Old 12-31-2009, 02:54 PM   #1
AkumaMotorsports
Member#: 214570
Default AKUMA Tuned/Owned-2008 STI
Event: dyno pull
Ambient Temp: unk, around 36F
Elevation: sea level
Weather: sunny, cold
Car: 2008 Subaru STI
Tuner: [email protected]
Dyno Info: Mustang AWD 500
Peak HP at RPM: 447whp uncorrected
Peak Torque at RPM: 431wtq uncorrected
Baseline hp/tq for a stock on same dyno: approx210
Target Boost: 24.2
Target AFR: 11.6
Fuel: 93 octane/Methanol-HFS-6
MODS:
ENGINE MANAGEMENT:
Cosworth/Pectel ECU: AKUMA Tuned
5BAR MAP AEM
Bosch Wideband
ENGINE:
Cosworth Shortblock-Forged Pistons/Rods/Crank
Cosworth bearings-Main/Rod
Cosworth Hi-Volume Oil Pump
Cosworth Intake Manifold
Cosworth Head gasket and ARP Headstuds
AKUMA ported TGV Housings
AKUMA 5 AXIS CNC Heads
Supertech Valves/Springs/Titanium retainers and seats
9mm Phenolic spacers
Mishimoto Radiator and Low Temp Thermostat
Killer B Pick up tube
Killer B Hi Volume Oil Pan
AKUMA Oil Cooler and Mocal thermostatically controlled sandwich plate
AKUMA Air/Oil Separator
FORCED INDUCTION / EXHAUST:
Forced Performance 3082 Turbo(GT35R comp/ GT30 turbine)
Tial V Band Turbine housing
-8AN Oil and Coolant lines- Flex Lite
AKUMA Custom FMIC(Spearco Core) and piping....reduced 90deg bends for superior flow and spool
AKUMA Cold air intake
Synapse 50mm Wastegate with Nitride piston
AKUMA Up-pipe and External Dump
APS Split pulse Header
AKUMA Dual Exhaust(quad tips)-prototype
SUSPENSION:
KW variant 3 Clubsport Coilovers-RobiSpec alignment and corner balanced
Cusco Front Camber Plates
Whiteline Steering Rack Bushing
Whiteline Anti lift kit
Whiteline Toe ADj ARMS Front
Cusco Front brace X
Cusco Rear Trailing arms
Cobb front sway bar
Cobb 3 piece rear sway
TRANSMISSION:
Cobb front and rear shifter bushings
Cobb Short shifter
Robispec CarbonFiber Driveshaft
BRAKES
AXIS Ultimate pads-fr/r
Stoptech braided lines
ATE Superblue fluid
EXTERIOR/INTERIOR
Red tail overlays
Prova Steering Wheel-Alcanter:retains stock radio controls and airbag
FUEL and EXTRAS:
DW1000cc Injectors
Aeromotive FPR
Perrin Rails with 6AN Braided lines
Full Blown DUAL Walbro In-tank Hanger(Billet Aluminum) -6 AN lines
AQUAMIST HFS6 AKUMA Spec Methanol Injection kit
HKS EVC 6 and Easy Writer Software
The first plot is a comparison to an STI with a Cobb OTS map, Stg 2. I wanted to put this up for a comparison that people can be familiar with, both on the dyno and actually driving the car.
The second plot is to demonstrate the difference AVCS tuning cam make on the Intake cam. One plot as the cam in a neutral position(131deg) and the second has a deviation of approx. 21deg from centerline. The spool is quite better and the difference in torque and power is astounding. This is actually 3 pulls after the change. My AFR were so lean on the first pull I had to stop the run. the send pull was better, and this is the third.
The tune is not complete. I wanted to get this started to show the progression in the tune with this new motor and ECU. The Pectel unit is the best ECU I have used to date. This unit is phenomenal. As a tuner, I have complete control over the vehicle and calibration, which is key.
I will keep this updated, as I will have her back on the dyno next week to tune the exhaust Cam and play with a bit more boost.
Here are some pics of the car....I know it is a bit dirty. LOL
I have a bunch more build pics. as soon s I get them from the other camera I will upload them.
Thanks for looking, and Happy New Year!
John
AkumaMotorsports is offline   Reply With Quote
Old 12-31-2009, 03:07 PM   #2
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
very nice guys, sure are whipping out alot of cars recently
KB'izzle is offline   Reply With Quote
Old 12-31-2009, 03:18 PM   #3
CVR STi
Member#: 127428
Looks good! Hows IAN aka kiwi doing ?
