Old 12-25-2009, 05:09 PM   #1
4080wrx
Member#: 68129
Chapter/Region: HIIC
2001 Impreza RSTi
Default 2001 Impreza 2.5RS w/05 STI swap tuned by AMS
Event: Dyno pull
Ambient Temp: 92 degrees
Elevation: sea level (and some change)
Weather: sunny
Track and Conditions:
Tires:
Car: 2001 Impreza 2.5RS
Tuner: Chris Black of AMS
Dyno Info: Dyno Jet
Peak HP at RPM: 338
Peak Torque at RPM: 360
Baseline hp/tq for a stock on same dyno:
Target Boost:
Target AFR:
Fuel: 92 octane
Engine/Power Modifications:
-2005 STI engine and drivetrain installed in GC at 17,xxx miles
-Deadbolt Zilla TD06 18G w/full port and polish on the hot and cold side and ceramic coating for hot and cold side
-Deutches Werks 650cc injectors
-JDM TGV deletes
-Walboro fuel pump
-Gruppe-s header
-Gruppe-s lightned crank pulley
-Invidia CBE
-Perrin downpipe
-Tial 44mm EWG w/atmospheric dump
-Hallman manual boost controller
-TurboXS shorty intake
-APS TMIC
-07 STI BOV
-Open Source AMS Tune
-Area 1320 IWG bracket
-Optima Red Top battery
Suspension Modifications:
-JDM Enkei rims (Gold), 17x8 5x114.3 +53 offset
-BC Coilovers BR Series 10k fronts and 8k rears w/front and rear camber plates w/rear extenders
-JDM Impreza STI Version 6 carbon fiber front strut bar
-JC Sports rear strut bar
-Cusco front and rear sway bars
-Whiteline front and rear endlinks w/heavy duty sway bar mount
-05 STI Brembo brakes (4 pot front and 2 pot rear)
-Cobb Stainless steel brake lines (front and rear)
Other Modifications:
Dyno graph. The red line represents AMS (current tune) and the green line represents PDX (old tune).
Pics:
Video:
4080wrx is offline   Reply With Quote
Old 12-25-2009, 05:12 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
very clean car nice job on the full drivetrain swap.With the lighter vehicle package that car is probably a blast to drive.I really like the 2dr rs body--have fun and be safe.
john 1badSTI is offline   Reply With Quote
Old 12-25-2009, 05:15 PM   #3
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
I did a 99 coupe with a full swap this week. Thing made 400/400 and I about **** myself when we took it on the road. It made me miss my RS so bad, he got to drive his home. I got to push mine in
Congrats and Enjoy it. I will always say that the RS/GC is by far the most fun of all the Subaru's.
Jr
Junior2JZ is offline   Reply With Quote
Old 12-25-2009, 05:18 PM   #4
4080wrx
Member#: 68129
2001 Impreza RSTi
thanks....I am finally getting use to the huge power to weight ratio. in the beginning this car scared the crap out of me.
also below is a link of the journal i kept while building this car. for the most part I went from 2 cars to the dyno within 17 days.
http://www.i-club.com/forums/showthread.php?t=212223
Old 12-25-2009, 05:46 PM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
nice car and setup
How much does the car weight?
GL
juanmedina is online now   Reply With Quote
Old 12-25-2009, 08:33 PM   #6
4080wrx
Member#: 68129
2001 Impreza RSTi
Originally Posted by juanmedina View Post
nice car and setup
GL
according to my registration 2900 pounds but with the swap not sure. I am trying to track down a place where I can weigh the car officially.
Old 12-25-2009, 09:51 PM   #7
Krang
Member#: 134272
2002 WRX Wagon - WRB
ej207 v8 vf37
Go to the dump over in Kailua, or I bet you could get it weighed at Sand Island somewhere. They must have a scale out there.
The car looks beautiful in person. So clean and looks like everything on the car was there from the factory, exactly what I am looking to do with my wagon. When I get back i'm going to have to bug you for a ride in this beast!
Krang is offline   Reply With Quote
Old 12-25-2009, 10:18 PM   #8
4080wrx
Member#: 68129
2001 Impreza RSTi
As clean as the car looks there are still minor stuff that need to be fixed that only the guy that built the car from the ground up would see. But for the most part the car is 98% complete. I also can't take full credit for all of it. Shags and Dave helped out a lot and provided ideas on how to make things work. Its also kinda crazy on how those two can get my imagination moving. I would spend hours or even a day trying to figure out how to make something work and the second they show up BAM I figure it out.
I will start seriously looking around for a scale this coming week. with all the holiday activities I kinda took a break from the car.
As for the ride, let me know. Probably be best when the t-shirts come in.
Old 12-25-2009, 10:34 PM   #9
Krang
Member#: 134272
ej207 v8 vf37
^ I'm not going to be back until next year so it would probably be around that time. I will hit u up!
