Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 01-01-2010, 04:00 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default RCE T2 Coilovers are back in stock-RCE, GTWORX, KW and alot more
We are the Canadian Distributor for Racecomp Engineering
RCE In Stock
RCE Tarmac 2('02-07 WRX/STI), Tarmac 0('02-07 WRX/STI, RCE Regular Guys springs(GD, GRB), RCE swaybars(GD/GRB), RCE Carbon Fibre Kool Brake kit(GD)
Coming Soon
RCE Yellows(GR chassis) should be here very soon, '08+WRX Bilstein/Yellow spring packages should be here very soon also.
Still taking deposits-very popular and I only have 20 sets alotted at intro-pricing:
1) RCE Yellows for the GRB('08+STI)
Teaser pic courtesy of Myles at Racecomp Engineering
2) '08+WRX Bilsteins/Yellow springs-pm or email for pricing
3) I also have GD('04-06 STI, *'07 STI) and GRB('08+STI) swaybars coming-pm or email to pre-order, these swaybars are very popular.
RCE swaybars are here!!!!!
Racecomp Engineering 25mm Swaybars for STi (2004-07)- pm for pricing
The Racecomp Engineering swaybar set will work well with stock springs, lowering springs, or coilovers. The settings for the front bar are 25.5 and 28.5mm. The settings for the rear bar are adjustable from 25.5, 27.0 and 28.5mm. You can run these and not have to go to a bar that is actually 27mm thick. 25.5mm physical diameter. 4142 Chrome Moly Heat treated and cold finished. Ends are hot forged on a 125 ton press. Includes polyeurathane bushings and lube. Washer tabs on front and rear to prevent walking.
Racecomp Engineering GR Sway Bars-
pm for pricing
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
Pm/email for more info
Bilstein Struts-GH chassis '08+WRX
Finally something available for the '08 WRX where you don't have to break the bank.
Bilstein struts will transform your WRX into a cone eating monster when matched to a set of RCE Yellow springs.
Details:
Front:
Monotube, Gas, inverted struts.
NON DAMPING ADJUSTABLE.
For use with OEM springs or lowering springs and top hats.
Rear:
Monotube, Gas, shock absorber.
Adjustable sir CLIP for + 10 or -10mm rear height.
For use with OEM springs or lowering springs.
Shocks will come with dust covers and be powder coated.
Racecomp Engineering Parts List
Coilovers
GR Chassis Clubsports- $2,370US pm for pricing.
GH/GE Chassis 08+ WRX non-STI-$1,995US pm for pricing
GD Chassis-$2,275US pm for pricing
Tarmac 1 Coilovers for 05-09 Legacy $1,675US pm for pricing
Tarmac 0 Coilovers for 02-07 Impreza $1,775US pm for pricing
Sway bar Solutions
04-07 STi Sway bars Front or Rear-$219US pm for pricing
08+ STI Sway bars Front or Rear-$229US pm for pricing
Spring Solutions
Yellow 04-07 STi $339US $375Can
Black 04-07 STi $339US $375Can
WRX Wagon 04-07 $339US $375Can
08+ Regular Guy STI $359US $395Can
Mounting Solutions
Introducing the first in an all new line of parts from GTWorx, the sister company of Racecomp Engineering. Drawing upon the extensive chassis design knowledge and experience that comes from designing several suspension and brake components with RCE, GTWorx is proud to announce their Camber Adjustment Pillowball Mounts for 2008+ Subaru Impreza GR chassis and 2005+ Legacy. These camber plates are currently intended for coilovers only, however, testing is underway for use with OEM style fixed perch struts.
Key features of these new front camber plates include a very low stack height, which means that these top mounts are non-raising at most camber settings. For a coilover at a given ride height, the user will have MORE bump travel with the GTWorx plate when compared to most other currently available plates on the market which raise the car substantially.
In addition, +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber challenged Impreza chassis.
These lightweight alloy camber plates use the same high quality PROVEN pillowball bearing used in the popular Racecomp Engineering Camber Plates, which are known for smooth, long lasting, and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
A fact worth noting is that the relatively straightforward and simple design means that these durable plates are available at a realistic price much cheaper than the popular Racecomp Engineering camber plates.
