Old 12-30-2009, 04:29 PM   #1
raWRXce
Member#: 203763
2003 WRX
Default ordering a JDM 2.0l from japan. good or bad idea?
have an 03 wrx thats down for the count because of a spun rod bearing. the local subaru shop and i have decided to order a 2.0l sti engine that is used and imported from japan. works for me because ill have more power and have plenty of spare parts to sell. the shop has done this twice before with great success. i suppose im wondering if you guys think this is a good idea or not, or if any of you have done this with success. i have a fidanza 4.3 clutch and a lot of aftermarket parts to accomodate this engine already so there is no need to urge me to buy stronger parts.
raWRXce is offline   Reply With Quote
Old 12-30-2009, 04:32 PM   #2
NFJ79
Member#: 90750
2000 RS EJ207 Hybrid
2006 BMW K1200S
If its a EJ207 I'd go for it.
NFJ79 is offline   Reply With Quote
Old 12-30-2009, 10:27 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
you should ask them what year and engine code...
If i can look at the motor, i'll know what it is.
FuJi K is offline   Reply With Quote
Old 12-30-2009, 11:05 PM   #4
Overboosting04
Member#: 202417
Wrx Stock EJ207
[email protected]
im in the same boat as you, im saving up for the engine and tranny. find out if its a version 7/8 ect...and Id also have them do a compression test in front of you with the engine.
Overboosting04 is offline   Reply With Quote
Old 12-31-2009, 12:58 AM   #5
redrexmeister
Member#: 111692
04 wrx wagon
I'm curious if the shop guarantees that that the engine they intend to import from Japan for your is in good condition? do they offer any kind of warranty that the engine they will put in is prolem free?
redrexmeister is offline   Reply With Quote
Old 12-31-2009, 06:41 AM   #6
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Any engine is just about better than yours.
I"m not familiar with emissions, or which engine your getting, but any JDM STI engine will be an upgrade.
It just depends if it works. That is the Million dollar question.
Think warranty and think about it A LOT!!!!!!!! Don't be a tool. ie. tools get used.
2cents.
DHRDAN is offline   Reply With Quote
Old 12-31-2009, 07:41 AM   #7
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
i recently did a jdm V7 in my 05 cause i also spun a bearing. I found a broken hose hooked up to the boost solenoid, my turbo inlet was completely torn and coil packs and sparkplugs where not torqued at all. So it's a great investment the V7 but make sure they go over everything and i mean everything before installing it. Are you doing the tranny too? I didn't but i am aware our 5spd won't last long at all....who is doing your install
gingertooth is offline   Reply With Quote
Old 12-31-2009, 08:49 AM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not every "STI" engine is an upgrade and there are roughly 12 years worth of production that won't be compatible
and i wouldn't work with a shop that didn't know this
Old 01-01-2010, 05:55 PM   #9
nottofast
Member#: 89663
1962 Fuji 350
cerelean blue
Who is "the shop"? As everyone asks about the warranty it is quite a gamble. Is the exporter backing the reliablity of the engine or is "the shop"? Just have evrything in writing about who is responsible IF THIS......................................... goes wrong.
Nobody really can give a good history on an engine because, how can you tell if someone beat the hell out of it or drove it nottofast?
nottofast is offline   Reply With Quote
Old 01-05-2010, 05:33 AM   #10
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
JSpecAuto just moved to Asheville, VA. from Quebec. I just picked up a V.8 EJ207 from them a couple days ago. they have a 60 day warranty. when i was there, i picked from 2 version 8's. mine had a defi boost controller and an aftermarket o2 sensor. probably a wideband. the other one had a grounding kit on it and a block-off plate on the recirc hose for the stock bpv, so it had a front mount. they were both clean and looked like pretty low mileage. the wiring harnesses were pretty hacked up though. and they didn't have the intercoolers either. but they did have all the rest of the accessories and VF-37's. I pulled the plugs on mine, and they were perfect. didn't check the plugs on the other engine. both of them turned pretty freely with a ratchet on the crank. since the plugs were so clean, i didn't bother looking inside the iacv for blowby clues. that's about the extent of what i can tell you about the other engine they had there. they might not even have it anymore - i think i picked up mine on the 30th. but give them a call. they were easy to deal with, and the two 207's there were pretty clean.
lil'redwagon is online now   Reply With Quote
Old 01-05-2010, 09:54 AM   #11
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
we lost the OP...... lolz
Old 01-05-2010, 11:00 AM   #12
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I have an EJ207 with 17k on it for sale near NYC. You can do any tests you want to it before picking it up if you're interested.
I definately would go with an EJ207, but don't know if I'd bother sourcing it from Japan. Shipping is killer and there are some already in the states for probably $4500-$5000. I'm selling mine pretty cheap if you're interested, full longblock.
garface is offline   Reply With Quote
Old 01-07-2010, 08:55 PM   #13
RS99
Member#: 215671
99 subaru rs
black
engine anything can happen in the shipping never know what you get until you see and or test it
RS99 is offline   Reply With Quote
Old 01-08-2010, 03:15 PM   #14
shultz2
Member#: 213772
2013 BRZ
debatable. i guess that depends if im going to buy your old engine or not to help source the funds to do this.....lol
shultz2 is offline   Reply With Quote
Old 01-08-2010, 11:26 PM   #15
Munashe Nhubu
Member#: 211521
91 VW GTi
Red
That is a very great motor, high rpm. But might have a bit of a lag
Munashe Nhubu is offline   Reply With Quote
Old 01-09-2010, 09:35 PM   #16
raWRXce
Member#: 203763
2003 WRX
hey guys, sorry that i have been missing in action. im for sure going to get a ver 7 or 8 ej207and will have a complete leak down test when recieved. i do understand that there is a risk involved and i am exersicing every possibly option and warraty thats available. and rest assured i will go over all piping and electics and make necessary repairs. i assume coilpacks and similar parts are interchangable? then ill just simply transfer over my aftermarket goodies and have a lot of spare parts to sell and or give-away to those who are in the same predicament as me or looking to upgrade. no sense in keeping two vf-30s around unless god forbid something else should happen
Old 01-09-2010, 09:42 PM   #17
raWRXce
Member#: 203763
2003 WRX
and yes, not only will you buy all my parts above what theyre worth, but you will tow my car around until its fixed. and maybe ill buy your lunch to repay you.
Old 01-09-2010, 09:49 PM   #18
raWRXce
Member#: 203763
2003 WRX
after reading over some more posts. a local shop that does primarily subaru cars will be working under the hood of my car. they have also done a swap like this before, twice. i will not be getting the 6 speed along with it because i dont currently have the funds for all that. parts i will be replacing right off the bat are as follows:
clutch
air intake
turbo inlet pipe
down pipe
up pipe
intercooler
blow off valve
and possibly:
injectors (i have a set of sti pinks already)
turbo (with the vf30 i currently have)
good or bad idea for stage 2 SkimSTI AccessPort 13 02-27-2007 02:38 PM
G-Force KDW 2 Good or Bad idea? 417WRX Tire & Wheel 8 06-25-2005 10:43 PM
New clutch? Good or bad idea? GregUnd Texas Impreza Club Forum -- TXIC 13 12-19-2001 10:48 AM
Planning to change lotsa fluids, good or bad idea? Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-27-2001 01:51 PM
FMIC: Good or Bad Idea Byrner13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-29-2001 07:51 AM
