#1 |
Member#: 95017
NWIC
Vehicle:2000 2.2RSTI stroker 2010 SWP STI |
Alright, my other build thread got too long so I'm starting another thread for assembly. If you want to see me tear it down and start getting parts together you can check it out here: http://forums.nasioc.com/forums/show....php?t=1703227.
Here is a table of contents for this thread: 1 - Intro and table of contents 2 - Highlights, plans and mod list so far 3 - Paint pictures part 1 4 - Paint pictures part 2 5 - Paint pictures part 3 6 - Paint pictures part 4 49 - Start stripping my wheels 50 - Buffing the paint at the body shop 51 - Doors, trunk, and hood on 57 - Sunroof, door handles, strikers, and more paint buffing 67 - Car comes home! Pull trunk, hood, axles, and installed RSB and rear brakes 73 - Reinstall axle, axle seals, front brakes, brake booster, ABS pump, STI pedals, and firewall blanket. Clean polish off paint. 99 - Pedals mounted, wiring started, brakes off to powdercoating 100 - Soldering in some connections and a lot more wiring 114 - More wiring and my battery hooked up. Lights are working and sun roof opens! 117 - Wheels are back and on the car 130 - Tires on the wheels 134 - Headlights wired in 140 - Microsuede headliner and started carpet 156 - Dash and headliner and trim in 197 - Put most of interior together 224 - Most of the exterior on 245 - Exterior 99% done and looking hot! 260 - A little bling for the exterior 270 - BBQ/Meet pictures 295 - Tons of interior done, stereo done, and sunny day pictures 307 - Removed all the tint, added the catback 309 - Twin scroll kit is here 314 - Harnesses fixed, rear seat fixed, rear cards in, tons more pictures 338 - Motor is built, still owe money though 345 - Got bored without a driving Subaru, bought a '10 STI 351 - Motor is home! Clutch is on! Motor is in the car! Exhaust is ceramic coated! 356 - Tons more little motor stuff done, coming along quick now I bought my first WRX 4 years ago about 6 months before my 18th birthday. I paid for it with my own money and modded it with my own money. I did all of my own modding to save some money and learned as much as I could. I started out easy but eventually got it pretty heavily built. I got it paid off and decided I wanted an RS. I bought this car January of 2009. It was a total on an auction that a friend picked up for me. I am doing almost all of the work myself with the help of my girlfriend (aside from motor build and paint). My plans have changed a lot over the last year but for the most part the car is as I had hoped it would be. Here are pictures of my old WRX and my RS when I got it: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Member#: 95017
NWIC
Here is the mod list I have planned for the car so far. Most of it is already purchased. I'm adding to it and changing things all the time so this will probably get updated.
Motor- Heads - Stock EJ205 heads Regrind 272/272 Cams Ferrea Springs/retainers Ferrea 1mm oversized exhaust valves Ferrea 1mm oversized intake valves STI Shimless buckets CNC ported exhaust Shortblock - EJ207 spec C type RA shortblock with 15k Bored .023 over Custom JE pistons Stock length CAT (Tomei) rods modded with oil squirters ACL bearings 83mm stroke Billet crank Balanced and blue printed Modded 12mm oil pump Cusco Motor Mount Phenolic 8mm Intake Manifold Spacers STI wiring harness STI gas tank CXRacing FMIC STI intake manifold and throttle body Bosch 1000cc injectors Walbro 255 fuel pump Perrin fuel rails STI oil pan and pickup Turbo kit - Covert Performance twinscroll T4 divided header, up pipe, and down pipe FP 3586R HTA /w 1.00 Divided T4 hot side Twin Tial 38mm wastegates Interior V2 GC8 STI front seats V5 STI rear seats Defi BF Imperial 60mm Boost gauge Defi BF Imperial 60mm EGT gauge Defi BF Imperial 60mm Oil Pressure gauge ATI 3 gauge pod TurboXS Knocklite Bosch Knock Sensor STI dash, auto HVAC, center console, ebrake STI full wiring harness Custom 6 point roll cage with harness bar painted to match exterior of the car Exterior Custom T-5000 paint Black gloss roof Shaved rear bumper Shaved bump strips Shaved antenna Impreza L trunk lid Impreza L hood OEM fogs Seibon P1 style front lip Gimmick Motorsports Hood struts Grimmspeed stealth antenna STI valve stem caps McGards red cap wheel locks Grafx Werks center caps Front and rear Aero Guards Rear spats Drivetrain Cusco tranny mount 2007 STI 6mt STI clutch slave cylinder STI hubs /w knuckles STI drive shaft STI axles STI rear diff STI 6mt short shift linkage STI 6mt shift knob STI front