Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-25-2009, 02:16 AM   #1
top222
Member#: 192481
2003 BMW M3,300zx TT
Default 2004 STI Seems to be using oil
So I bought this motor after I blew my other motor and the motor has ran mobile 1 its entire life or so the guy before me says the motor has like 35k miles on it. But it seems to be using oil i Keep adding the recommended weight by the oil cap in full synth. Should I try to not use full synth and see if it still uses oil?
top222 is offline   Reply With Quote
Old 12-25-2009, 03:22 PM   #2
bluesubie
Member#: 767
04 FXT
There are many more viscosities allowed other than what's on the cap. Has the PCV been replace lately? How much are you using? Mods?
First step is to switch to a more robust oil. If you want to stay with M1, try M1 High Mileage, M1 0W-40, or M1 T&SUV 5W-40.
-Dennis
Old 12-25-2009, 03:25 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
oh boi....here we go AGAIN
Old 12-25-2009, 05:56 PM   #4
top222
Member#: 192481
Should I just go NON synth?
Old 12-25-2009, 06:44 PM   #5
Uncle Scotty
OK buy Nates beans
oh boi...here we KEEP going.........again
Old 12-25-2009, 07:00 PM   #6
Uncle Scotty
OK buy Nates beans
first of all......you are just like all the other lemmings that blow **** up because they dont know what they are doing or using
saying 'mobil1 full synth is just ****ing nebulous as mobil makes LOTS of 'mobil 1' oils
below is a list of all that I can come up with--including the 'non synth' ones
MOBIL 1 OILS
MOBIL 1 EXTENDED PERFORMANCE
Mobil 1 Extended Performance 5W-20
Mobil 1 Extended Performance 5W-30
Mobil 1 Extended Performance 10W-30
MOBIL 1
Mobil 1 0W-40
Mobil 1 5W-20
Mobil 1 5W-30
Mobil 1 10W-30
Mobil 1 15W-50
Mobil 1 High Mileage 5W-30
Mobil 1 High Mileage 10W-30
Mobil 1 High Mileage 10W-40
Mobil 1 Truck and SUV 5W-30 for Gasoline Engines
Mobil 1 Turbo Diesel Truck 5W-40 for Diesel Engines
Mobil 1 ESP Formula 5W-30
Mobil 1 ESP Formula M 5W-40
MOBIL CLEAN 7500
Mobil Clean 7500 5W-20
Mobil Clean 7500 5W-30
Mobil Clean 7500 10W-30
MOBIL CLEAN HIGH MILEAGE
Mobil Clean High Mileage 5W-30
Mobil Clean High Mileage 10W-30
Mobil Clean High Mileage 10W-40
MOBIL CLEAN 5000
Mobil Clean 5000 5W-20
Mobil Clean 5000 5W-30
Mobil Clean 5000 10W-30
Mobil Clean 5000 10W-40
MOTORCYCLE OILS
Mobil 1 Racing 4T 10W-40
Mobil 1 V-Twin 20W-50
RACING OILS
Mobil 1 Racing 0W-20
Mobil 1 Racing 0W-30
________________
so sying 'mobil1 full synth' means NOTHING
also
the OTHER point here is....
the above is the MOST ridiculous farce foisted upon subadu owners by subaru and that ****ing oil cap should be recalled as the reason FOR SO FUCING MANY OF THESE ENGINES BLOWING THE **** UP.
5w30 is 'recommended' for FUEL ECONOMY ONLY AND NOT FOR ****ING PERFORMANCE OR ENGINE LONGEVITY OF ANY SORT AND SHOULD BE DISMISSED AS A BAD IDEA BY MOST OF US
IF THE ENGINE IS 'USING OIL' THAT MEANS THAT YOU ARE PUTTING THE WRONG ****ING OIL IN IT...SO STOP
Old 12-26-2009, 01:50 AM   #7
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
I don't think scotty got what he wanted for x-mas.
DHRDAN is offline   Reply With Quote
Old 12-26-2009, 02:37 AM   #8
Uncle Scotty
OK buy Nates beans
I just get really irritated when good cars get ****ed up for no reason
and the '5w30' myth and M1 are a PERFECT combination to blow **** right up
there are several GREAT M1 oils.....but the average lemming out there know nothing of motor oil and virtually ALWAYS picks the WRONG one and blows his **** up
that makes me mad
Old 12-26-2009, 04:04 AM   #9
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
ro-te-lla 5w40. < i use this and my car does not use any oil. 40k miles.
06-wrx-tr is offline   Reply With Quote
Old 12-26-2009, 04:21 AM   #10
Departed
Member#: 228045
2010 Evo X GSR/SSS
Wicked White
I am planning on using either the Rotella T 5w40 or Renewable Lubricants BioSyn 5W-40HD when I get my car back personally.
Departed is offline   Reply With Quote
Old 12-26-2009, 06:40 PM   #11
Rallycraft
Member#: 192625
take it to the dealer and have them start an oil consumption test, at the dealer I work at we do it for free. Test would take place over the coarse of ~3k miles taking back in to the dealer every 1k. That will tell you if you need a new engine.
Rallycraft is offline   Reply With Quote
Old 12-26-2009, 07:19 PM   #12
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Why bother on an 04 with no warranty...you can track consumption yourself.
Compression and leak down will tell the tale. Look for sputtering oil on the muffler and smoke under boost or WOT. Could be the hotside seal on the turbo. I've had two VF series turbo's go.
mapleleaf is offline   Reply With Quote
Old 12-26-2009, 08:09 PM   #13
Departed
Member#: 228045
2010 Evo X GSR/SSS
Wicked White
Also, when I had my cracked ring-land... when the car was hot(not always the case on every car but it was with mine) if i took off the oil cap I would see light smoke coming out. Also, I had NO smoke coming out anywhere but there and my ring-land was EFFED(pic below). Catts were doing their job still. Hope that's not your case, good luck!
Motorcycle loans and why they seem to be set up to screw you.. ErikAnderson North West Impreza Club Forum -- NWIC 21 06-27-2007 07:57 PM
I seem to be missing a swaybar- which parts do I need to install one? azn2yunr Brakes, Steering & Suspension 13 10-05-2005 01:46 PM
05 STi seems to be somewhat cold blooded? stevessti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 07-28-2005 10:48 PM
Oil feed line connection to my turbo seems to be loose... jigga Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-27-2005 10:39 PM
There seems to be some confusion about Saturday... subpreza Texas Impreza Club Forum -- TXIC 0 03-27-2001 09:41 AM
