Old 01-12-2010, 05:45 PM   #26
jibber
Member#: 6675
98 SF5 some mods
01 allroad
Yeah, I suppose I should have mentioned that you must let the car "0" the cams (at idle) before they will do anything. Once they zero out and start showing in the logger you can usually go drive them and they will move properly if they are working correctly.
jibber is offline   Reply With Quote
Old 01-12-2010, 06:03 PM   #27
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Just a bit more info on those AVCS bolts
There are 4 bolts in the system, 2 types.
Rear passenger head and front driver's head (behind the timing belt cover) have filters, they also have a small (1/8") bump in the center of the bolt head.
The bolts on top of the OCV are the same passenger vs driver, they have no filter, and the head of the bolt has no bump (it's flat).
That's a pretty easy way to see which bolt is which, you should have 2 bolts with a bump (on the heads), and 2 bolts without (on the OCV).
Is it possible your cam timing has jumped a tooth? I imagine that would throw a cam position CEL and probably disable, or at least cut back on the AVCS advance.
No bump:
http://www.thesuicidaleggroll.com/st...0/DSCN0587.JPG
Bump:
http://www.thesuicidaleggroll.com/st...0/DSCN0589.JPG
Old 01-12-2010, 07:18 PM   #28
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Originally Posted by 18aspenSTi View Post
I logged the NPS yesterday. It read 0 while in gear and 1 when in neutral.
I'll have to double check at lunch time for you, but I am pretty sure your polarity is reversed - I'm sure it is meant to show 1 while in gear and 0 while in neutral.
Will check in 2 hours for you - unless someone else knows for sure and would like to post.
Leslie
wrxsti.l is offline   Reply With Quote
Old 01-12-2010, 07:50 PM   #29
18aspenSTi
Member#: 139419
2005 STi
AW
11.75 & NSFW,
I just tried resetting the ecu after it was up to operating temp, and letting it idle without touching anything at all for 15 min. then tried it out, no luck, pretty much the same as before...3 degrees max advance. and it still did 12-25 degree advance when warming at 1500 rpm.
Jibber,
The cams have always zeroed before I move it at all. Once it's down to idle speed the go to "0", only when warming up @1500 rpm do they advance a lot.
Eggroll,
The OCV bolts are both correct now. Will check the other 2 in a few min. I thought about jumping a tooth, but read that the car would feel down on power and not drive as well. It however still pulls very very hard, once it spools later than usual. Is it possible for the car to still run well with a jumped tooth?
WRXSTI.L,
I appreciate you checking when you can.
Thanks everyone for helping me with this dilemma.
18aspenSTi is offline   Reply With Quote
Old 01-22-2010, 12:29 AM   #30
18aspenSTi
Member#: 139419
2005 STi
AW
I replaced the oil pickup tube, but apparently that was not this issue. When I was test driving it though, I noticed that even though the rev limit is set at 7100 rpm on the map, that my peak rpm was 7360. I remember seeing the needle dip to that point from the slight overlap of throttle/clutch when shifting? Could this be an issue with the ecu that could also be affecting my avcs actuation?
Old 01-22-2010, 01:07 AM   #31
ImportJunky
Member#: 115858
Mav Super Sonic
be there in 30 Secs
I'm Curious on this one as well. Just rebuilt the motor. not even 100 miles in and this has been popped twice.
Guess Looking into later today :-(
ImportJunky is offline   Reply With Quote
Old 01-22-2010, 01:52 AM   #32
18aspenSTi
Member#: 139419
2005 STi
AW
People have mentioned that maybe the person who built the motor forgot to remove the allen screws from the BC 272s and that is causing AVCS to not work. I had not gotten a chance to log anything before I experienced this problem, but spool is definitely taking longer now than when I bought it. Any thoughts?
Old 07-03-2012, 09:37 AM   #33
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
ever get this figured out?
Mr.Chow is offline   Reply With Quote
AVCS advance clarification drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 04-13-2006 04:50 PM
Front wheel has 2-3 degrees neg camber. What's wrong? sime Brakes, Steering & Suspension 7 03-23-2005 10:21 AM
AVCS advance dwx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-13-2004 01:57 PM
AG970 STi RA ECU and AVCS Advance... 30 degrees? dug-e-fresh Engine Management & Tuning 0 11-04-2003 03:10 PM
How many degrees of advancement are you running with link? gldenchld Engine Management & Tuning 5 11-07-2002 10:28 PM
