Old 12-30-2009, 03:17 PM   #1
Flyin_Hayn
Member#: 175031
2005 PSM STi
Stage2 303awhp / 331awtq
Exclamation possible piston slap or knock at cold start??
I live ine salem oregon I noticed on very cold mornings my engine is slightly louder than usual during a cold start up/first start up of the day.
I can hear a slight VERY SLIGHT tapping or "knock" I guess you could say near the 2500-3000rpm range. Than its unoticable before the car is even fully warmed up.
First question,
Can this be an early sympton of a spun rod bearing or some sort of rod knock?
Next I have noticed my engine is burning oil faster than I would like it to. In my opinion it shouldn't burn any, but I'm losing 3/4 a qt per 1000miles to my rough calculations. I'm leaning towards my valves or piston rings the culprit behind this.
Second question,
Could friction within the engine block itself burn oil?
Other than all this car runs great! Just got oil changed aswell as MTF changed.
Check out my profile for list of mods if that information is any use to you.
Car has 90k on it.
Thanks for lookin all
Happy new year
Flyin_Hayn is offline   Reply With Quote
Old 12-30-2009, 06:48 PM   #2
oguitar
Member#: 206720
2002 WRX Wagon
It is normal for your car to make lots of noise during a cold start up. It is also normal for your car to burn a little bit of oil. You are probably ok. You might want to change the type of oil though.
oguitar is offline   Reply With Quote
Old 12-31-2009, 01:27 AM   #3
Flyin_Hayn
Member#: 175031
2005 PSM STi
Well is it normal being two and a half qaurts low at 3.5k?? I've never been low on oil at any point ever with any other car I've owned.. (I know I should have changed it at 3 but didn't get around to it and squeezed one more trip in.)
And if so, I should be checking my oil regularly and keeping it in operating range? (Annoying)
Old 12-31-2009, 01:28 AM   #4
Flyin_Hayn
Member#: 175031
2005 PSM STi
Old 12-31-2009, 10:09 AM   #5
danbbb
Member#: 219748
From what I've found, these things do burn a lot of oil. I guess it makes sense when you pressurize the cylinders so much with the forced induction. I have to check my oil at least once between oil changes and add a little. (I have also heard that if you don't boost much you won't have as much trouble)
-Dan
danbbb is offline   Reply With Quote
Old 12-31-2009, 12:26 PM   #6
DragginFrame
Member#: 188641
2005 OBP WRX, 03 EP3
Juiced 93 Ranger
Two and a half quarts in 3500 miles seems like a lot to me. I normally go through about a quart between changes (German Castrol changed every 3K).....With these cars, you have to be especially diligent with checking your oil, I check mine at least once a week.
Edit: I see you're running Royal Purple, from what I've seen on the forums here our cars eat RP and Mobil One like no other oil. Try out some German Castrol next time you change your oil and see how your oil consumption goes.....
DragginFrame is offline   Reply With Quote
Old 12-31-2009, 12:39 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
The max "normal" rate of consumption is 1qt per 1k miles. You should be checking the oil at every other gas stop, and topping it up as needed.
Just so you know, burning oil won't kill your car, but taking turns and hitting the brakes (pickup starvation) while 2.5qts low will.
CKxx is offline   Reply With Quote
Old 12-31-2009, 01:01 PM   #8
Flyin_Hayn
Member#: 175031
2005 PSM STi
Thanks guys. I've got another 5 qt of RP for next oil change, ill definetly try something else and see how that goes when that's been all burned up =O.
Also I did. Boost it hella last 3k lol....
Old 12-31-2009, 01:03 PM   #9
spinningcain
Member#: 176490
2005 STI
I dont use a drop between changes (3000) miles. The motor is new 15000 miles on it. I run rottela full syn. In my opinion ya its normal for a high milage engine.. Just keep it full you will be ok. What kind of oil do you run?
spinningcain is offline   Reply With Quote
Old 12-31-2009, 01:20 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
and we wonder why so many of these get blowed sky high.....
just keep drinking the kool-aid
Old 12-31-2009, 01:33 PM   #11
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
coul dbe the timing belt tensioner
robbieshonda is offline   Reply With Quote
Old 12-31-2009, 02:42 PM   #12
timmah
Member#: 54203
2011 WRX
I'd say your usage is a bit high, but may have to do with the oil your using. I was using more when using Mobil 1, for sure. I think I use about 3/4 of a quart every 5k on Rotella 5w40. my car has 105k on the clock.
timmah is offline   Reply With Quote
Old 12-31-2009, 02:48 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Try making a switch to German castrol which is only sold at Autozone. My car used to lose a lot of oil (>1 qt every 3k miles) when using Mobil1, but since switching to GC oil loss has pretty much stopped. Oil level is still very close to "F" mark after 3k miles. My oil catch can is also empty (has filter inside).
That obnoxious noise is normal on our cars. If noise goes away, I wouldn't really worry about it. MAKE SURE TO CHECK OIL LEVEL FREQUENTLY!
Old 12-31-2009, 04:57 PM   #14
Flyin_Hayn
Member#: 175031
2005 PSM STi
Thanks guys ill try some high milage oil...
Almost a whole qt of oil per 1k is a *****ing joke to me, personally. I wanna get an engine stand and pull my valves out.
Anyone live in oregon?? Haha
Knock at cold start shm777 Normally Aspirated Powertrain 13 03-19-2005 06:41 PM
Piston Slap vs Knock. OIL ? hernan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-20-2004 08:08 PM
piston slap rod knock...engine overhaul baby_rs Bay Area Impreza Club Forum -- BAIC 3 12-25-2003 12:16 AM
switched to synthetic oil...now at cold start engine knocking... wrxxtc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-11-2002 03:08 PM
WRX cold start noises...normal, piston slap, or detonation? Xio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-04-2001 08:12 PM
