Old 12-26-2009, 09:34 PM   #1
superv
Member#: 212305
'03 WRX Sedan
Default Photo Tutorial for the d-spec install on a 02-03 wrx?
I can't seem to find one around the web. I'm trying to replace a set (rear and front) on my 03 wrx sedan, but would like the read up before I actually spend the day doing it. Springs are prodrive blue i believe. Any help is appreciated.
there's this one, but is not for the wrx
http://www.americanmuscle.com/tokico...4-install.html
superv is offline   Reply With Quote
Old 12-26-2009, 10:15 PM   #2
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
don't have one for the shocks, per-se. but its very easy n straight forward on the subarus. Be very thankful that you are only doing full strut replacements, not having to do insert like some cars only have. So much less grunt-work.
Just unbolt your full strut, disassemble, and reassemble the top hats/bumps stops/boots on the new springs/struts...
Need some basic ratchets, sockets, breaker bar and torque wrench. Hopefully your new springs will be shorter a bit (most are), uncompressed, so you won't need a spring compressor if ya got a friend around to help.
However, consider rear adjuster extenders if you don't already have them:
http://forums.nasioc.com/forums/show....php?t=1102593
neko is offline   Reply With Quote
Old 12-26-2009, 11:39 PM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Scroll up. It's an inch or two from the "new thread" button.
OFFICIAL Brakes/Steering/Suspension Installation/Walkthrough Thread (inc. Koni)
http://forums.nasioc.com/forums/show....php?t=1430598
--> several links, including this one
How To: complete idiot's guide to spring installation (austinpike)
http://www.iwsti.com/forums/how-inst...tallation.html
Should pretty much work the same. Of course if you are installing full assemblies that would be easier.
Rear extenders are not worth it IMHO... takes about five seconds to unhook the rear seat, adjust, and re-hook.
If you get stuck on any particular bolts let us know. I just put my winter suspension back on and have a couple tricks, but the hardest parts are usually getting the big strut bolts out (2 per corner). Helps to disconnect the swaybar endlinks. From there I usually use a punch and a hammer of varying sizes. YMMV.
Old 12-26-2009, 11:40 PM   #4
Butt Dyno
Member#: 17301
is the "dark side"
Oh yeah. This is a good opportunity to grease your brake caliper slider pins.
Old 12-27-2009, 08:53 AM   #5
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
The most difficult part of installing DSpecs is tightening the bolt on the top of the strut once the spring, washer, and tophat are assembled on the housing. Its difficult because the strut wants to spin while you tighten the bolt. Do some searching - there's a few threads discussing this issue and methods that people have used to get it done.
Other than that, just follow the other tutorials that ButtDyno noted above.
thrasher is offline   Reply With Quote
Old 12-27-2009, 12:01 PM   #6
neko
Member#: 46500
Now with 200% more
^ its not that bad, since it only needs to be like 30-40ft/lbs on most macpherson strut setups. in fact, the little ones that hold the top hat to the car are usually tighter.
I use an air gun for assembly, mostly for speed (much faster, especially if you have to use spring compressors). All i do is re-assemble everything, get the top nut on the strut threads (strut standing on the ground), and then just hold the top hat and hit it with the airgun for a sec till i can't hold the top hat still with my hand (it'll want to twist out of your hand pretty quick once the nut hits bottom). That should be easily tight enuf. I guess the advantage to the air gun is that it will spin faster than the strut wants to. You could easily do this with a ratchet if you have a helper to hold the strut. Again, you only need like 40ft-lbs, its not much.
The advantage of doing it outside the car is that you can still easily see if the top hat/spring/strut perch are all still lined up straight after you crank on it, or if you need to loosen and re-align for any reason.
Its nice to do struts (non-inserts, like the subarus, anyway), since the whole job is only like 7 or 8 bolts/nuts per strut and that's it. And they're usually not rusted up badly. Probably once of the easiest things to do on a car, after changing oil. Heck, it probably takes me as long to do a set of struts as i would to do the alignment after.
Old 12-27-2009, 09:12 PM   #7
thrasher
Member#: 40579
2002 WRX Stage 2+
Default Need to clear up a few things here...
Originally Posted by neko View Post
^ its not that bad, since it only needs to be like 30-40ft/lbs on most macpherson strut setups. in fact, the little ones that hold the top hat to the car are usually tighter.)
No, the three smaller tophat bolts are 14 ft-lbs. Much tighter and they can easily be snapped off.
An air gun would be faster, BUT it is not recommended to be used with the adjustable struts like the DSpecs. The use of an impact wrench on these can damage the seals. I do have air tools but I purposely did not use them for tightening the top nut - I'm not about to blow $600 in struts because I'm too lazy to do it right. Some have said that the HarborFreight battery-powered impact tool works well for this because it doesn't have too much torque, but I just used hand tools, patience, and some advice from other NASIOCers who had done it before.
To the OP - check out this thread http://forums.nasioc.com/forums/show...ferrerid=40579
Old 12-27-2009, 11:44 PM   #8
superv
Member#: 212305
'03 WRX Sedan
thanks for the input. Looks like I need to get a spring compressor for the front struts since i'm doing this solo.... My car has 120k on her. What are your advice on changing the springs? I was planning on only replacing the d-spec and didn't think the springs would go bad. Opinions?