To be used with coilovers
GTWorx GR front camber plates $389US $428Can
GTWorx GD front camber plates $359US $396Can
GTWorx GD rear camber plates $359US $396Can
Brake Cooling Solutions- in stock
Kool Brake Kit GD STI $399US $449Can
Kool Brake Kit GR/2010 Leg.TBA
GTWORX by BILSTEIN
2008+ GH Impreza and WRX shocks $999US pm/email for pricing
We have Whiteline parts in stock for all make/model years of Subaru
Search here for your vehicles part#- http://www.whiteline.com.au/index.php
Strut top-camber/caster adj MOTOTSPORT KCA255M
Anti-lift/caster kit - lwr c/arm KCA359
Anti-lift/caster kit COMFORT KCA362
Anti-lift/caster kit RACE KCA359M
Brace-strut tower alloy adj KSB554
Brace-strut tower alloy adj KSB599
4 point Brace-Lower control arm KSB723
Brace-strut tower alloy adj KSB568
Subframe lock kit KSB750
Front of rear diff support lock KSB751
Gearbox positive shift kit W0584
Gearbox positive shift kit-MOTORSPORT W0584M
Heavy duty steer rack mounts KSR202
H/duty steer rack bushes KSR206
H/duty steer rack bushes KSR207
Roll-centre / bump-steer adjust kit KCA313
Camber adj kit-control arm upper bushes KCA326
Anti-lift/caster kit - lwr c/arm KCA334
Anti-lift/caster kit - lwr c/arm KCA334M Race
Strut top-camber/caster off-set KCA335
Sway bar link conv kit - extra h/d alloy KLC26
Sway bar link-bushed allow link KLC32
Swaybar link kit-spherical rod end KLC39
Swaybar link kit-spherical rod-end KLC066
Swaybar link kit-spherical rod end KLC047
Anti-roll link kit- h/duty adj ball link KLC139
Swaybar mount-h/duty kit KBR20-22
Swaybar mount-h/duty kit KBR20-24
Swaybar 22mm-h/duty Blade adjustable BSF12Z
Swaybar 22mm-h/duty Blade adjustable BSF30Z
Swaybar 22mm-heavy duty BSF30
Swaybar 24mm-X heavy duty Blade adjustab BSF30XZ
Swaybar 22mm-h/duty Blade adjustable BSF33Z
Swaybar 24mm-X h/duty Blade adjustable BSF33XZ
Swaybar 24mm-X heavy duty BSF33X
Swaybar 24mm-X h/duty Blade adjustable BSF36XZ
Swaybar 27mm-XX h/duty Blade adjustable BSF36XXZ
Swaybar 22mm-h/duty Blade adjustable BSF39Z
Swaybar 22mm-heavy duty BSF39
Swaybar 24mm-X heavy duty BSF39XZ
Swaybar 22mm-h/duty Blade adjustable BSR33Z
Swaybar 22mm-heavy duty BSR33
Swaybar 24mm-X h/duty Blade adjustable BSR33XZ
Swaybar 22mm-h/duty Blade adjustable BSR36Z
Swaybar 24mm-X h/duty Blade adjustable BSR36XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR37XZ
Swaybar 27mm-XX h/duty Blade adjustable BSR37XXZ
Swaybar 20mm-h/duty Blade adjustable BSR49Z
Swaybar 22mm-X heavy duty Blade adjustab BSR49XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR49XXZ
If you do not see a part # listed pm/email for availability
I will match price with any Canadian vendor-just forward me a valid quote
Last edited by dalesalignment&brake; 08-02-2010 at 11:10 PM. Reason: Updating title
dalesalignment&brake is offline
Old 01-11-2010, 01:18 PM   #2
Member#: 173316
'13 BRZ
Many other suspension options:
1''drop frt/rr.
I installed a set in an '09 STI and the rideheight looked awesome and it was very comfortable, works well with the stock dampers.
Retail-pm for pricing
Spring and coilover applications
Bottomline pricing:
KW V1 '04+WRX-$1699Can
KW V3 '05+STI-$2395Can
KW V3 '08+WRX-$2295Can
KW V3 '08+STI-$2595Can
Group n tophats, motor mounts and bushings
Coilover and shock options
Coilover andshock options
Brake Upgrades
All DBA and Hawk part # in stock.
