Old 12-30-2009, 08:26 AM   #1
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
Default 02 WRX hood won't close .. :(
yesterday someone needed a jump start at work and after they drove away my hood wouldn't properly latch .. not sure if its the spring and latch not working or it just needs adjustment.
is it safe to drive with the hood just latched on that first catch that it makes? last night i rigged up some bungies and drove painfully slow. dreading the drive in today.
the maintenance manual doesn't really go too in depth on the latch or properly adjusting it .. any insights? its freezing out and i hate working in the cold (i have no garage)
never had a problem before.
ronaldwrx is offline   Reply With Quote
Old 12-30-2009, 08:42 AM   #2
rkramer
Member#: 118209
2015 WRX Limitec
If it worked before and you haven't had body work done, it isn't an adjustment issue. My bet would be that you have some ice jamming up the mechanism.
Old 12-30-2009, 09:09 AM   #3
bluesubie
Member#: 767
04 FXT
It happens to me sometimes and I just spray some WD40 in there.
-Dennis
Old 12-30-2009, 10:42 AM   #4
Bfazona
Member#: 223605
If you haven't had any accident damage, then you could try two things: Spray WD40 into the latching mechanism like bluesubie suggested, and you can get to it from the top and front of the car. Also, you could try adjusting your rubber stoppers on each side of the car. They just screw in by hand.
Bfazona is offline   Reply With Quote
Old 12-30-2009, 02:37 PM   #5
ronaldwrx
Member#: 23570
2002 Impreza WRX
Sedona Red Pearl
i sprayed some pb on the spring mechanism this morning and a few hood slams later it caught .. thanks for the help! i will check out the rubber stoppers after work ..
Old 12-30-2009, 02:39 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
unbolt the latch from the car after marking its position, turn it gently so you can see the back side of hte latch. You will see a litte metal hook that the ball on the cable pulls on, this hook pivots, whet gets gunked up it sticks making the hood unable to latch.
clean it out an lube it up, its pretty easy to see how it works.
Old 12-30-2009, 03:11 PM   #7
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
i used pb blast an a toothbrush to get some of the grime off the mechanism
666stars is offline   Reply With Quote
Old 12-30-2009, 03:20 PM   #8
NiFFa
Member#: 151393
2011 STi hatch
I had the same problem, it turned out to be the actual wire that holds the latch open.. i just re-adjusted it into the beam above the radiator.. and it stayed closed for me. just trying to help.
NiFFa is offline   Reply With Quote
Old 01-04-2010, 12:56 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
This is a wild guess, but I didn't realize it until one accidentally fell off one day.
On either end of the engine bay above the head lights, there are 2 rubber cylindrical pads that you can rotate to adjust the height/ standoff of the hood when it closes. See if it is that, or corrosion in your hood release wire.
strohausii is offline   Reply With Quote
Old 01-28-2010, 08:47 AM   #10
kubuli-wrx
Member#: 143773
2004 WRX
Yup had the same problem this morning.... Dam upstate NY winters. Some wD40 and i few hood slams did it.
Thanks
Dre
kubuli-wrx is offline   Reply With Quote
Old 01-22-2011, 11:28 PM   #11
Steph_bmx
Member#: 270027
I had the same problem on mine today (been really cold in Minneapolis 3F). I tried the W40 and let it sit for a bit and then was able to shut the hood.
Steph_bmx is offline   Reply With Quote
my hood won't close? kooklie Newbies & FAQs 4 07-20-2009 10:13 PM
Dammit. My hood won't close. Snoopy Off-Topic 15 02-19-2007 10:19 AM
Hood won't close all the way? HAL1 General Community 15 12-15-2005 01:22 AM
my hood won't close ychan Service & Maintenance 11 02-18-2003 08:47 AM
