Old 07-04-2012, 07:52 AM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Changing only injectors, advice on changes to tune for "no change" in operation
I am replacing the injectors on an 02 WRX. I would like advice on a quick way to modify the current tune to essentially make it function equal to before. I have the correct latencies but am curious what other items I may miss. The search engine is down and I am at the shop trying to button this up
Going from stock 02WRX blue top feeds to DeatschWerks 1000cc units. The intake will remain stock (hopefully little to no maf rescaling necessary).
I will take it to the tuner once the additional parts are installed but it needs to be safely drivable in the meantime.
ciper is offline   Reply With Quote
Old 07-04-2012, 09:09 AM   #2
quazimoto
Member#: 70395
Input the latencies and they go by the smallest injector value on the flow sheet for injector scaling. You will have to adjust tip-in at a minimum. I would then check your fueling ranges and see if adjustments need to be made.
http://www.romraider.com/forum/viewt...jectors#p68338
http://www.romraider.com/forum/viewt...ning+injectors
Old 07-04-2012, 09:42 AM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
Thanks a plenty. I felt like I was forgetting something but couldn't put my finger on it. I guess I must have been thinking about the tip-in.
Latencies are what the spec sheet says multiplied by .64 for open source right?
Message Board Statistics All times are GMT -4. The time now is 03:51 AM.