'04-09 STI-DTC 30, HP+ and HPS
HB453W.585 Hawk Brake Pad
HB180W.560 Hawk Brake Pad
HB453N.585 Hawk Brake Pad
HB180N.560 Hawk Brake Pad
HB453F.585 Hawk Brake Pad
HB180F.560 Hawk Brake Pad
'02-07 WRX-HPS and HP+
HB352F.665 Hawk Brake Pad
HB434F.543 Hawk Brake Pad
HB432F.661 Hawk Brake Pad
HB452F.545 Hawk Brake Pad
HB178F.564 Hawk Brake Pad
HB179F.630 Hawk Brake Pad
HB432N.661 Hawk Brake Pad
HB452N.545 Hawk Brake Pad
HB178N.564 Hawk Brake Pad
HB179N.630 Hawk Brake Pad
DBA Standard Slotted Rotors
STI-'04
654SL DBA Brake Rotor
654SR DBA Brake Rotor
655SL DBA Brake Rotor
655SR DBA Brake Rotor
WRX-'02-07
650SL DBA Brake Rotor
650SR DBA Brake Rotor
644SL DBA Brake Rotor
644SR DBA Brake Rotor
653SL DBA Brake Rotor
653SR DBA Brake Rotor
DBA 4000 Slotted Rotors
'02-07 WRX('06-07 rears only)
4650SL DBA Brake Rotor
4650SR DBA Brake Rotor
4653SL DBA Brake Rotor
4653SR DBA Brake Rotor
'05+ STI DBA 4000 slotted
42654SL DBA Brake Rotor
42654SR DBA Brake Rotor
42655SL DBA Brake Rotor
42655SR DBA Brake Rotor
05+ Legacy GT Front DBA slotted
42650SL DBA Brake Rotor
42650SR DBA Brake Rotor
DBA 5000 and Performance Friction 2-piece Slotted Rotors
Steel braided brake hoses
ATE brake fluid(Blue and Clear)
Ferodo 2500/3500 in stock for STI.
PM for rotor, pad, fluid and steel braided hose combos. This will save you $$$$$.
For a quicker response email [email protected]
Old 01-11-2010, 08:21 PM   #3
Member#: 173316
'13 BRZ
We also sell tires, here is a quick and easy way to get pricing:
http://www.dalesalignment.com/online...imate_page.htm
We offer very competitive pricing with other Canadian vendors and all major brands are available.
Please do not price match us with large U.S. tire warehouses. A few things to keep in mind the big warehouses cannot offer are lifetime balance, rotations, flat repairs etc. which are included in our quotes. Dismounts/mounts, tire levy for recycling and wheel balancing are an $80+charge on top of your import tire pricing.
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
Old 01-12-2010, 05:00 PM   #4
Member#: 173316
'13 BRZ
Put together a package and I will save you $$$.
PM or email for pricing.
__________________
[/CENTER]
Old 01-12-2010, 10:21 PM   #5
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
This is a great opporttunity for Canadians to save on duty, shipping etc.
Jason is a great guy and knows his suspension tech very much.
Myles
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline
Old 01-14-2010, 04:24 PM   #6
Member#: 173316
'13 BRZ
Bump for update
__________________
[/CENTER]
Old 01-14-2010, 05:01 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Originally Posted by dalesalignment&brake View Post
Bump for update
thanks Jason for the order today.
People.....Dales is our Canadian connection and you should support him !!
YAYYYYYY.
Myles
__________________
410-846-5407
Old 01-18-2010, 08:26 PM   #8
Member#: 173316
'13 BRZ
Dales Alignment is the exclusive Canadian distributor of Racecomp Engineering and GTWORX products. Jason at Dales Alignment has served us well in representing RCE and GTWORX since early 2007. Their expertise in suspension installation and track day preparation has set them apart from most regional dealers. Their online presence and customer service speaks for itself. If anyone has any questions about RCE and GTWORX products feel free to contact Jason at Dales Alignment and Brake in Vancouver, BC.
Best Regards,
Myles Williams
Motorsports Marketing Director
Racecomp Engineering LLC. and GTWORX.com
7410 Coca Cola Drive Suite 109
Hanover, Maryland 21076
Email from Racecomp Engineering
__________________
[/CENTER]
Old 01-25-2010, 12:56 PM   #9
Member#: 173316
'13 BRZ
Monday bump
__________________
[/CENTER]
Old 01-25-2010, 01:25 PM   #10
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2009 WRX and Boxster
Gray and Black
Monday bump
Dale what tires do you run at the track?
