Old 01-01-2010, 11:35 PM   #1
Tr2laozboi
Member#: 119766
Default 2.5 RS swap in 02 WRX...What is needed?
I have a 2002 WRX that needs a new motor because of spun bearings. I have a good opportunity to buy a 2003 2.5 RS motor for cheap. My question is what would all be needed to make this work. Would I have to use a 2.5 rs ECU?
Tr2laozboi is offline   Reply With Quote
Old 01-01-2010, 11:38 PM   #2
wrath1517
Member#: 193723
2002 RS STI HYBRID
Yes entire wire harness swap, ecu swap make sure tranny will work as well.
Why tho?
wrath1517 is offline   Reply With Quote
Old 01-01-2010, 11:41 PM   #3
Tr2laozboi
Member#: 119766
Why tho?
Lol money is really tight. But I guess this would be the wrong route? I assume that the wiring harness would be really similar.
Old 01-01-2010, 11:46 PM   #4
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
[quote=Tr2laozboi;29271665]Lol money is really tight. But I guess this would be the wrong route? I assume that the wiring harness would be really similar.[/quote
I get that money is tight but this is kind of a odd way to "save" money. You have a turbo wrx 2.0 motor and you want to drop in a n/t 2.5 rs motor? It will cost you money to make the swap and you lose in affect what is a WRX and turn it into a RS wagon for all practical terms. How much money are you really working with, can you do any of the work, are you taking the car to a shop? If its just a bad bottom end and the heads are ok, have you tried looking into a used short block or something along those lines?
flyinghighlm is offline   Reply With Quote
Old 01-01-2010, 11:48 PM   #5
hella jdm y0
Member#: 118845
2006 Ninja ZX6R
spun bearing? Couldn't you just use the block from the 2.5 and reuse everything else from the wrx?
hella jdm y0 is offline   Reply With Quote
Old 01-01-2010, 11:52 PM   #6
Tr2laozboi
Member#: 119766
Yeah I have look at all the possibilities. But there is a 2003 2.5 RS motor for $300. I was thinking the cheaper the better since this is just a daily driver. The head cylinders are fine id assume. My funds are low as $500 lol. Just thought that the motor swap would be simple as swap in swap out. So the harness is completely different?
Old 01-02-2010, 12:05 AM   #7
wrath1517
Member#: 193723
2002 RS STI HYBRID
YUP!!! I removed the rs harness and replaced it with a wrx in my swap.
Old 01-02-2010, 12:11 AM   #8
wrath1517
Member#: 193723
2002 RS STI HYBRID
Nah...Heads won't fit
im gonna buy a 2.5 rs swap plz tell me if this is good zacxzx Newbies & FAQs 3 04-21-2010 11:23 PM
Closed Deck EJ20G swap in 02 WRX??? What esle do i need? Wrx_Fan_0717 Built Motor Discussion 13 03-06-2009 06:01 PM
2.5 rs turbo in a wrx rhino1122 Newbies & FAQs 32 10-23-2006 02:20 AM
2.5 RS trophys in STX; STS exclusion is immenent gary p Motorsports 44 05-06-2005 05:22 PM