Also, as I just saw you noticed, you posting your results got me motivated to do the same lol.
Old 12-26-2009, 08:45 PM   #10
Benchmark Tuning
Member#: 154444
2008 08 STi, Typhoon
06 STi, 847-960-8676
Jess...good stuff, i remember when that set-up was in ur 05 STi, clean GC
Benchmark Tuning is offline   Reply With Quote
Old 12-28-2009, 10:47 AM   #11
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
OP, please read this thread and reorganize your 1st post to reflect the required format. Looks like you have most of the information there, just needs to be organized differently. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 12-28-2009, 12:03 PM   #12
4080wrx
Member#: 68129
2001 Impreza RSTi
Fixed
Thanks for the heads up!
Old 12-28-2009, 06:37 PM   #13
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
very nice, bout how much he spend to get it together?
not labor or tune, just parts & the chasis or car or whatever it started from?
KB'izzle is offline   Reply With Quote
Old 12-28-2009, 08:02 PM   #14
4080wrx
Member#: 68129
2001 Impreza RSTi
I paid 10k for the 01 RS back in 2006 and used it as my daily driver as I had an 05 STI as my play car.
The STI was t-boned in October 08 and the bank wanted to repair the STI since the car was worth 20k and it had 14k in damages. After getting multiple opinions on the condition of the car it was not in my best interest to fix the damage (floor pan rolled). So I told the insurance company to cut me a check for the repairs (14k) and that I would use it towards paying off the car. SO out of pocket I technically paid $1000 to the bank to buy out my car. Now this is not counting the monthly payments I have been paying for the past 3 years.
Now add that I already had performance parts on my STI which was roughly 8-10k worth of stuff. I would say I have a total of just under 20K invested into the car depending on how you look at it. Not to mention I am now out of a car payment.
Old 12-28-2009, 10:04 PM   #15
juanmedina
Member#: 133146
nice GC
Old 12-29-2009, 01:14 PM   #16
rico_q808
Member#: 155896
2006 WrX
bLuE
very nice....
rico_q808 is offline   Reply With Quote
Old 12-31-2009, 10:21 AM   #17
burtonrider3889
Member#: 163519
2006 Cayman S
Very sick. I wonder what something like this is running in the 1/4.
burtonrider3889 is offline   Reply With Quote
Old 12-31-2009, 10:39 AM   #18
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Very nice but why not used uncorrected instead of SAE which takes away power?
project_skyline is offline   Reply With Quote
Old 12-31-2009, 03:00 PM   #19
Krang
Member#: 134272
ej207 v8 vf37
^^ It's just the way the dyno was set up that day. It doesn't take away power, only changes #'s so who cares?
Old 12-31-2009, 03:24 PM   #20
4080wrx
Member#: 68129
2001 Impreza RSTi
guarantee mid to low 12's.....I'd imagine if I can get a good launch and my driving is on point high 11's would be possible.
Old 12-31-2009, 03:59 PM   #21
Ds baruuuuu
Member#: 4724
01 01RS
brp
Jess there is a scale on middle street on the right when you turn from dillingham, thats where all the dealerships get cars weighed for title stuff
Ds baruuuuu is offline   Reply With Quote
Old 12-31-2009, 09:09 PM   #22
4080wrx
Member#: 68129
2001 Impreza RSTi
damn and thats like right around the corner from me.......thanks Big Deezy!
Old 01-04-2010, 09:41 PM   #23
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Very nice indeed. Going from the N/A 2.2 in my L to the conservatively tuned Ver 1/2 2.0L was a night and day difference, and a lot of fun...I couldn't imagine adding another 100+hp (mine currently puts down around 220).
beaviscih is offline   Reply With Quote
Old 02-02-2010, 10:36 AM   #24
4080wrx
Member#: 68129
2001 Impreza RSTi
for sure a night and day difference....the crazier part is going from 4EAT to 6 speed
Old 02-02-2010, 11:42 AM   #25
Badler
Member#: 133597
Clean car man. Bravo!
Badler is online now   Reply With Quote
2001 Subaru Impreza 2.5RS with 2002 WRX swap jmoffitt Private Vehicle 'For Sale' Classifieds 2 06-13-2009 11:55 PM
FS: 2001 Subaru Impreza 2.5RS coupe w/ EJ257 swap and CARB legal STi-coupe Private Vehicle 'For Sale' Classifieds 21 05-29-2009 09:12 PM
2001 2.5rs coupe. 05 wrx swap thisisthenewsic Private Vehicle 'For Sale' Classifieds 43 12-01-2008 01:29 AM
2001 2.5rs coupe. 05 wrx swap thisisthenewsic SCIC Private Classifieds 50 11-24-2008 11:43 AM
Few questions on 98 2.5rs to 05 STi swap bdr2488 Subaru Conversions 6 10-19-2006 10:07 PM
