Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 12-29-2009, 06:32 PM   #1
Mush04
Member#: 191705
2007 Limited STi
Swp
Question Gas Smell?!?!?!
Hey I have been noticing a gas smell in my car for the past couple of days, anyone ever have anything like this and know what it could be from?
I put in a Walbro 255 a week ago or so, but that shouldn't have any issues but then again I don't know for sure.
Any help is appreciated! Thanks in advanced!
Mush04 is offline   Reply With Quote
Old 12-29-2009, 06:38 PM   #2
Lil' Biggie
Member#: 93992
'06 EVO MR,
'89 240SX, '07 Yaris
Welcome to owning a WRX when it gets really cold.
Lil' Biggie is offline   Reply With Quote
Old 12-29-2009, 07:03 PM   #3
KevinK
Member#: 231813
Candy Red Mettalic
what is ur fuel pressure set at. you should be at 2.5-2.7 depends on how strong ur kung fu is. what size injectors?
KevinK is offline   Reply With Quote
Old 12-29-2009, 07:22 PM   #4
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
wouldnt worry about it. very common
801_STi is offline   Reply With Quote
Old 12-29-2009, 07:27 PM   #5
Mush04
Member#: 191705
2007 Limited STi
Swp
just the stock injectors at the moment. and I don't know what my pressure is set at right now.
yeah I think someone told me that it is fairly common for the to smell like that, but I don't believe I smelled it last year and it seemed like it was too strong to be normal.
I'm sure it is just wanted to make sure, thanks guys!!
Old 12-29-2009, 07:49 PM   #6
SkiWrex
Member#: 142559
05 Fozz XT VF39'd
04 Broyota 4runner
When I installed a Walbro 255, I had the same problem. It was from that main floor panel gasket getting damaged, might wanna check that.
SkiWrex is offline   Reply With Quote
Old 12-29-2009, 07:54 PM   #7
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
the fuel smell is coming from a hose connection underneath the manifold. SOA has recalled this part for many of the "cold" states and the dealer should replace the part under warranty. I had mine replaced several years ago and I just started smelling it again.
I should add that the warranty goes beyond the 36,000 mile warranty... I think its 100,000 miles or something like that
02blueru is offline   Reply With Quote
Old 12-30-2009, 12:04 AM   #8
subiewrx001
Member#: 193591
04 WRX VF34
water/meth, spt intake
yeah my 04 is doing the same thing, it smells when it is cold but once the engine warms up it goes away at least on mine, if it stays then it may be the little o-ring on the #3 injector.
subiewrx001 is offline   Reply With Quote
Old 12-30-2009, 12:12 AM   #9
Jncominco2
Member#: 170212
some of this is true, some of it is not.
the smell is probably as he described. a fuel line/hose that runs under the intake manifold is known to go bad and crack/leak when its cold out.
as far as the recall, its not. its a service bulletin. i had to buy the parts and replace it myself (well i could have paid someone to do it, but meh) but im just saying it is not covered under a recall/warranty. at least not any more
Jncominco2 is offline   Reply With Quote
Old 12-30-2009, 12:23 AM   #10
02blueru
Member#: 80012
04 BMW M3
I stand corrected
Old 12-30-2009, 12:24 AM   #11
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i fixed my fuel leak under the intake manifold last month. i got 3 full turns out of the screws on the clamps
pumpkyn is offline   Reply With Quote
Old 12-30-2009, 03:49 PM   #12
aclver1
Member#: 114177
2004 Impreza 2.5rs
70 Datsun Fairlady
Yeah, check your hoses. My friend that bought my legacy just fixed his the other day and he said it was dripping the crack was so bad. I would hate to see your car go up in flames.
aclver1 is offline   Reply With Quote
Old 12-30-2009, 03:52 PM   #13
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i smelt it last and year and was whatever, but this winter it was worse so i had to do it.
Old 12-30-2009, 04:00 PM   #14
02blueru
Member#: 80012
04 BMW M3
did you have to remove the manifold to tighten up the screws or are they accessible without?
Old 12-30-2009, 04:06 PM   #15
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i took the manifold off, you can get to one clamp but i tightened all hoses that were down there
Old 12-30-2009, 04:13 PM   #16
Mush04
Member#: 191705
2007 Limited STi
Swp
ok cool well I wont waste my time with the dealership then! Thanks
Yeah I really don't want to see it go up in flames!! hopefully I can find the right hoses there are a bunch of black little hoses under there. It smells pretty bad at times and other times it's not so bad, so hopefully it's not dripping like you friends, that would suck, but be easy to find. haha
I though my gas was going quicker than it usually does!
Old 12-30-2009, 04:14 PM   #17
Mush04
Member#: 191705
2007 Limited STi
Swp
this is a total noob question but will I have to replace any gaskets if I take the manifold off and is it a huge pain to take it off if I do need to?
Old 12-30-2009, 04:15 PM   #18
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
trust me it drips. you dont NEED to replace the hoses you can just tighten the clamps. but if you want to replace the hosing, go for it
Old 12-30-2009, 04:17 PM   #19
pumpkyn
Member#: 156347
1997 Milano EK
2004 Platinum Wrex
i didnt and im fine, most people dont.
i followed this guide to take out the manifold. just skip the TGV part
http://www.omods.com/index.php/mods_..._install_guide
Old 12-30-2009, 04:18 PM   #20
Mush04
Member#: 191705
2007 Limited STi
Swp
Oh ok cool thanks man!!
Old 12-30-2009, 05:18 PM   #21
Jncominco2
Member#: 170212
i replaced my gaskets....but then again i have a lot more miles on my car
i just hate re-using gaskets, no matter what it is
and yes, you have to take off the manifold
Old 12-30-2009, 05:24 PM   #22
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Replace the gaskets. Its not expensive and youll regret it if you have to do all the work over again. Alot of the time you can remove the AC compressor to get to the clamp on the fuel line. Otherwise take off the intake manifold. (Take off the TGVs at the same time that way the fuel rails etc will come up at the same time and make your life alot easier.
Like so
bhhamblin is offline   Reply With Quote
Old 12-30-2009, 05:46 PM   #23
Mush04
Member#: 191705
2007 Limited STi
Swp
ooooooo the ac compressor might be an easier way to tighten them, I'll try that, I don't have enough time these days to pull off the whole manifold haha.
Old 12-30-2009, 06:19 PM   #24
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
sometimes the clamps are flipped the other way. but however you do it, good luck.
Old 12-30-2009, 07:21 PM   #25
Mush04
Member#: 191705
2007 Limited STi
Swp
yeah hopefully they are not flipped then haha. Thanks man!!
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 07:14 PM
2 newbie questions, Occasional gas smell and gas pipe wattpuppy Newbies & FAQs 0 10-31-2006 01:01 PM
gas smell TSB- repaired and still smelling it! SVX WRX Warranty Issues & SOA Problems 5 04-13-2004 07:33 PM
gas smell? tonic Newbies & FAQs 4 04-11-2001 10:53 AM
Exhaust gas smell in car... WRC666 General Forum Archive 5 03-03-2001 12:47 AM
