Old 01-06-2010, 07:01 AM   #1
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Default p1443 and trouble filling tank
I threw p1443 and it isn't the phantom one from the early 02s because I also cannot fill the gas tank because the air in the tank is not venting fast enough when I pump.
Anyone ever have both of these symptoms? Nothing is visibly wrong with the charcoal box or the hoses. I'll take it off soon and double check.
Anything else I should look at?
Agkelos is offline   Reply With Quote
Old 01-06-2010, 10:56 AM   #2
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Bump for ideas, I have the canister off, no cracks. Hoses look fine.
I think there is water in the system. This problem only happened after the weather dropped below freezing, and is harder to fill the tank when it is colder out.
Is there anything I can put in the tank to eliminate the water? A friend mentioned a product called "Heat", anyone ever use this?
Old 01-06-2010, 11:04 AM   #3
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
May have solved it.
One of the hoses, the one which goes to a valve then a filter then to the atmosphere.
I was feeling for cracks in the hoses, when I found this hose. It was hard, so I figured it was a metal one. Well, 30 minutes in a warm garage (which it hasn't seen in a long time) and the hose is no longer "metal".
I pull it off and dump out a ton of water and ice chunks.
Going to reset the ECU and watch it. If anyone else has this problem during the winter months, I think this may be the fix.
Still would like a comment about using "Heat" in these cars.
Old 01-19-2010, 10:42 AM   #4
zer0max713
Member#: 38363
2002 Impreza 2.5
Red
So I am having the same problem P1443 on my 2002 Subaru 2.5 TS. I just bought the car and had it for less then a week when this CEL came up. It looks like the canister was replaced because it looks pretty new. I will try later to take the hoses off and see if there is anything stuck in there. If that is clear which other steps can I take to try to resolve this CEL and gas filling issue? I had no issues filling my take the day I bought it, but since then it’s been a pain in the A$$... Any tips or tricks would be greatly appreciated. Thanks!
zer0max713 is offline   Reply With Quote
Old 01-19-2010, 10:55 AM   #5
dfwbugeye
Member#: 217269
2002 bugeye
MBP
I too have this problem it only started bout a month ago i dont know if its winter related but i have searched up and down for answers not much help out there. Hopefully someone can here help.
dfwbugeye is offline   Reply With Quote
Old 01-19-2010, 03:50 PM   #6
zer0max713
Member#: 38363
2002 Impreza 2.5
Red
anyone?
Old 01-19-2010, 10:12 PM   #7
spinningcain
Member#: 176490
2005 STI
Same issue here... I curred it for 1 fillup by blowing out the lines at the canaster but now its back
spinningcain is offline   Reply With Quote
Old 01-20-2010, 10:21 AM   #8
dfwbugeye
Member#: 217269
2002 bugeye
MBP
The world's largest Subaru commmunity and still no answers? im puzzled
Old 01-20-2010, 10:35 AM   #9
Mekks
Member#: 219749
yea, i had this problem... and then the cell. looking for the part number 2 sec.
Mekks is offline   Reply With Quote
Old 01-20-2010, 10:44 AM   #10
Mekks
Member#: 219749
42084FA120 Vent Valve
This evap vent solenoid fixed my problem, was a easy fix other than the bolts being rusted and then snapping. I just zip tied the new one in place LOL.
Old 01-20-2010, 11:58 AM   #11
dfwbugeye
Member#: 217269
2002 bugeye
MBP
k ill try this and post my results here as well
Old 01-20-2010, 12:00 PM   #12
zer0max713
Member#: 38363
2002 Impreza 2.5
Red
How much was the part and were did you get it? How long have you had it installed, and working?
Old 01-20-2010, 01:01 PM   #13
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Make SURE there is no water in the hoses.
I had a lot. It froze again after I emptied it. 90 miles later.
Before I could empty it again, it got above freezing and the CEL went away. I still need to get out the extra water.
Old 01-21-2010, 11:55 AM   #14
dfwbugeye
Member#: 217269
2002 bugeye
MBP
Thanks to subaru engineers/design team to put that right behind the tire were all the dirty/water/slush/snow goes
Old 01-21-2010, 11:57 AM   #15
Agkelos
Member#: 58163
2002 Stage 2 WRX
World Rally Blue
Not to mention only 2 of my hoses were even clamped. All the others I could remove with one hand.
