Old 01-04-2010, 02:01 PM   #1
SLVRBUGEYE
Member#: 232114
Default Misfire Cyl 2
I have a 2002 Subaru WRX just 70k I have a misfire in cylinder 2 and its running rough. Startup is rough, idle is rough and when u hit the gas, it stalls
possible problems?? Im thinking its something piston/ring wise
just find it hard to believe with just 70k no mods what so ever
SLVRBUGEYE is offline   Reply With Quote
Old 01-04-2010, 03:23 PM   #2
boll58
Member#: 175222
2003 WRX
I would start with the coil first.
boll58 is offline   Reply With Quote
Old 01-04-2010, 03:47 PM   #3
Haelan
Member#: 151045
2013 Subaru STI
CBP
Do a compression test before you start replacing parts.
Haelan is offline   Reply With Quote
Old 01-04-2010, 03:51 PM   #4
SLVRBUGEYE
Member#: 232114
workin on the comp now
Old 01-04-2010, 04:49 PM   #5
Mototrav22
Member#: 216822
02 WRX
Just swap coils and see if the prob move's to a diff cyl...
Mototrav22 is offline   Reply With Quote
Old 01-04-2010, 06:04 PM   #6
WRXPRE55
Member#: 193481
2004 WRX PSM
Catless, SRI, Inlet
Spark test the coil pack, the spark plug gap on a new stock plug is .30, if it sparks across .30 just replace the plugs. If not it may be either the coil pack or a bad wire or bad connection, I'd pull the plastic tubing away from the coil pack and look at the wires, or maybe if cyl 4 is misfiring too you have the connections backwards. The black connector goes onto the rear coil pack. Hope this helps! Good luck!
WRXPRE55 is offline   Reply With Quote
Old 01-04-2010, 06:08 PM   #7
WRXPRE55
Member#: 193481
2004 WRX PSM
Catless, SRI, Inlet
And if your not losing vacuum at idle, knocking, leaking/burning oil or smoking blue or gray out the exhaust chances are its not a piston/ring problem... Halean's right though, it wouldn't hurt to do a compression test while the plugs are out if you think you have a piston or ring problem.
..:: misfire cyl 2 - COIL sparking arcing VIDEO ::.. please help diagnose MR2fanatic Normally Aspirated Powertrain 7 05-02-2009 07:35 PM
2.0 Misfire Cyl 4 03WRX-WRB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 06-01-2008 10:47 PM
01 OBW lean misfire cyl 2 mechanic can't locate cause! GYates Outback Forum 3 08-23-2006 01:57 PM
HELP - CEL P0302 and P0304 = Misfire on Cyl 2 and 4! dexterous Normally Aspirated Powertrain 8 04-14-2005 11:38 PM
P0301 Misfire Cyl 1 and CE light 2yLiTe Normally Aspirated Powertrain 20 11-11-2001 01:13 PM
