Old 01-05-2010, 06:59 PM   #1
Maxwell Power
Member#: 190729
Default Maxwell Power Dyno Tune: 2006 WRX, Built Motor, ATP GT3076R, 16psi = 380whp
16psi track day tune on a TMIC. The target for this tune was as linear a power band as possible.
Event:
dyno tune
Ambient Temp: 53.4F 54%humidity
Elevation: 200ft
Weather: Seattle
Car: 2006 WRX Wagon
Owner: Mike McIntyre
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 380 whp uncorrected, 367whp SAE corrected @ 6750rpm
Peak Torque at RPM: 334 ftlbs uncorrected, 323 SAE Corrected @ 4400rpm
Baseline hp/tq for a stock on same dyno: 175whp
Target Boost: 16psi
Target AFR: 11.3
Fuel: Pump 92oct
Method: COBB AP
Engine/Power Modifications:
*MPS Power Factor SS 2.5L shortblock: JE Pistons, full blueprint,
*Kelford R-199-B Cams, Ferrea Valves and Manley Springs, 11mm oil pump
*ATP GT3076R
*TMIC
*ID 1000cc injectors, TGV Deletes, APS 3" Inlet, Grimmspeed Spacers, Grimmspeed DP
thanks for looking,
Dominic Acia
Arlington, WA
360-474-8225
Maxwell Power is offline   Reply With Quote
Old 01-06-2010, 12:17 AM   #2
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Nice fat power band all the way to redline!!!! Very nice Dom!
I should be over there in early spring for tuning, can't wait.
I think you should post a pic of the car on all your threads if possible.
morrocco88 is offline   Reply With Quote
Old 01-06-2010, 12:34 AM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
wouldnt you want all the mid-range tq for the track?
Old 01-06-2010, 06:56 AM   #4
MattPersman
Member#: 139385
what does this dynocom dyno read like. when I had the 20g setup on my car tuned by Tim Bailey the car made about 350 whp on Buschur's Mustang dyno (known as a low reader the car ran 116 mph at the track 1/4 mile) then we took it to the dynocom here in Indianapolis at E-motor a few months later when Tim was in town and it did 416 whp with no changes. do all dynocoms read like you have a super car?
MattPersman is offline   Reply With Quote
Old 01-06-2010, 07:18 AM   #5
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Which hot side did this 3076R came with?
Tnx,
Walter
Beetspeed is offline   Reply With Quote
Old 01-06-2010, 08:04 AM   #6
silver-duck
Member#: 130710
This is my car,and Dom tuned the torque out of it until I change the trans. My prior tune was done by Tim Bailey on a mustang at 317/344[old motor,great tune].Butt dyno tells me this motor makes alot more power up top;these cams make a big effect from 5000 up.This motor is so smooth it is really fun to drive.Someday I will have Dom turn this motor up and have even more fun.[27mpg on highway is nice also; I checked it for 120 mile trip going over 2 mountain passes and putting my foot in it some and got 25.4 mpg]
silver-duck is offline   Reply With Quote
Old 01-06-2010, 10:16 AM   #7
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Tnx,
Walter
The standard ATP stock location housing. ~.7x A/R.
Old 01-06-2010, 10:51 AM   #8
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Ok, thanks.
.7x -ish is about 10cm² right? Would make a nice comparison then to the new DOM3 XTR, which has now 10cm hot side, hence the question
Would be nice to know what this combo would make at 20 psi, which seem to be sort of a benchmark for turbo-engines comparison.
Old 01-06-2010, 10:58 AM   #9
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Originally Posted by Maxwell Power View Post
Peak HP at RPM: 380 whp uncorrected, 367whp SAE corrected @ 5600rpm
I see peak RPM for max hp at 6750, not 5600 rpm??
Am I reading it wrongly?
Old 01-06-2010, 11:21 AM   #10
Maxwell Power
Member#: 190729
Obviously people have different opinions on what a track car should be like. To me, nothing beats a flat torque curve and a linear hp curve. It makes the car feel like a big N/A V8. This makes the power easy to manage. A sudden jump in torque and hp makes a more difficult car to drive on the track as you exit corners.
Also, as silver-duck said, we kept the torque lower on purpose to help out his transmission. However.... well we tried, right?
Lastly, with these cams, the car isn't going to make the normal high peak tq that suby owners are used to seeing on factory cams/heads.
Two big things to note for this tune/engine.
*1st, the cams. Cams go a long long way. Boost is a function of back pressure (or flow resistance). HP is a function of airflow. So if you lower flow resistance (cams), you increase airflow (hp) for the same boost pressure.
*2nd, a 3076 flows much more than a 20G.
Also, our dyno reads between a mustang and a dyno jet.