GTWORX
__________________
GTWORX - 410-846-5633
- BILSTEIN- Cobb - WHITELINE- Kartboy - KW - AST - STOPTECH - SPARCO-JRZ
GTWORX.com is offline
Old 01-25-2010, 01:44 PM   #11
Member#: 173316
'13 BRZ
Haven't tracked the GR yet, paranoid about the ringland failure issue. In the past I used A032R and A048R, was going to run Toyo R1R on the GRB if I tracked it but pu$$ied out.
__________________
[/CENTER]
Old 01-26-2010, 03:06 AM   #12
HRCboy
Member Sales Rating: (4)
Member#: 167075
08 STI & 999R
I've run my GR thru 4 portland trackdays and 2 mission. NO issues at all! Can't believe everything you read on the internet. What you need is to get a tune from Pat... can't believe you are still running OTS maps.
HRCboy is offline
Old 02-03-2010, 01:05 AM   #13
Member#: 173316
'13 BRZ
I'am now taking deposits on RCE Yellows for the GRB('08+STI) and GH('08+WRX)* chassis.
I will honor RCE intro pricing of $349US+shipping(Can. address), free shipping to the lower 48 if you have a US address. Exchange rate will be calculated day of shipping from RCE.
*recommend upgrading struts on WRX chassis. PM for details
__________________
[/CENTER]
Old 02-09-2010, 12:30 PM   #14
Member#: 173316
'13 BRZ
I have 2 sets of GR Yellow springs and 3 GH Yellows that are offered at intro-pricing.
Once these are gone the 2nd batch of springs will be coming in late spring at retail pricing.
PM/call for more info.
__________________
[/CENTER]
Old 02-10-2010, 02:10 PM   #15
subzero_Legacy_Gt
Member Sales Rating: (2)
Member#: 52185
pm sent
subzero_Legacy_Gt is offline
Old 02-11-2010, 10:58 PM   #16
Member#: 173316
'13 BRZ
Here is what my son(5y/o now) thinks of RCE, KW, etc.
__________________
[/CENTER]
Old 02-11-2010, 11:53 PM   #17
iht
Member Sales Rating: (7)
Member#: 196742
2000 Impreza 2.5rs
He also likes OEM 6 speed shift knobs
iht is offline
Old 02-18-2010, 02:47 AM   #18
Member#: 173316
'13 BRZ
Check out the pricing on KW in post #3.
__________________
[/CENTER]
Old 02-21-2010, 10:52 AM   #19
Member#: 173316
'13 BRZ
WRX and LGT BBK now available
We can try and build a kit for any budget. Start with the front then add rears when the budget allows.
Email for pricing
__________________
[/CENTER]
Old 02-21-2010, 11:05 AM   #20
Member#: 173316
'13 BRZ
Email for pricing
__________________
[/CENTER]
Old 03-10-2010, 11:46 PM   #21
Member#: 173316
'13 BRZ
Wednesday bump
__________________
[/CENTER]
Old 03-11-2010, 02:33 AM   #22
Petrie
Member Sales Rating: (8)
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Aren't you on holiday?
Take a break buddy.
Petrie is offline
Old 03-12-2010, 07:41 AM   #23
Member#: 173316
'13 BRZ
I have one set of '08+STI RCE T2 in stock. PM me for DISCOUNT pricing.
* '07 STI use a different front lower c/arm, RCE swaybar can be fitted with adjustable endlinks. PM for more info.
__________________
[/CENTER]
Old 03-12-2010, 07:41 AM   #24
Member#: 173316
'13 BRZ
Take a break buddy.
My kids coughing is driving f'ing nuts, trying to kill time.
__________________
[/CENTER]
Old 03-15-2010, 10:49 AM   #25
Member#: 173316
'13 BRZ
Lundi bump
__________________
[/CENTER]
Closed Thread
Racecomp Engineering pre-order-Updated pricing and product list dalesalignment&brake VIC Vendor Classifieds 2 12-14-2009 01:17 PM
Pre-order sale on Avic-f900bt flatfour562 Car Audio, Video & Security 44 07-04-2008 04:05 PM
did anyone Pre-order sale on Avic-f900bt with rock star? poorlilpoop Car Audio, Video & Security 3 06-22-2008 08:05 PM
Pre-order SALE On Genuine JDM STi Pink Spring sets! (04+ WRX, STi, Forester) Edo Performance Suspension/Brakes/Handling 12 08-19-2007 09:49 PM
COBB Access port ver 2.0 pre order plus more COBB and APS Fine Line Imports Engine/Power/Exhaust 9 11-16-2006 11:26 PM