Old 12-28-2009, 01:11 AM   #9
viper74656
Member#: 84758
'04 WRB WRX
Your stock springs won't go bad but the D-Spec can handle a LOT stiffer spring than that. By keeping your stock springs on you're leaving a lot of performance potential on the table. If you don't want to throw a lot of money at it I'd consider picking up a set of used stock STI springs (and rear top hats) for cheap.
viper74656 is offline   Reply With Quote
Old 12-28-2009, 08:28 AM   #10
03SubyWRX
Member#: 200767
2007 OBS 5MT
Lifted
I used my battery powered Craftsmen impact gun on the lowest setting. I had no problems, and I checked the torque after installing them on the car. Amazingly, it was at 40 lbs/ft. Not bad for a Craftsman haha.
03SubyWRX is offline   Reply With Quote
Old 12-28-2009, 09:53 AM   #11
thrasher
Member#: 40579
2002 WRX Stage 2+
The original post says Prodrive Blues, so you will be fine with those as long as you like the ride characteristics. Still, as viper said, the DSpecs can handle much stiffer springs, so if you are looking to upgrade spring stiffness, now is the time. RCE and Swift make excellent springs that match the DSpecs performace very well.
Old 12-28-2009, 10:05 AM   #12
murrdogg24
Member#: 50586
04 WRX
Flappy bird edition
If you are disassembling your stock struts to reuse the bump stops I would recommend using a spring compressor. I didn't have much difficulty on the tophat nut used a torque wrench once it was on the car and tightened to 50ft/lbs.
murrdogg24 is offline   Reply With Quote
Old 12-29-2009, 12:01 AM   #13
superv
Member#: 212305
'03 WRX Sedan
I've managed with great difficulty to install the left rear strut today and it took me like 3 hours. Getting the 2x19mm bolts back in was a huge pain. OMG Any advice on making this easier doing it myself?
Old 12-29-2009, 05:30 AM   #14
Butt Dyno
Member#: 17301
is the "dark side"
You have the car on four jackstands, right?
Use a floor jack to move the hub assembly to the right height.
Old 12-29-2009, 09:11 AM   #15
superv
Member#: 212305
'03 WRX Sedan
hm only 2 (back ones)
Old 12-29-2009, 09:13 AM   #16
Butt Dyno
Member#: 17301
is the "dark side"
That should be fine... the important thing is that you are not doing this using a jack for each corner (that is not a good idea). That way your jack is free to use on the hub.
Just jack up the hub until the holes loosely match, then use a screwdriver or a punch to get the strut hole and the hub hole lined up correctly, and stuff the bolt in. Tap it lightly with a mallet of some kind if it doesn't slide in all the way.
IMHO it is easiest to do this if you remove the two 14mm bolts that hold the rear brake caliper on to the bracket, and then hang the caliper off of the swaybar or something (don't let it dangle by the brake line - use zip ties if you have to). That way you can get punch/hammer/torque wrench/etc in there without conflict.
Old 12-29-2009, 04:51 PM   #17
viper74656
Member#: 84758
'04 WRB WRX
^^^^+1 on this. I had a tough time getting those 19mm rear bolts in too but using a floor jack to move the hub up helped immensely.
Old 12-30-2009, 10:33 AM   #18
andyboi677
Member#: 179049
2005 Imperza Wrx
I installed all four oem sti springs in 1 1/2 hours. Went smoothly.
andyboi677 is offline   Reply With Quote
Old 12-30-2009, 10:38 AM   #19
thrasher
Member#: 40579
2002 WRX Stage 2+
How is this info helpful to the OP? The time spent to do a mod is pretty irrelevant because everyone works at a different pace, and there are several variables that can affect how long it takes to complete a project. Even though I have my own garage, air tools, jackstands, etc., I typically take longer to do stuff because I am very organized and thorough, and I like to keep my car and the workspace clean and clutter-free. Others end up with the same result but are able to work very quickly and do their clean-up after the fact.
Old 01-01-2010, 06:39 PM   #20
superv
Member#: 212305
'03 WRX Sedan
^i live at an apartment, so it's hard to get a clean space to do some of the work. I've only had a few hours at a time to do this. So far it's gone good. I've done the rear replacement. And i've added the rear adjustment which i'm liking a lot. Taking the seats out is more work than i like. http://forums.nasioc.com/forums/show....php?t=1102593
Also, I found a breaking bar + pb blaster to be good ideas to get the big 19mm bolts off. Unlike others, I haven't had problem with getting the strut bolt tightened once that assembly is in the wheel well. Weird, I was worried about that step a lot.
Next up i'll do the front.
Old 01-01-2010, 08:51 PM   #21
Butt Dyno
Member#: 17301
is the "dark side"
Hint for the rear seats:
Just leave them unbolted. They work fine that way
Old 01-01-2010, 09:56 PM   #22
superv
Member#: 212305
'03 WRX Sedan
speaking of which, I can't believe they're just pieces of foam. Guess i'm just naive
Old 02-13-2010, 11:25 PM   #23
superv
Member#: 212305
'03 WRX Sedan
This turnout out to be an important tip. Thanks
Has anyone had any probs with the new SPT intake on an 02/03 wrx? Nettalp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-02-2006 08:59 AM
Anyone have a 02-03 rear bumper and tails on a 02-03 WRX file_id Interior & Exterior Modification 7 11-28-2005 05:32 AM
Does the STi rear/side apron fit on a 02-03 WRX wagon? YinUCSD Interior & Exterior Modification 10 06-22-2005 10:26 AM
The Difference in Tailights on an 02-03 WRX Lux Texas Impreza Club Forum -- TXIC 20 03-11-2004 02:03 PM
GT Spec II or Gruppe-S Headers on their 02-03 WRX soundwave Bay Area Impreza Club Forum -- BAIC 2 11-11-2003 12:46 AM
