Old 12-29-2009, 04:09 AM   #1
MAtwal
Member#: 125053
2004 Wrx Sedan
Default 04 wrx early production- Harmonic dampers?? anyone install these before??
Hi guys, so I have been on a hunt to find out why I get this vibrating,resonating, grumble from my rear end at above 60+mph.
I found this link on scoobymods that had this Subaru official bulliten posted. This bulliten would affect cars the were early production 2004 wrx models, manufactured before april 2004
http://imgur.com/yP3tt.jpg
http://imgur.com/7kXw9.jpg
Has anyone ever heard of these? Prices, how hard they are to install?
There is a piece they refer to as the "differential number" and im assuming a new one of these are needed as its in the parts list.
any info on this would be appriciated
MAtwal is offline   Reply With Quote
Old 12-29-2009, 08:09 AM   #2
GHK
Member#: 103886
2005 WRX
I have those, came stock from factory.
GHK is offline   Reply With Quote
Old 12-29-2009, 11:24 AM   #3
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I can take pictures of the 2002 rearend I have in my garage with those attached if that would help you out. Probably not until this weekend of next week though cause I'm out of town at the minute.
Old 12-29-2009, 03:39 PM   #4
MAtwal
Member#: 125053
2004 Wrx Sedan
kpluiten: Sweet dude, a pic would definately help, then I can check if I already have them, ill try to look without your pic too.
I made a big thread about this vibration/resonance noise I get when I travel above 60+mph. After doing some inspections I found that my 3' was close to rubbing against the axle where it exits the diff. So i am getting longer exhaust hangers to fix that issue but Im not sure that will fix the overall vibration issue since I found this Subaru bulliten
Is this something you got installed? cost? It refers to the part " differential member" what is that, and is a new one needed with the drilled holes?
GHK- Subaru implemented this fix for cars produced after April 2004 so ya you have them for sure. I have a early production wrx, probably produced back in 03.
thanks for the help guys
Old 12-31-2009, 05:23 PM   #5
MAtwal
Member#: 125053
2004 Wrx Sedan
anyone know the rough cost of these parts?
Old 12-31-2009, 06:16 PM   #6
kpluiten
Member#: 120273
06 WRBWRXWGN
No clue. You could probably get someone to sell them to you if you posted up a wanted add. I'd send them your way, but I'm going to be using this subframe in my garage.
Old 12-31-2009, 06:38 PM   #7
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
#18 & #19 ...
theotherguy is offline   Reply With Quote
Old 12-31-2009, 07:30 PM   #8
MAtwal
Member#: 125053
2004 Wrx Sedan
Default Same diff member
The part labelled differential member? Does that mean I need a whole new one or is this something that can be installed onto my existing differential member
kpluiten send me a pic of your 02 rear end when you get a chance. Thanks.
Old 12-31-2009, 08:11 PM   #9
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Shows 41310FE040 from '02, October — '03, October, '04, April — '05, May
41310FE050 from '03, November — '04, March, '04, January — '04, April.
Weird they'd do that.
Old 01-08-2010, 06:17 PM   #10
MAtwal
Member#: 125053
2004 Wrx Sedan
Default pricing in Vancouver bc
Ok so I went to the local subaru dealer today with the part numbers for the harmonic dampers. These are the prices at Don Docksteader in Vancouver BC
41310fe040 - rear diff member assembly - $213.08
41322ac050 - dynamic dampers - $106.52 qty=2
023508000 - lock bolts - $4.08 qty= 2
Grand Total = $362.53 and thats just for parts.
Seems like a little pricey of a fix and ive read posts where guys install these and the whole vibration/noise doesnt even go away
Old 01-09-2010, 01:29 PM   #11
DS1
Vendor
Member#: 111780
I have a dozen of these lying around, if you want them PM me
Dylan @ ds1
DS1 is offline   Reply With Quote
Hella Horns, has anyone installed these? PapiDarren Newbies & FAQs 45 06-04-2011 02:21 AM
WRX remote starter by Subaru - anyone installed? WRXFiles Canada Region Forum 39 03-06-2007 01:54 AM
Anyone installed these? STi metal x-member bush replacements jpmarotta Brakes, Steering & Suspension 11 02-02-2004 11:14 PM
04 wrx boost & A/F gauge install wkderf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-09-2003 01:26 PM
Anyone installed boostvalve before? kalasend Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-29-2001 10:15 PM
