#1 |
Member#: 35596
South East
Vehicle:03 wrx wrbp |
hey guys, i am having a problem with the car.. i was getting a check engine light for the crankshaft position sensor. i replaced the sensor and it still comes on. any ideas? also my car never wants to start in the morning. so i go to work come home and it starts right up. i dont get it but its making me crazy. i called subaru two days ago to get an estimate on a valve cover gasket because i think that is leaking too @ about 4:30pm the guy tells me i will call you in the morning.. i waited..no call. called him back at about 4:30 another guy says he will call you in 10 mins he had my name and number right there the guy never calls back so im about to call them back but i think its just plain crazy that these guys dont want my money.. has anyone changed a valve cover gasket? if so how hard is it going to be. i know its a tight fit..
PLEASE HELP. thanks, Mike
#2 |
Member#: 176490
SWIC
Vehicle:2005 STI WRB |
not to hard.. Look for a writeup
#3 |
Member#: 35596
South East
im not too worried about the valve cover gaskets at the moment. i am more worried about getting the car to even start.. these two items ------>
"hey guys, i am having a problem with the car.. i was getting a check engine light for the crankshaft position sensor. i replaced the sensor and it still comes on. any ideas? also my car never wants to start in the morning. " i tried heating stuff up with a hair dryer but it didnt help |
#4 |
Member#: 151045
Vehicle:2013 Subaru STI CBP |
What's the exact CEL code? The service manual should have a good list of items to check to diagnose the issue with the CPS.
#5 |
Member#: 193874
BAIC
Vehicle:2003 Impreza WRX Sonic Yellow |
I've seen a few cars come in with messed up wiring for the CPS. Trace it back a bit and see if it got buggered up.
#6 |
Member#: 151045
Just to add to that--a couple nasioc members had one of the wires pull right out of the electrical plug for the CPS. Looked like the wire was jammed in there, but not properly electrically connected.
#7 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
and just an FYI here
WAY too many of these happen because somebody---in a galaxy long long ago......posted a DIY on doing a turbo swap....which includes instructions on how to make the car crank and not START to pre-lube the turbo.... and these instructions FALSELY and ERRONEOUSLY include the ABSOLUTELY ABSURD AND TOTALLY UNNECESSARY STEPS OF UNPLUGGING THE CAM AND CRANK ANGLE SENSORS WHICH POINTLESSLY AND NEEDLESSLY MAKES ****ING THEM UP AN ALL TOO OFTEN REALITY ![]() ![]() ![]() ![]() ![]() and ALL you have to do is PULL THE ****ING 'IGN' FUSE AND NO ****ING WITH THE CAM AND CRANK SENSORS IS NEEDED OR WANTED ![]() S0000000000 kiddies..........if you do any turbo swap and the instructions include disconnecting ANY sensors to pre-lube the turbo after install DON'T |
#8 | |
Member#: 16200
do NOT take the car to Eddie Accardi Subaru ![]() ![]() ![]() THAT would be a mistake |
#9 |
Member#: 35596
South East
ok i figured out why she wasnt starting.. needed a new starter.. going to pick that up in a bit. now i am still needing to find out why i am getting a check engine code for the the crank position sensor..
Haelan: the exact code was/is P0335 Crankshaft Position Sensor Circuit Malfunction. do you have a service manual handy so i can get a good list of items to check to diagnose the issue with the CPS. i will look at the wiring when i get back from getting the starter.. thanks guys. |
#10 |
Member#: 35596
South East
i also wanted to ask about oil in the intercooler and throtle body, when i was removing the i/c for access to the starter. i found the oil in there. should i be worried? please give me some in put on that as well.
#11 |
Member#: 151045
You do know that a malfunctioning CPS will cause your vehicle to not start, right? How did you determine it is the starter--I'm assuming it's not cranking over?
The only thing the services manual mentions is checking the CPS (which you already replaced), the wiring harness, and the connection at the ECU. Some oil in the intercooler and throttle body is normal. Blowby tends to accumulate in those areas so unless it's a small lake of oil--don't worry about it. |
#12 |
Member#: 35596
South East
no i did not know that..
i think the starter was going because.. when i put the key in and turned it sometimes it took a second or two for the engine to start then sometimes nothing happens when i turn the key just a click when i let the key go. its been intermittent. i hit it with a screwdriver and it started. i still havent looked at the wiring yet. so i will check that. whats the best stuff to clean the intercooler with? will brake cleaner work or should i just simple green it. |
#13 |
Member#: 151045
#14 | |
Member#: 16200
d0000000000d....if the sensor is dirty or the sensor is bad it wont want to start if it isnt unplugged it IS bad replace it the damned cel code is TELLING YOU WHAT IS WRONG stop screwing around with the damned starter and the bloody intercooler |
#15 |
Member#: 102808
Vehicle:2002 v8 EJ207 v7 6spd FP Green |
its called blow by, search it.
#16 |
Member#: 35596
South East
come on scotty dont be a tard here. I REPLACED THE SENSOR ALREADY!!!!!!! the starter was part of the problem.. the starter is rebuilt and installed and i havent had a problem with it yet.
#17 |
Member#: 90438
check the wiring to the cps. i had my one wire literally fall out of the connector to the cps and the car still started but drove HORRIBLE. it eventually stopped starting and wouldnt turn over. I got a spare connector, soldered it on and havent had a single cps issue since.
| Thread Tools | |
| Display Modes | |
| My car probably won't start in the morning due to cold. What should I do? | bruticus | Service & Maintenance | 22 | 01-15-2004 12:15 PM |
| My car probably won't start in the morning due to cold. Any suggestions? | bruticus | Tri-State Area Forum | 8 | 01-14-2004 01:08 PM |
| Thoughts about starting the car in the morning, and commute | Karl | New England Impreza Club Forum -- NESIC | 2 | 05-12-2003 08:11 AM |
| Noise on start up in the morning... | Karl | New England Impreza Club Forum -- NESIC | 5 | 07-23-2002 10:16 PM |
| car wont start in the cold | gallstone | Normally Aspirated Powertrain | 2 | 01-08-2002 04:03 PM |