CVR STi is offline   Reply With Quote
Old 12-31-2009, 03:37 PM   #4
CatfaceType-R
Member#: 81102
nice engine and fmic piping
CatfaceType-R is offline   Reply With Quote
Old 12-31-2009, 04:12 PM   #5
Dom Terreto
Member#: 180034
Anyone that's been to the shop knows that this project has been long and laborious but it is being tied up in excellent fashion! John did the majority of the work himself and if you know him, you know how particular he is... Especially with his vehicle.
That being said, even seeing the project step by step.. The results are extremely impressive. This is a rotated turbo that is spooling as fast as a bolt on and making loads of power. If you have seen any other of our recent threads then you know what a heartbreaker we have, and what the numbers this car achieved really mean. As John stated, he will be pushing it farther soon, and hasn't even begun revving it out to where he can.
I think this car has been an excellent example of how matching the proper parts, allowing the right flow, and doing things the right way can pay off. I don't think anyone can argue that what you're looking for is the spool of a bolt on, but the power of a rotated. Well here it is! Congrats John... See you tomorrow lol.
Evan
Dom Terreto is offline   Reply With Quote
Old 12-31-2009, 05:05 PM   #6
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Nice mod list....too bad about the brake pads.
I hope you don't plan on road racing it.
mapleleaf is offline   Reply With Quote
Old 12-31-2009, 05:38 PM   #7
fourmicah
Member#: 128760
2015 STI
Nice set up! That seems like amazing power for your dyno. I'm sure that thing pulls like a freight train. I've heard that a hybrid turbo like this is the best way to go for Subies. I'm very interested in the turbo and how it works out for you.
The only question I have, is there a reason why you decided to run the intercooler piping directly over the turbo? It seems like most people are working on avoiding that these days. I notice that the Cosworth Intake doesn't leave much room for running something like that underneath it like the stock unit, is that the reason?
fourmicah is offline   Reply With Quote
Old 12-31-2009, 09:48 PM   #8
pisymbol
Member#: 174448
Interesting, does Akuma sell the ECPro? I didn't think anyone in NJ do ECPro.
Nice power gains. I am probably going with the ECPro for the New Year myself.
pisymbol is offline   Reply With Quote
Old 01-01-2010, 01:12 PM   #9
AkumaMotorsports
Member#: 214570
Yes we can sell you the EC Pro should you want one. I would caution you, that you will have to have some understanding of how to identify and fix small issues. I firmly believe anyone who is purchasing a stand alone ECU, should have some basic understanding of EFI calibration principles. If we sell this unit to a customer, I will personally train the person on the unit. This will be included in the price.
As far as the pads, they are not off the shelf Axxis pads. They work very well on the track, promise. I will be getting the Ferrodo 2.1 for the track though with new rotors for next season.
I designed the intercooler this way deliberately. I have many different set ups, from reversed manifold, counter clockwise/clockwise flow, under the mani, over the mani. I know I am going to get some resistance to this statement, but it is tested. They shorter piping makes no difference in performance.
The key to a proper intercooler set up rests on two main points, IMO. 1. The inner Diameter of the piping and the number of 90 or greater than 90 degree bends. Shorter piping will add the benefit of less weight, but it is negligible.
On the first point, it is critical to mate your turbo, piping ID, and core dimensions correctly.(I am not going into displacement/header set up). Many people go for the biggest core and piping. Not the best choice. As far as cores go it is all about efficiency, fin density is king here. You all may remember the Surface area to Volume Ratio idea.... here it is. You want to keep the piping smaller on the hot side of the core to keep up velocity, and larger on the cold side to allow for flow/expansion...you get the idea. The piping is far enough above the turbo that heat is no issue. The meth jet placement also assists in cooling.
The second point is easy to visualize. Picture running down a hallway. Which can you run down faster a straight one 20 feet long or one with 4 90deg turns 15 feet long? This is an over simplified concept, but I think it get the point across. The idea was to keep the path of flow as straight as possible. The extra foot or two make no difference at this level of flow. If we made the kit correctly, piping diameter and core choice, then the kit would exhibit proper flow and cooling properties without sacrificing performance. This is the case for the current iteration of the kit.
The FMIC is our prototype. It will be put into production very soon. We just put our GTR Intake out. As soon as they are done, we will start on this. I am just debating on weather to keep this core(works awesome, but you have to trim the bumper beam and bumper) or go with a taller core that requires no cutting. Keep in mind, a proper FMIC is not going to fix a poorly set up header/up pipe combo. The vehicle needs to be set up correctly to realize the full potential of any turbo set up.
Sorry for the long post. Happy New Year!!
John
Old 01-01-2010, 01:33 PM   #10
IMPORTEDCARS
Member#: 56945
08 STI Base Model
John
Great work! See you soon -)
-George Kakaletris
IMPORTEDCARS is offline   Reply With Quote
Old 01-01-2010, 01:43 PM   #11
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Very nice numbers John. Must be a blast to drive!
