Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 01-04-2010, 10:23 PM   #1
Member#: 143024
Default Porsche 914 with subaru conversion
Hey guys,
I've been lurking here for about a year now while I have been working on my project. My project is a 1974 914 and I am putting a DOHC 2.5L subaru engine in the car. You can check out my progress here...
So, here is my question to you guys:
I have kind of dug myself into a hole, and I was hoping that you guys can help me get out, or at least guide me in the right direction. I purchased a JDM motor from a 96-98 Legacy, and 1998 forester. For some reason (my stupidity and lack of diligence) I ended up with an USDM ECU for a 1999 legacy. with that ECU I got the entire wiring harness. I had the wiring harness re-worked, stripping it down to the necessary components for running the engine and also had the necessary sensors faked out.
Now, when I got the harness back, and after the engine was in, I realized that only some of the sensors were there(the entire EGR system is not), thus leaving several connectors un-plugged. Which is when I realized my total clusterf$%& of a situation.
So, here is what I think are my two possible solutions. Let me know what you think and if there are other possible situations.
Situation 1:
As I have read here... the only real difference between the JDM and USDM is the intake manifold, which has the EGR system on it. So, can I get a USDM intake manifold and put it on the JDM block? If so, do I get a 1999 manifold, or a 1998 manifold? Do I have to drill into the block for the EGR pipe, or is it already there on the block? (i think it is, but im not 100% sure). By doing this I could keep the harness and ECU and only have to buy the intake... which looks like I can buy one for about $100-200.
Situation 2:
The other option would be to go with a standalone engine management system. This would be a custom EMS Stinger ECU with a custom harness done by the guys at Outfront Motorsports. With this system, I could keep my engine 100% JDM and have the harness built for my engine specifically. Also other advantages to this situation would be that I can run diagnostics, program different maps, all from my laptop. Also it can be upgraded as I upgrade.. turbo, different engine, etc. I will be able to use it for a while. The only con.... it would cost $1500.
That was a lot to read. But I thank you guys in advance for any input you have. Oh, by the way, I am also in the market for a 2004 WRX wagon!! I think subarus are great for everything!
-Peter J.
malaga_red75 is offline   Reply With Quote
Old 01-04-2010, 10:33 PM   #2
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
scby rex is offline   Reply With Quote
Old 01-04-2010, 10:47 PM   #3
Member#: 44836
1999 Fozzy
stand alone, and put pistons and cams in it while you have the motor out.
KurtP is offline   Reply With Quote
Old 01-04-2010, 11:22 PM   #4
Member#: 143024
sounds like the standalone is the way to go... it is just a lot of money that is the only drawback... and if my engine will work for <$200... it might be worth it.
Is swapping the intakes a 'sketchy' fix, or will it work solid like that?
Porsche 914 with an ej20 Ysidro General Community 11 03-10-2010 03:36 AM
My 1973 Porsche 914 with Hybrid Suby engine Porche914WRX Subaru Conversions 40 06-18-2009 09:59 PM
WTB: NA Subaru Motor for Porsche 914 Simon Tibbett Private 'Wanted' Classifieds 2 06-08-2009 12:40 PM
Renegade Hybridís Subaru WRX-Powered Porsche 914 NYCshopper Non-Subaru News & Rumors 13 04-27-2007 08:14 AM
Project Porsche 914 Update tomrichardson Rocky Mountains Impreza Club Forum -- RMIC 14 06-19-2001 02:58 PM
