Old 12-28-2009, 01:04 PM   #1
Forged Performance
Member#: 227509
2015 Subaru STi
Galaxy Blue
Default Forged Performance - 07 STI Stroker Build
Forged Performance makes 407whp/404wtq on 93 octane @ 19.4 psi, 461whp/461wtq on E85 @ 22.4 psi on a GT35r
Event: Dyno Dynamics Dyno Pull
Car: 2007 Subaru STI
Tuner: Scott Siegel @ Forged Performance
Dyno Info: Dyno Dynamics
Peak Power: 407whp/404wtq on 93 octane @ 19.4 psi, 461whp/461wtq on E85 @ 22.4 psi
Fuel: 93 Octane and E85
Alright ... Here's the run down on this beast:
- Forged Performance 2.7L Stroker Motor
  • Billet Crank
  • Forged Pistons
  • Forged Rods
  • Race Bearings
  • ARP Hardware
  • Balanced & Blueprinted
- Race Prepped Heads
- Deatschwerks Injectors
- Cosworth Intake Manifold
- Koyo Radiator
- Moroso Oil Pan
- Carbonetic Triple Carbon Clutch
- UR GT35r Turbo Kit
- AEM EMS
Here's what it made on our Dyno Dynamics "Heart Breaker" dyno:
*Unfortunately, we ran out of fuel pump on the E85 tune and couldn't push the full potential. Round 2 E85 tune coming soon
Forged Performance is offline   Reply With Quote
Old 12-28-2009, 02:27 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Graph? Slip? At leat a video?
godforbid67 is offline   Reply With Quote
Old 12-28-2009, 02:37 PM   #3
siegelracing
Member#: 45173
1999 2.5 RS
White&Gold All-Suspension
Here's pump gas compared against another built motor that was recently on our dyno:
More plots and video coming
Siegel
siegelracing is offline   Reply With Quote
Old 12-29-2009, 04:48 PM   #4
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Retarded monkey says power is kinda low for that much of a built engine.
CoolRex is offline   Reply With Quote
Old 12-29-2009, 04:52 PM   #5
acssa
Member#: 184023
what oil pick up is that?
acssa is offline   Reply With Quote
Old 12-29-2009, 05:08 PM   #6
nrowensby
Member#: 222943
2000 Audi A4
Santorin Blue
Wow... That's kinda depressing...
nrowensby is offline   Reply With Quote
Old 12-29-2009, 05:14 PM   #7
siegelracing
Member#: 45173
1999 2.5 RS
That's the Moroso oil pickup.
Obviously I don't want to get into a dyno debate, and we will be taking this car to at least one of the local Dynojets as well as the strip, but by our best calculations (taken from other STi's that have dynoed at multiple places) our Dyno Dynamics 409whp is Dynojet 471whp on 93 with just 20.4 psi peak and 19.4 psi at peak whp. This is exactly what a build of this level SHOULD make. With the heads, cams, intake, header etc, 470whp is exactly right.
We had 2 Walboros in series and on E85 the fuel pressure is dropping at 25.0 psi peak, 22.4 psi at peak whp and what calculates to 530 wft-lbs and 530 whp (Dynojet). We thought the Walboros in series would be enough, but the Bosch engineer believes that using the stock hardline from in-tank to in-line Walboro is our major restriction. He thinks that at full bore, the pressure from in-tank to in-line could be dropping to near 0, so it acts more like a single Walboro. Again, it's not surprising to max a Walboro (or even a "Walboro and a half") at 530-550whp on E85... (It was 461/461 on our Dyno Dynamics).
Cliff notes: (best calculation to Dynojet whp)
93 octane 20.4 psi peak, 19.4 psi at peak whp 471whp
E85 maxed the pumps (losing 20psi of fuel pressure) at 530whp
Car will be tested on a Dynojet and at the strip once it's full complete.
Siegel
Old 12-29-2009, 05:18 PM   #8
nrowensby
Member#: 222943
2000 Audi A4
Santorin Blue
There is quite a difference in 409.3whp and 471whp...
I guess we will just have to wait to see what it does on a different dyno or on the strip... until then, 409.3whp seems quite depressing for the amount of work done...
Old 12-29-2009, 05:23 PM   #9
Forged Performance
Member#: 227509
2015 Subaru STi
Galaxy Blue
The dyno is just a tool ... The track would be the correct proving ground.
