#1 |
Member Sales Rating: (36)
Member#: 193383
South East
Vehicle:2004 WRX WRB 97 Impreza Wagon |
IHI-VF30 - SOLD
*Includes Oil Feed Line *No Shaft Play *Low Mileage -Will trade my turbo + cash for a 20g (preferably FPGreen) The VF30 is a fairly new IHI model that utilizes the exhaust housing of a VF24 and the compressor housing sized between a VF 23 and a VF 22. It comes on boost down low (around the 3000 rpm range). With upgraded injectors, fuel pump, and engine management, the VF 30 is good for 365-390 horsepower. It is important to note that the VF30 is NOT a roller bearing turbo it is bronze bearing. IHI VF30: Another Subaru factory affair, this Turbo is installed on the latest edition STi version WRX from Japan (to 10/01). The VF30 represents the best bang for the buck Turbo to be used for street and strip use. The VF30 features an identical RHF55 housing as used in the larger VF22 which makes upgrades to the wheel increasingly easy. In terms of size, this turbo is almost as large as the VF22, and bigger than the VF23-29. This turbo features the venerable EZ18H turbine housing, 48 mm compressor inlet, and a compressor that while similar in design to the VF23-29, features a 6th blade for better performance across the rev range. This is a terrific all around turbo, and clearly a top seller. It's main characteristic is its linear power delivery, making it a perfect bolt on street turbo that can easily turn 12 second timeslips at the strip. ![]() ![]() ![]() ![]()
| Thread Tools | |
| Display Modes | |
| FS in MD: VF30 turbo, good condition NO shaft play | NickD151 | Engine/Power/Exhaust | 5 | 08-18-2009 10:25 AM |
| FS (SC): 07 OEM STi VF43 Turbo! 17k miles, no shaft play, no cracks!! | Crewchief | Engine/Power/Exhaust | 1 | 04-18-2008 07:24 PM |
| FS (Nor Cal): VF39 turbo, 52K miles, no shaft play | DomozitoLK | Engine/Power/Exhaust | 5 | 04-16-2008 04:19 PM |
| FS: TD04L Stock WRX Turbo Low Miles/No Shaft Play | 02GAWRX | Engine/Power/Exhaust | 12 | 01-05-2007 05:45 PM |
