Old 01-06-2010, 12:49 AM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default EJ20G Parallel fuel rail mod
Well i have been working on it for the last week... looks like it is going to work awesome. just have to get it in the car and see how it works...
The AN adapters going right into the rails were turned down on a lathe and silver soldered on. said to hold up to 3000PSI... We'll see...
This will go nicely with my VF37 sitting in the back of the manifold. And the 2.5l block it is sitting on... notice the spacers between the intake and the heads... this will allow me to run a front entry turbo (also have to change to a EJ20K P/S pump, but that is already on the car)
-=Suberdave=-
www.suberdave.com
suberdave is online now   Reply With Quote
Old 01-06-2010, 01:10 AM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
looks good...but of course anything with SS braided hoses does
did you smooth out the manifold???
Cbgrandtheftauto is offline   Reply With Quote
Old 01-06-2010, 03:37 AM   #3
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
damn nice!
route69wrx is offline   Reply With Quote
Old 01-06-2010, 08:49 AM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Very nice. I have a 20G manifold sitting on m work bench and was debating about doing this but didn't know a good way of modifying the rails for the AN fittings. Looks like -6 lines - correct?
beaviscih is offline   Reply With Quote
Old 01-06-2010, 09:14 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
i gasket matched the ports, they looked like poo...
Originally Posted by route69wrx View Post
damn nice!
Thanks
yeah -6 AN. after looking at the stock rails and line sizes i thought anything much larger would be way overkill for my build.
-=Suberdave=-
Old 01-06-2010, 11:05 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Looks terrific! Want to do the same when I'm building my EJ20K/G hybrid
Marnix is offline   Reply With Quote
Old 05-12-2010, 10:24 PM   #7
TRBO_BXR
Member#: 75835
1992 dontask
white
-=Suberdave=-
www.suberdave.com
Did you have them add it to the ends? Silver that is. Been wanting to do this meself.
TRBO_BXR is offline   Reply With Quote
Old 05-13-2010, 02:53 AM   #8
sniper512
Member#: 189923
1993 JDM WRX
So stock EJ20G heads on a EJ257 block or EJ25D with which head-gasket thickness? . Really nice fueling solution.
sniper512 is offline   Reply With Quote
Old 05-13-2010, 07:24 PM   #9
suberdave
Member#: 101865
88 GL-10 STi
Engine Specs:
2005 EJ257 Block, crank, rods
1997 STI EJ20K Heads (Pollished Intake Ports)
JE Deep Dish Pistons\
STI Head Gaskets / will give me 8.75:1-8.80:1 compression ratio
1997 STI EJ20K Cams
1996 EJ20G intake manifold (ported and painted) and wiring
1996 EJ20H Timing Belt Covers
2003 EJ207 VF37 Twin Scroll Turbo
1" Intake Spacers to allow front inlet turbo
Phenolic intake spacers
EJ20K Power Steering Pump
ViPEC standalone ECU (Currently in the car)
ARP Head Studs
Gates HP Timing Belt
Excedy Twin Disc clutch
Custom Built -6 AN Parrallel Fuel Rails
Sard Fuel Pressure Regulator
-=Suberdave=-
Old 05-13-2010, 10:18 PM   #10
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
in and running yet?
azn0boi04 is offline   Reply With Quote
Old 05-14-2010, 01:05 AM   #11
suberdave
Member#: 101865
88 GL-10 STi
yeah been driving it for 2 weeks now...
have to get a few more miles on it, then i will be taking it back to the dyno and tuneing it...
-=Suberdave=-
Old 05-14-2010, 11:41 AM   #12
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
sweet i wanna come by today to take a quick look, actually maybe this weekend some time.
Old 05-14-2010, 07:44 PM   #13
suberdave
Member#: 101865
88 GL-10 STi
give me a call and we will meet and talk...
-=Suberdave=-
Old 05-14-2010, 07:47 PM   #14
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
post some numbers when you dyno it...Im curious on how much it will make
Old 03-31-2011, 03:10 PM   #15
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Hi, First thanks for making the thread with the great picts! I have a NOOB question but I am in the middle of doing this and am wondering with the stock rails gone there is no longer the metal vacuum lines for the charcoal canister, what do I do with this can I just take off the hose that normally connects the stock rail to the metal line that goes into the firewall and runs back to the canister and leave it open? Or do I need to do something else? car is a 2000 rs and the engine is a 1996 v2 sti if that matters or helps.
Thanks in advance,
Jesse
spackyscooby is offline   Reply With Quote
Old 04-01-2011, 05:05 PM   #16
sneaky
Member#: 200316
nice work dave
sneaky is offline   Reply With Quote
Old 04-01-2011, 08:30 PM   #17
suberdave
Member#: 101865
88 GL-10 STi
I did connect up the Charcoal canister. i just used rubber lines not the medal lines. as you can see in this picture.
-=Suberdave=-
Old 04-02-2011, 10:33 PM   #18
turboedbug
Member#: 155981
1969 vw bug
ej20k ems stinger 4424
-=Suberdave=-
sorry to hyjack this or what ever.....wheres this dyno at, I see your in western washington.....my car is close to road worthy so here soon I would like to get some tuning done
turboedbug is offline   Reply With Quote
Old 04-03-2011, 01:56 AM   #19
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
Ok thanks, one more question. I have been told but just want to make sure, in the pict #4 is the vacuum port that I will run to the charcoal canister correct?
Old 04-07-2011, 01:22 PM   #20
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
-=Suberdave=-
Slightly Off topic but looking at your engine bay there are lines running away from black boxes the top of your struts. What do those lines go to? What kind of shock/strut/coil setup is that?
Btw nice parallel fuel rail setup
TommyAtomic is offline   Reply With Quote
Old 04-07-2011, 03:26 PM   #21
sneaky
Member#: 200316
Its Tein's EDFC, the electronic control of the dampening. Can be used on the higher end Tein coilover setups.
http://www.tein.com/products/edfc.html
Parallel fuel rail mod - evap line jasona Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-19-2011 04:51 PM
Series to Parallel fuel Rail Mod. 2TG8V Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-15-2006 01:10 PM
anyone done the parallel fuel rail mod? brazymstrp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-01-2004 02:29 PM
Question on finding parts for the series to parallel fuel rail mod Legacy777 Normally Aspirated Powertrain 1 02-24-2003 09:06 AM
Parallel Fuel Rail Mod Queston Skidd Normally Aspirated with bolt-on Forced Induction Powertrain 26 01-27-2002 11:59 AM