Was your HP the corrected or uncorrected value? I always include both. Mustang always gives corrected (as far as I can remember) and the dynocom gives you the option of observed (uncorrected) and SAE corrected.
No sir, you are correct. I copied this format from my other threads in proven power bragging and forgot to change the RPM.
Old 01-06-2010, 03:05 PM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
looking good Dom!
Old 01-07-2010, 11:12 AM   #12
silversubiedude
Member#: 182010
2002 slow wrx
psm
Can't wait to see this thing with the built 5 speed!!!
Congrats Mike!!
silversubiedude is offline   Reply With Quote
Old 01-07-2010, 02:38 PM   #13
silver-duck
Member#: 130710
It might be a while but someday it will happen. Thankyou for the kind words.
Old 01-12-2010, 02:46 PM   #14
JD06REX
Member#: 158395
2006 1Wide WRX
QuickSilver pushin 275s
turn da boost UP and post new graph PLEASE
JD06REX is offline   Reply With Quote
Old 01-12-2010, 02:47 PM   #15
Maxwell Power
Member#: 190729
need working transmission first.
Old 01-12-2010, 03:31 PM   #16
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I'm sorry, and I respect you guys very much, but I can't help but see these big number cars and think this dyno reads much higher than "between a mustang and a dynojet". My 61mm T4 .81ar, car made around that horsepower on 93 octane and 19lbs of boost.
wrxwhat is offline   Reply With Quote
Old 01-12-2010, 04:41 PM   #17
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
By looking at the thread of the VF43 making 340whp on 93oct it is safe to say that this dyno reads about 30-40whp higher than airboys/mustang
I think this car will trap 113-115mph
Old 01-12-2010, 05:52 PM   #18
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
I completely agree. But a dyno is just a tool, if the car is healthy and the owner is happy... thats all that counts.
As for how the dyno actually reads, this would be just about 300whp on a true mustang, and 330 on the airboy.. all signifying 113-115 traps.
STi Mikey is offline   Reply With Quote
Old 01-12-2010, 07:29 PM   #19
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Any issue getting those valve springs to fit?
modaddict is offline   Reply With Quote
Old 01-12-2010, 09:01 PM   #20
Maxwell Power
Member#: 190729
you guys are totally missing something; the temperature.
There are very few dyno cells in the country that draw in air as cold as ours. 32 degree change in intake air temp is 10% HP. If you notice that the temps are 40 degrees, you can easily do the math. In the summer these same cars will make a LOT less hp (and most of them did). If it was 70 degrees, we'd lose 10%. On a 500 hp car, that's 50 hp. On a 400, that's 40. A lot of places are still 80 degrees doing dyno pulls.
I know each of you has driven your car when it's cold outside and noticed the extra power. These pulls are basically the power created during that time.
This last summer, we had a lot of people during our dyno sessions that made only a couple percent more than Surgeline and PIA's mustang dynos. This was due to the temperature being the same at both facilities.
Old 01-12-2010, 09:02 PM   #21
Maxwell Power
Member#: 190729
woops wrong thread. Thought this was craigs car.
do you have cams and a built motor? Cams make a HUGE difference.
Old 01-12-2010, 09:20 PM   #22
Gray Ghost
Member#: 162790
Nice stuff Dom. Sounds like you guys are kicking a** up there Keep up the great work!
For reference my stock '09 STi made 260 whp on this dyno last summer before final calibrations to the dyno were done.
Gray Ghost is offline   Reply With Quote
Old 01-12-2010, 09:21 PM   #23
Maxwell Power
Member#: 190729
thanks man,
haven't seen you guys in a long time. You still local?
Old 01-12-2010, 09:35 PM   #24
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
What did this car make SAE?
RealStreet is offline   Reply With Quote
Old 01-12-2010, 09:39 PM   #25
Phatron
Member#: 36033
CEO PhatBottiTuning
^^^ its in the first post
Maxwell Power Dyno Tune: 2.5L SOHC + GT3071R = 512ftlbs of torque Maxwell Power Proven Power Bragging 102 12-11-2012 09:19 PM
Dyno Tune: 09' WRX STOCK, makes 240whp. (reasonable?) Breezio Proven Power Bragging 32 02-20-2012 11:13 PM
Dyno tune: 06 wrx ej257 VF37 91 octane Camtuned DigitalPunk Proven Power Bragging 17 12-14-2011 12:03 PM
Maxwell Power Dyno Tune: 2.5L Hybrid + GT35R = 588whp Maxwell Power Proven Power Bragging 47 12-31-2009 06:31 PM
Dyno Tune: 08 WRX 2.5L with TD06 18G 8CM^2 Makes 285.6 WHP N1KN4K Proven Power Bragging 26 11-26-2009 03:12 PM