Any plans on coming to UT again? My wrx could use a touch up and my sti will need a tune once the new motor is installed.
bhhamblin is offline   Reply With Quote
Old 01-01-2010, 02:28 PM   #12
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Pardon my ignorance but what is "not off the shelf" about Ultimates.....
Are they making a proprietary race compound I'm not aware of?
I'm curious why you are going with the 2.1's versus the 1.1's? Is this car going to be doing Time Attack duty?
Old 01-02-2010, 08:19 PM   #13
whitestar
Member#: 130454
2006 STI
Hey John, are you still on the stock clutch?
whitestar is offline   Reply With Quote
Old 01-02-2010, 09:29 PM   #14
Dom Terreto
Member#: 180034
Nooooo.. Lol. Clutchmaster clutch
Old 01-02-2010, 10:04 PM   #15
AkumaMotorsports
Member#: 214570
Clutchmasters. The Axxis Pads are made for another company, not Axxis. That is what I meant. I misspoke abut the Ultimates'. They are a more race oriented compound. I had to call to find out exactly.
Old 01-03-2010, 08:24 AM   #16
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Thanks for clearing that up....
Nice build.
Old 01-03-2010, 11:05 AM   #17
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Great Job john and the Akuma team. Car must be a beast to drive...
rexworx is offline   Reply With Quote
Old 01-04-2010, 06:24 PM   #18
fourmicah
Member#: 128760
2015 STI
Thanks for the reply on the FMIC piping. There is so much about the design of them that I don't understand, specifically the piping. That kits looks awesome and the turbo looks like the perfect turbo for the street if you want relatively quick spool and good HP.
Old 01-05-2010, 03:32 PM   #19
AkumaMotorsports
Member#: 214570
Default More Pics!!!
These are our 5 axis CNC Heads. We can offer these for 1999.00!! If you want the full valvetrain and assembly, just let me know and I can get a full estimate(requires your heads as core)
KILLER B OIL PAN!!! This thing rocks.
Into the beast!
Old 01-05-2010, 07:07 PM   #20
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
+1
I was disappointed when my gt35r reverse-manifold setup didnt make any difference in spool-up compared to the normal manifold placement. Infact, i had more 90-degree bends after the change to make the reverse-manifold setup work correctly, so i probably made it spool slower LOL.
I did all that work for nothing
ImprezaRSfan! is offline   Reply With Quote
Old 01-06-2010, 08:05 AM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Great build, I'm glad we could be a part of it!
Great innovative stuff here and I'm looking forward to following this and future projects!
KillerBMotorsport is offline   Reply With Quote
Old 01-06-2010, 09:46 AM   #22
AkumaMotorsports
Member#: 214570
The Killer B pick up and oil pan are critical parts to this build. The increased volume of the pan and the structural integrity of the pick up are two details that make this part of the build. Not having to worry about oil volume and delivery, are two very important details often overlooked on hih HP builds.
The fit and finish on the Killer B parts are excellent. We still need one more pick up and one more pan for a 2005 STI! Waiting patiently.
John
Old 01-06-2010, 02:40 PM   #23
whitestar
Member#: 130454
2006 STI
Thumbs up
awesome build John... can't wait and see what it does when you turn up the boost!!
Old 01-09-2010, 06:57 PM   #24
STIdad
Member#: 195929
I'd really like to hear more about the ECPro. What kinds of little issues would an end user face that you were referring to earlier? What other drawbacks are there, and what are the real benifits?
I've always thought that the ECPro would be the best ECU solution available, but very few have used it to this point and less have really commented on it. The product description from Cosworth only tells so much.
STIdad is offline   Reply With Quote
Old 01-09-2010, 09:14 PM   #25
Dom Terreto
Member#: 180034
I'll leave the real pros and cons list to John.. But this car has amazing drivability and the ecu allows control over EVERYTHING... In the right hands(emphasis), this may be the best ecu on the market.
Evan
FS : 2008 STI OBP 30k miles sublimeplaid SCIC Private Classifieds 24 11-05-2010 02:43 AM
Sold law MWSOC Private Classifieds 2 06-09-2010 11:03 PM
FS : 2008+ STI SPT cat back exhaust Hokie-wrx wagon MAIC Private Classifieds 6 06-08-2010 10:33 AM
FS : oops sublimeplaid SCIC Private Classifieds 0 06-04-2010 11:14 PM
FS: 2008 STi (San Antonio) HaloWRX TXIC Private Classifieds 0 05-14-2010 01:00 AM
