Old 12-29-2009, 04:17 PM   #1
kotea
Member#: 230156
93 GC8 wrx
red
Have a Nice Day? EJ20G spark plugs
kotea is offline   Reply With Quote
Old 12-29-2009, 04:42 PM   #2
dr3w
Member#: 222318
1993 RHD GC8
What do you mean by "wont hold boost" ? if it means what it actually means as in your boost is dropping then your spark plugs have zero to do with that.
But for reference a stock ej20g should be running PFR6G's, but alot of people use the BKR6E's
dr3w is offline   Reply With Quote
Old 12-29-2009, 05:24 PM   #3
kotea
Member#: 230156
93 GC8 wrx
red
boost cuts out i am going to try this since i am pretty sure those arent the spark plugs i have in. will let you know! if its not the problem then i will let you know.
Old 12-29-2009, 05:32 PM   #4
dr3w
Member#: 222318
1993 RHD GC8
^ aw boost cutting out and boost wont hold are two different things. let us know.
Check your gap as well if its to big you'll blow your spark out.
Old 12-29-2009, 06:04 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
6's? I always use 7's in my boosted Subarus. I use 6's in my RS.
Old 12-29-2009, 06:35 PM   #6
curt
Member#: 165657
fast wagon, toyota
4x4, & a supermoto bike
arent the 7's just a colder spark? what benefits does one gain from that?
curt is offline   Reply With Quote
Old 12-29-2009, 06:42 PM   #7
dr3w
Member#: 222318
1993 RHD GC8
You should not be using 7's is a stock boosted subaru. You go colder as you increase hp. NGK's general rule of thumb is 1step colder for every increase of 75whp.
The EJ20G Shop Manual says to use pfr6g's, I'm sure i have that written under my hood somewhere aswell. I personally currently use bkr6e's ill be using 7's when i hit up the dyno to increase boost.
Old 12-29-2009, 06:43 PM   #8
dr3w
Member#: 222318
1993 RHD GC8
Nothing ^ see my post above.
Old 12-29-2009, 07:28 PM   #9
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
You go hotter as you increase hp. NGK's general rule of thumb is 1step colder for every increase of 75whp.
This looks very contradictory here, would you please clear it up?
and tell me which plugs I should be running in my stock EJ20G?
bl_easy is offline   Reply With Quote
Old 12-29-2009, 07:32 PM   #10
dr3w
Member#: 222318
1993 RHD GC8
^oops corrected my little cold/hot inverted error.
Like i mentioned above in a stock EJ20G use:
NGK PFR6G (Platinum Plugs) <-What EJ20G Shop manual recommends
or
NGK BKR6E (V Power Plugs) <- Cheaper & Easier to Find.
Old 12-30-2009, 10:46 AM   #11
sniper512
Member#: 189923
1993 JDM WRX
I have had good luck with both these plugs as long as gap is set between 0.028 and 0.031. I am running 550 injectors at 18psi with Rob's tune, TBE, Intake, and a couple other part. I was wondering about going to BKR7E's for a while. Not sure if it would make a diff though.
sniper512 is offline   Reply With Quote
Old 12-30-2009, 02:31 PM   #12
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
With the colder plugs, the engine is less prone to det running more boost. Regarding brands: NGK all the way, engine seems to run worse on any other brand.
Marnix is offline   Reply With Quote
Old 12-30-2009, 02:45 PM   #13
dr3w
Member#: 222318
1993 RHD GC8
at 18psi+ i would run 7's
Old 12-30-2009, 02:48 PM   #14
dr3w
Member#: 222318
1993 RHD GC8
Yep colder is generally better but to cold and you run into plug fouling issues. If you dont need a colder plug you dont use them. Like in matts case running 7's on a stock ej20g is a little much.
Old 12-30-2009, 02:57 PM   #15
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
FWIW, I'm running NGK 7s with .024 gap, 17psi, DW 650s on 93 octane.
beaviscih is offline   Reply With Quote
Old 12-30-2009, 03:45 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
If we had gas here that was equivalent in octane to what the cars were tuned for in Japan I would run 6's. I run 7's for greater knock resistance on our crap US gas. Cheap insurance in my book and I've never once had an issue with fouled plugs or any of the associated issues one can run into with going too cold on the plugs. 1 step colder isn't really all that much.
Old 12-30-2009, 07:25 PM   #17
sniper512
Member#: 189923
1993 JDM WRX
Well looks like I will have to try some out. Probably time to change them anyways. We have 94 here which doesn't seem to bad especially with the tune.
Old 12-30-2009, 10:19 PM   #18
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
I don't think it's necessary. The end result will be a drop in power and worse MPG IMHO.
rob is offline   Reply With Quote
Old 12-30-2009, 10:20 PM   #19
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Dang, why such a closed gap?
Old 12-30-2009, 11:37 PM   #20
beaviscih
Member#: 123362
'93 Crapcan, '98L
IIRC we started at 0.026 and had spark blow out at 15-16psi, so closed them a little and hit 17psi with no issues.
Old 12-31-2009, 01:27 AM   #21
dr3w
Member#: 222318
1993 RHD GC8
^ Ya i was wondering the same I'm currently running 16psi before i hit up the dyno and I'm running .028 gaps. Anything bigger and i was blowing out spark on old cracked coils, ill be doing the newer wrx coil swap before i drive my car again in the summer. The goal is to get the biggest gap possible without blowing it out.
Old 12-31-2009, 02:49 AM   #22
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Yowser. I am running around 0.031" @ 19psi with no spark issues (with the coil conversion of course )
Old 12-31-2009, 07:10 AM   #23
beaviscih
Member#: 123362
'93 Crapcan, '98L
Well that's a data point I omitted; I have not done the coil mod.
Old 12-31-2009, 08:46 AM   #24
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i run bkr7e @.28 in both my g and k
as matt says cheep insurance
Old 12-31-2009, 10:29 AM   #25
bl_easy
Member#: 91407
BRetty green
Is anyone running an R5671A-7 in their car?
Spark plug recommondations for Ej20G owners? scobaru Pre-2002 Factory Turbo Powertrain 8 09-19-2016 12:11 PM
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 710 09-01-2016 11:53 AM
factory Spark Plug compatibility EJ205 (02-05WRX) vs EJ20G (93-96WRX)??? Longitude Service & Maintenance 3 10-09-2008 10:02 PM
EJ20G Ver 2 Jdm sti 555...spark plugs? and other maintenance stuff.. tyrint13 Service & Maintenance 0 12-03-2007 09:39 PM
spark plug question for jdm EJ20G scobaru Subaru Conversions 3 03-09-2004 11:53 AM