Old 01-21-2010, 03:38 PM   #16
zer0max713
Member#: 38363
2002 Impreza 2.5
Red
Ok so i received a call back from somone at the subaru service center and i was told that there is air in the tank and that is why i cannot fill it up. The sensor in the gas cap throws this CEL and how to resolve it is to shake the car to get the air buble out. (haha) shaking the car? i mean this sounds so out of whack... has anyone heard this before i mean i heard of the "spider web" problem but shaking the car?
Old 01-21-2010, 11:44 PM   #17
spinningcain
Member#: 176490
2005 STI
Old 01-22-2010, 01:16 AM   #18
ledzeppelin240
Member#: 227951
2004 Impreza WRX
When you fill your tank up the air has to be displaced somewhere and since venting fuel vapousr to the atmosphere is frowned upon this is what happens:the air travels from the tank through a line, to the charcoal canister, then to the canister close valve, then to the evap filter (simple explanation). I would guess there is either a problem with the line being pinched/blocked, the canister close valve stuck closed, or a dirty/blocked evap filter.
ledzeppelin240 is offline   Reply With Quote
Old 01-22-2010, 01:17 AM   #19
dfwbugeye
Member#: 217269
2002 bugeye
MBP
this has to be a joke.....
Old 01-29-2010, 09:42 AM   #20
Mekks
Member#: 219749
anyone replace the part i listed? let me know if it works for you also!
Old 06-04-2010, 01:30 PM   #21
dfwbugeye
Member#: 217269
2002 bugeye
MBP
Im sorry i hadnt got time to post my results. But yes installing this part resolved the problem. It took about two weeks though for the problem to finally go away after install dont know why.
Old 08-31-2010, 11:08 AM   #22
abosworth
Member#: 53856
2012 Speed3
Red Mica
I'm bumping this because I had the same code and replaced this part and the code hasn't come back. Just posting to help confirm that replacing the mentioned part fixes the code.
Mine were all rusted too. I snapped one of the charcoal box bolts but was able to get one of them off without breaking it. I ended up having to snap the mounting bracket on the old VV to get it off and then I just zip tied the new one. Kind of ghetto but it works and it will be much easier to snip a couple zip ties than deal with those crappy, rusty bolts again.
abosworth is offline   Reply With Quote
Old 08-31-2010, 11:04 PM   #23
classicaddict
Member#: 220619
04 wrx wagon
So I am having the same problem P1443 on my 2002 Subaru 2.5 TS. I just bought the car and had it for less then a week when this CEL came up. It looks like the canister was replaced because it looks pretty new. I will try later to take the hoses off and see if there is anything stuck in there. If that is clear which other steps can I take to try to resolve this CEL and gas filling issue? I had no issues filling my take the day I bought it, but since then itís been a pain in the A$$... Any tips or tricks would be greatly appreciated. Thanks!
i have noticed while in NJ those gas station goons like to top off the tank......ALOT. this can cause gas to actually get into the canister then causing the CEL and unability to fill tank.
classicaddict is offline   Reply With Quote
Old 12-13-2010, 03:13 PM   #24
SnowWhite07
Member#: 237536
2007 WRX TR
Satin White
Well i just got this code. Thanks to mekks for posting part number. Gonna go exploring and see first if it is a simple clogged hose issue. if not i will order part and see if that fixes it. And i will then post the results.
SnowWhite07 is online now   Reply With Quote
Old 02-22-2011, 09:43 PM   #25
abosworth
Member#: 53856
2012 Speed3
Red Mica
What ended up happening? Did you replace the part or was it just a clogged hose or something?
Problem filling tank (05 Sti) th1rd3y3 Newbies & FAQs 35 08-27-2012 12:04 PM
trouble filling gas tank. bad evap system? orionh2215 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 04-21-2010 12:21 PM
WTB: NEED thie radiator fill tank from WRX BADLY! Norcalrallyist Private 'Wanted' Classifieds 2 07-20-2007 08:21 PM
relocating coolant fill tank DJSuperSoul Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-05-2007 09:24 PM
odd...having trouble filling tire shemoves Tire & Wheel 2 08-30-2005 02:42 PM
