Old 05-21-2002, 05:57 PM   #1
etam
Member#: 439
www
Default how important is sway bar when you have upgraded your suspension already?
Hi all,
During Saturday's autoX or even earlier, I broke one of the rear sway bar bushing or the driver's side sway bar is disconnected from the end link...
I am just wondering how important is the rear sway bar when you already upgraded your suspension??...
I am asking because I didn't feel any difference in handling.. maybe it has been broken for a long time..
I found this out when I swap the race tires to street tires. I know I didn't pay attention to my car.. I will, in the future.
My setup:
version 5 strut with H&R spring
stock 16" R compound (44psi front/34psi rear)
my rear sway bar is a 19mm older Legacy turbo one (with bushing to connect to drop link; and also bushing to connect to sub-frame).
Ernest
etam is offline   Reply With Quote
Old 05-21-2002, 10:10 PM   #2
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Well, when I upgraded my wussy 13mm stock bar to my 20mm FHI bar it was a world of difference. Now i wish I had bought the Whiteline adjustable bar instead thoug, as you can effectively go to a much higher mm bar with it.
imprezadan is offline   Reply With Quote
Old 05-22-2002, 12:25 PM   #3
Section 8
Member#: 821
If you never noticed it when it broke/lost its bolt, maybe you never put a bolt in their to begin with.
Even with an uprated suspention, the difference between no sway bar and a NINTEEN mm swaybar will be huge.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 05-22-2002, 12:31 PM   #4
etam
Member#: 439
www
put the bushing back in hole and also some washers to prevent it from getting out again...
difference?? just a little.. not hugh.. well.. maybe I am in-sensitive to car handling
can post some pics tonight...and you will know what 19mm bar looks like..
Old 05-22-2002, 01:00 PM   #5
Section 8
Member#: 821
I have a 20mm bar. It shouldn't be much different. Do you drive fast enought to make the front tires skid (understeer)? If you don't then I guess that you wouldn't notice a bigger bar (or one at all as the case may be).
My bad.
I just put a 20mm bar on a ~390 front, ~330 rear pound per inch suspention. It greatly effects the breakaway charecteristics of the car.
cheeRS,
Greg
Old 05-22-2002, 01:07 PM   #6
etam
Member#: 439
www
My bad
Why??
Anyway, I guess I just need to drive my car harder to feel the difference..
thanks for the comment!
Good day!
Old 05-22-2002, 02:58 PM   #7
Section 8
Member#: 821
I assumed to much. The sway bar on an uprated suspention would be hard to detect in everyday driving. It won't make a huge difference. I thought that you were experiancing the lack of appreciable difference during an Auto-X, with the occasional sliding, that is when the bar makes a huge difference in how the car behaves.
cheeRS,
Greg
Here is what happens when you dont replace your up pipe. Davenow Newbies & FAQs 329 02-17-2015 08:51 AM
How important is it that the person who does your hair be easy on the eyes? Asinine Off-Topic 45 05-21-2008 08:12 PM
I'm a noob with turdbo cars...how important is a CBE when I already have a DP? lateralus1082 Newbies & FAQs 4 03-12-2008 09:52 PM
Water is like sex--when you have it, you want more. When you don't, you forget it. Asinine Off-Topic 13 06-05-2007 04:00 PM
This is what happens when you piss off your rich father mattjk Off-Topic 10 08-02-2006 06:40 PM