Old 12-29-2009, 05:24 PM   #10
nrowensby
Member#: 222943
2000 Audi A4
Santorin Blue
Interested to see if it runs with similarly dyno'd 400hp cars... or closer to 500hp cars...
Old 12-29-2009, 05:28 PM   #11
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Details of short block build?
blkscooby is offline   Reply With Quote
Old 12-29-2009, 05:33 PM   #12
Forged Performance
Member#: 227509
2015 Subaru STi
Galaxy Blue
- Billet Stroker Crank
- Forged Pistons
- Forged Rods
- Race Bearings
- ARP Hardware
- Suby AA360 Oil Pump
and all the machining, balancing and blueprinting that goes along with it
Old 12-29-2009, 05:40 PM   #13
siegelracing
Member#: 45173
1999 2.5 RS
Stock STi's generally make 200-210whp on this dyno and 24-250whp on most Dynojets. We've done 5 Stage2 STi's here in the last few weeks and they all made about 260whp here and 300whp on Dynojets.
It's really not hard... Different dynos read differently. If you search other kinds of cars you'll find that most people consider Dyno Dynamics to be 13-20% lower than Dynojets.
Siegel
Old 12-29-2009, 05:45 PM   #14
siegelracing
Member#: 45173
1999 2.5 RS
The owner of the car had the 35R on his stock block that made 380whp on 93 and 450whp on 110. He says that the car feels MUCH faster on the current 93 map (estimated 470 DJ whp) than it did on the old 110 map...
So while you might be disappointed at the number, the owner of the car is thrilled with the performance
Siegel
Old 12-29-2009, 05:46 PM   #15
siegelracing
Member#: 45173
1999 2.5 RS
I could walk back out the dyno, turn off the weather station, change the correction and make a plot that shows 470. Would that relieve your disappointment?
I could do that for you. You know, like a Christmas present
Siegel
Old 12-29-2009, 05:50 PM   #16
nrowensby
Member#: 222943
2000 Audi A4
Santorin Blue
That certainly couldn't have all gone in one post... I believe you though...
Old 12-29-2009, 05:55 PM   #17
siegelracing
Member#: 45173
1999 2.5 RS
Sorry. I kept posting, and then reading it and thinking of something else. It's always a hard call as to risk a ninja edit or just add another post...
And I'm in a good mood getting ready to take 5 days off
LOLOL! Just for grins I Googled "dyno dynamics dynojet" and one of the first posts was from HERE:
http://forums.nasioc.com/forums/showthread.php?t=286440
Siegel
Old 12-29-2009, 07:25 PM   #18
AVCSKIDD
Member#: 179372
Not what I was expecting
AVCSKIDD is offline   Reply With Quote
Old 12-29-2009, 07:26 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You're not paying any attention to the 20 psi.....
If my car made 400whp at 20psi on pump gas i'd be all
it takes me 26psi and methanol just to get to 375 whp.
Old 12-29-2009, 07:29 PM   #20
AVCSKIDD
Member#: 179372
I think what he was getting at is it doesn't look that much stronger than a typical 35r car with cams. its good power but its nothing crazy consider what all is done.
Old 12-29-2009, 07:41 PM   #21
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I agree with AVCSKIDD a typical 35R with built heads should make that kind of power at 20-21 psi on 93oct.
Look at this thread http://forums.nasioc.com/forums/show...light=topspeed
What is the AR on the turbo? spool seems slow to me
400-410whp on a low reading dyno is a 11.4-11.7 car if is full weight
Old 12-29-2009, 07:44 PM   #22
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Where's the tq curve?
Old 12-29-2009, 07:48 PM   #23
juanmedina
Member#: 133146
07 FPgreen 7.37@95
is the second one the one that is going down
Old 12-29-2009, 07:49 PM   #24
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Never mind....see now there is two charts.
Old 12-30-2009, 04:38 PM   #25
siegelracing
Member#: 45173
1999 2.5 RS
Typical 35r setups make 410-420 whp on a dynojet. They usually make about 360 on our dd. This made 410 on ours which is about 470 on a dynojet. 470 on 93 is STRONG.
Siegel
Forged Performance 370Z Race car build first track test...impressions Forged Performance NASIOC Project Cars 44 12-06-2010 11:12 PM
Fully Forged 2.2 liters stroker kit DJIMPREZA Private 'For Sale' Classifieds 35 02-11-2004 01:47 AM
Stroker build up help!! wrxtuner02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2003 06:14 PM
