Old 01-05-2010, 11:47 PM   #1
builtsubie
Member#: 226788
Default Compession test prob
I did a compression on my 06 sti it has drop in wiseco pistons an bc 272 cams i did it on a coldmotor b/c the car has no turbo on it an these are theses are the numbers i got 120-95-110-110 is that normal with drop ins an acoldmotor? thanks
builtsubie is offline   Reply With Quote
Old 01-05-2010, 11:57 PM   #2
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Um... wat
You did it on a cold motor. That's most of your problem.
How many miles on the built motor?
Chi_San is offline   Reply With Quote
Old 01-06-2010, 12:13 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
warm it up and repeat. That's my vote. 95 is quite low in comparison to 120.
Old 01-06-2010, 12:30 AM   #4
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
agreed.
Do it warm, but i agree 95 is the odd ball. Hopefully it cleans up when warm.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 01-06-2010, 02:10 AM   #5
builtsubie
Member#: 226788
well i havent started the car in 5 days bf doing this test thebmotor has about 3000 mileson it
Old 01-06-2010, 11:18 AM   #6
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
that is a little funky. can you try a leakdown test?
kevinh211 is offline   Reply With Quote
Old 01-06-2010, 11:56 AM   #7
Chi_San
Member#: 53558
2005 Baja Sport
Yeah, a leakdown test when cold is just as useful as a compression test when cold.
Old 01-06-2010, 02:09 PM   #8
builtsubie
Member#: 226788
i now did the compression test on a warm motor i let the car warm up an i got 120 each for all four about 119-120 if that normal thanks
Old 01-06-2010, 03:49 PM   #9
builtsubie
Member#: 226788
could the bc 272 cams an wiseco pistons lower the compression? another thing its lowing white smoke from oil filler cap an the 2 hoses that come off the valve covers im puzzled all the cylinders are the same 120. the onlything im thinking is jummping timing on the motor??
Old 01-06-2010, 04:28 PM   #10
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
blowing smoke out of the filler usually isn't a good thing,it should suck n blow
sense of nature is offline   Reply With Quote
Old 01-06-2010, 09:17 PM   #11
builtsubie
Member#: 226788
? anyone have an idea
Old 01-07-2010, 06:00 AM   #12
builtsubie
Member#: 226788
bump!
Old 01-07-2010, 07:31 AM   #13
iluvdrt
Member#: 46248
82 Brat
Tan
White smoke is water. I bet you have a bad HG or the water pipe seals between the block halves is bad. Are you getting milky film in the oil cap after letting it run for awhile? Check the oil level after running it. Is the oil level rising? I think you should drop the oil pan and pressure test the coolant system to see where the water is getting in.
A little bit of blue or black smoke is generally OK from those areas but not white.
iluvdrt is offline   Reply With Quote
Old 01-07-2010, 01:32 PM   #14
builtsubie
Member#: 226788
im lost im not sure how that can be when i have arp headstuds im not
saying it cant be im checking my timing today
Old 01-07-2010, 05:46 PM   #15
iluvdrt
Member#: 46248
82 Brat
Tan
Headstuds are not a Guarentee aginst blown HG's. They also do nothing for the seals in between the block halves.
Hopefully neeither of those is what's wrong, but white smoke is always some sort of condensation or water.
Old 01-11-2010, 01:46 AM   #16
builtsubie
Member#: 226788
the oil looked fine it just smelled lil like gas idk why bit is 120 on all 4 bad for the compression test the oil level was the came i just dont understand this smoke coming from thefiller caps an the valve cover vents.
p0301! compession test? greenspeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-16-2009 12:24 AM
compession check blazin sti Subaru Conversions 2 01-21-2006 11:57 PM
how accurate are compession/leakdown tests BlackoutWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 06-02-2005 03:52 AM
Directx 9, are they still beta testing? anyone have any probs with it bobturismo Off-Topic 0 02-23-2004 02:31 AM
Guys running a catless down-pipe and cel fix.Any probs with OBDII testing? Camperguy New England Impreza Club Forum -- NESIC 7 08-11-2003 07:51 PM