cross member with steering rack Kartboy Front Shifter Bushings Kartboy Tranny Crossmember Bushings TIC pivot bushing TIC Rear Diff Bushings Spiider Dual Mode OEM style DCCD controller Kartboy rear shifter bushings Kartboy STI 6mt shift lever STI front cross member and steering rack STI rear cross member Whiteline steering rack bushings ACT 6 puck clutch /w ACT prolite flywheel Suspension/Handling BC Racing BR coil overs 10k front/8k rear /w extenders TiC fender braces STI front lower control arms STI rear lateral links Whiteline ALK sport Prodrive PFF7 polished aluminum 18x8 +48 Kumho Ecsta SPT 235/45/18 Ingalls camber bolts Whiteline 24mm front sway bar Whiteline 24mm rear sway bar Kartboy front and rear endlinks L&E 10:1 quick steering column Brakes Brembos custom painted /w stock rotors Carbotech Bobcat pads Super blue brake fluid Gruppe-s Stainless lines ICE Stereo setup (no idea what kind yet) Here are some of the cooler pictures of stuff going on the car: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Cyclops; 01-04-2010 at 02:40 PM. |
#3 |
Member#: 95017
NWIC
Okay so as I said before, if you want to see it taken apart check the other thread. It's been at the body shop for the last 6 months getting all kinds of sweet stuff done to it. For more details you can read in the other thread but here are the most recent pics of it:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Cyclops; 01-04-2010 at 02:41 PM. |
#4 |
Member#: 95017
NWIC
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Cyclops; 01-04-2010 at 02:42 PM. |
#5 |
Member#: 95017
NWIC
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Cyclops; 01-04-2010 at 02:43 PM. |
#6 |
Member#: 95017
NWIC
#7 |
Member#: 210047
Vehicle:im a scooby guru really |
reserved 6!
#8 |
Member#: 170156
Vehicle:2010 370z white |
awesome!
#9 |
Member#: 159376
E. Canada
Vehicle:1999 Impreza STIV4.7 black |
wow nice paint job bud !!
![]() I prefer the RS over any GD |
#10 |
Member#: 143860
SCIC
Subscribing...almost there man! keep at it!
#11 |
Member#: 211600
NWIC
Vehicle:2001 Suzuki DRZ400 Supermoto |
hurry up and finish this, i LOVED your old wagon, it was just perfect so now i expect a lot out of this car. great choice in color
#12 |
Member#: 134516
Vehicle:o2 WRX BlankitaRIP o6 STi Blanca |
![]() That car is so beautiful and all it has is a fresh paint job lol |
#13 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP black & gold is pimpin' |
subscribed once again
#14 |
Member#: 156130
SCIC
Vehicle:2001 s2000 |
Looks amazing, cant wait to see more!
#15 |
Member#: 205427
Vehicle:2000 RSTI w/ hta68 Army Green |
Gorgeous build, but i am surprised your not doing fender work to fit some meaty rubber.
That paint is amazing, it must look so much better under sunlight. |
#16 |
Member#: 20492
Vehicle:Good for health, Bad for education |
Wow so much more to this car than I remember from the other thread. Amazing job |
#17 |
Member#: 105409
Vehicle:'05 HTA68'd WRX 327/310 |
nice project. color is sweet. subscribed for finished pics
#18 |
Member#: 192572
E. Canada
Vehicle:2007 Impreza CGM |
jizz jizz jizz
#19 |
Member#: 136098
NWIC
Vehicle:07 35r WRX Maxwell Power |
Too much win ITT.
#20 |
Member#: 88361
TXIC
Vehicle:'05 hYbrid |
OMG, sheppard puppy. So cute.
Oh yeah, nice car. ![]() |
#21 |
Member#: 87194
Vehicle:2008 Impreza WRX STI Spark Silver Metallic |
Can't wait to see the progress as this comes together!
#22 |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
wow im pumped to see this car complete!
#23 |
Member#: 230417
SCIC
Vehicle:Buy/ Support AWFILMS awfilms.bigcartel.com |
damn this is gonna be the tits.
#24 |
Member#: 233759
Vehicle:2006 WRX Lmtd. WFC #8008 |
oh my god so so sick, I am beyond jealous! so nice congrats
#25 |
Member#: 215854
SCIC
i dont think i would want mom and your half brother, along with his new puppy to go around a room near the paint, nobody likes a dog hair/lint paint.
| Thread Tools | |
| Display Modes | |
| FS: 06 STi. 35R. Tons of mods. (Buffalo, NY) | xnewmanx | Private Vehicle 'For Sale' Classifieds | 29 | 10-09-2008 04:45 PM |
| Tons of STI & WRX stock parts & Aftermarket | bottlediger | Engine/Power/Exhaust | 46 | 08-09-2007 08:30 PM |
| tons of sti part out and trades | ownnij | TXIC Private Classifieds | 25 | 02-10-2006 05:17 PM |
| Interested? '02 Wrx Wagon Black,tons of STi parts | WillRX | Private Vehicle 'For Sale' Classifieds | 9 | 07-14-2005 07:58 AM |
| Tint thread part 2: Calling LIGHT tinters | DieselClown | Member's Car Gallery | 25 | 08-21-2004 08:04 AM |
