LOVE my car.
mad prop to MPS, awesome car and a lot of ingenuity went into Craig's car.
AwaySooner is offline   Reply With Quote
Old 12-23-2009, 11:18 PM   #6
fourmicah
Member#: 128760
2015 STI
That's impressive!
fourmicah is offline   Reply With Quote
Old 12-23-2009, 11:21 PM   #7
Maxwell Power
Member#: 190729
Big props to MPS, awesome car and a lot of ingenuity went into Craig's car.
I LUST your car.
The turbo kit in Craig's car, TMIC, intake, rails, injectors etc are all out of my RS. So there is some sentimental value in his. Thus the "love".
Your car has my trans and diff which is sentimental as well, but it's got the STi swap, S203 wheels and other things ; thus the lust.
Old 12-23-2009, 11:23 PM   #8
Maxwell Power
Member#: 190729
Originally Posted by juanmedina View Post
WOW crazy spool,
it's pretty nutz.
at 3k rpm, you have 200ftlbs of torque, at 4k you have over 500 at the wheels. If you want to go sideways in this car, it's REAL easy.
Old 12-23-2009, 11:23 PM   #9
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Nice work man. That's the turbo I want with your motor
medamullet is offline   Reply With Quote
Old 12-23-2009, 11:25 PM   #10
Maxwell Power
Member#: 190729
we're working on a better one.
keep us in mind and stay tuned.
Old 12-24-2009, 06:14 AM   #11
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
are you using the COP ignition off a wrx?
...this is a perfect example of a badass tmic build! fmic...yea right!
i would gladly fill the tank with c16 for a ride in this car
All4bSpinnin is offline   Reply With Quote
Old 12-24-2009, 07:39 AM   #12
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Damn that spool is nuts! If you could hold that power to redline it would be the perfect street powerband. Becides the smaller A/R, is there anything else done to this car that helps it spool so fast?
Steve.804 is online now   Reply With Quote
Old 12-24-2009, 09:50 AM   #13
QksilverRS
Member#: 16826
01 STi DOMINATOR 3
444 WHP 431 WTQ
this is crazy...i had a TD05 20G that made 405 at the wheels at similar RPM and it was straight dangerous to drive if you were not expecting that TQ....sideways is right! wheel smoke on command!! great build!
QksilverRS is offline   Reply With Quote
Old 12-24-2009, 09:58 AM   #14
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
No pun intended
When you bring my car back to life, can you make me a pretty post like this too ?
leonbmx is offline   Reply With Quote
Old 12-24-2009, 01:58 PM   #15
Maxwell Power
Member#: 190729
no sir. Regular 2.5 RS coil. Notice the boost is only 23psi. If you go too much higher you start to blow out spark.
The heads are the answer. They are the reason why it spools so fast and why the power drops off hard on the top end. The port design says it all.
There is ALWAYS a compromise of some sort. We are contemplating putting a larger AR turbine housing on it so see how much it helps the top end.
Originally Posted by leonbmx View Post
No pun intended
abso-smurfly.
Old 12-24-2009, 02:17 PM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
I like it.
godforbid67 is offline   Reply With Quote
Old 12-24-2009, 03:35 PM   #17
silver-duck
Member#: 130710
I love my 'Maxwell motor[JE pistons, kelford-B cams, 3076 , 1000 inj. etc.]I wish I could turn it up but I need a tranny first.
At 16psi it makes 368hp/ 318tq.[being nice to trans]and 27mpg
Amazing thing is I start it up on a cold day, it idles better than stock and no piston slap[quiet]
Thankyou Dom, Craig, Wes; it was fun working with you guy,s!
silver-duck is offline   Reply With Quote
Old 12-24-2009, 03:59 PM   #18
juanmedina
Member#: 133146
What happen to your DS1 tranny?
Old 12-24-2009, 05:38 PM   #19
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
this is awesome. any pics of the car?
timeXlost is offline   Reply With Quote
Old 12-24-2009, 05:47 PM   #20
silversubiedude
Member#: 182010
2002 slow wrx
psm
Ya the pictures/movie should be up soon.
silversubiedude is offline   Reply With Quote
Old 12-24-2009, 08:33 PM   #21
juanmedina
Member#: 133146
Is the 6-puck unsprung? is so how do you like it?
Old 12-24-2009, 10:41 PM   #22
eg33GC
Member#: 206851
56 Belair
Pro Street
500ftlbs..
my 240ftlbs raises bloodpressure, I cannot imagine double that.
Nice work.
eg33GC is offline   Reply With Quote
Old 12-25-2009, 12:19 PM   #23
gumby647
Member#: 2532
2001 2.5RS-T
BRP
I'm curious what you guys used for a header and what you ended up with for compression.
I'm using the same turbo but on a completely stock NA engine so it's nice to see what it's capable of once I upgrade some more stuff.
Here's a link to some pics of my coil setup. I made a custom harness for the coils that runs back to the Hydra. They work really well once the dwell is set properly and I'm able to run a 1mm gap on a 10:1 engine pushing 12psi. With the stock coil It wouldn't pull clean over 6000rpm even with a .6 gap.
http://forums.nasioc.com/forums/show...7&postcount=30
gumby647 is offline   Reply With Quote
Old 12-25-2009, 12:30 PM   #24
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
This is a cool build guys. Can someone elabortate on such a fall off of power in the taller rpms?
the car is sohc, but over 100whp loss, damn. Def an auto x monster though.
STi Mikey is offline   Reply With Quote
Old 12-25-2009, 01:23 PM   #25
Maxwell Power
Member#: 190729
Simple: SOHC heads, .63 A/R turbine, TMIC.
There is ALWAYS a compromise. Faster spool means less top end HP.
we covered that already.
Dyno Tune: 2.5L '09 WRX Completely stock, makes 263whp. <-- dyno reading incorrectly Breezio Proven Power Bragging 114 10-12-2010 09:00 PM
Maxwell Power Dyno Tune: 2006 WRX, Built Motor, ATP GT3076R, 16psi = 380whp Maxwell Power Proven Power Bragging 77 02-12-2010 04:18 PM
Maxwell Power Dyno Tune: 2.5L Hybrid + GT35R = 588whp Maxwell Power Proven Power Bragging 47 12-31-2009 06:31 PM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-08-2009 11:18 PM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 08:32 AM
