Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 01-08-2010, 04:25 PM   #1
Member#: 192679
2002 WRX Wagon
Stage 2 [Sold]
Default Getting engine knock @ low RPMs & also running lean after Stg2 Map
Below is the LearningView of my '02 WRX as of a few days ago. Has improved after applying the Stage 2 map.
Also replaced the spark plugs a month ago (NKG plugs).
Sept 2009 - Stock map
Jan 2010 - After Stg2 map & new NKG plugs
Only mod done is a full catless exhaust (up-pipe/down-pipe/3" catback). Still getting readings of low airflow. The filter is a couple years old, but not filthy. Also the stock ram-intake and snorkel was removed (Been removed for years).
Any pointers of what may need adjusted or suggestions to a different map would be quite helpful.
ROM used: A4SGE01C - MY02 OSECU Stage 2 r10.hex
zigforjustice is offline   Reply With Quote
Old 01-08-2010, 05:00 PM   #2
Member#: 222350
First thing is to get your MAF rescaled mate I think for both OL and CL.
uk300bake is offline   Reply With Quote
Old 01-08-2010, 05:48 PM   #3
Member#: 108089
2003 WRX
NF Performance
How sure are you that it's running lean? Wideband?
If so, post logs.
The learning view looks fine, you can remove a little timing in the higher loads.
Low load knocks are normal.
Should not have to rescale the maf if still on the stock intake.
Nuke209 is offline   Reply With Quote
Old 01-09-2010, 06:55 AM   #4
Sammo Hung
Member#: 10613
you might want to clean or replace air filter..
while you're there clean your maf sensor.
