Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 01-06-2010, 01:13 PM   #1
andron
Member#: 55901
Default Both low-beams went out at the same time..help!
As I was driving yesterday, I noticed both of my headlights suddenly went out. High beams still work, as do the turn signals, but both the low beams and DRLs went out. I checked the headlight relays under the hood, and they both are good - I tried them in the horn relay slot, and it worked fine. The car is a 06 2.5i, btw.
Any ideas?
andron is offline   Reply With Quote
Old 01-06-2010, 02:19 PM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Did you check the fuse or the bulbs themselves?
Old 01-07-2010, 10:34 PM   #3
joewinchell22
Member#: 234573
2007 STI
Crystal Grey
i had the same problem both of my low beams and fogs went out would that be a switch or relay ?
joewinchell22 is offline   Reply With Quote
Old 01-09-2010, 07:59 PM   #4
04.STI
Member#: 36812
my lowbeams dont work either!! help im driving around on high beams like a moron!
04.STI is offline   Reply With Quote
Old 01-10-2010, 12:28 PM   #5
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
There are several places the trouble may be at. First check fuses 13 and 18 in the dash fuse panel. If they both have power getting through them then you need to check the DRL relay and the DRL module for trouble. The relay makes a common ground for both the low beam and DRL modes so make sure that is ok.
Old 01-10-2010, 10:19 PM   #6
billstein
Member#: 234787
2007 Forester XT
If you tapped into your headlights to power fog lights, another relay etc, it could have shorted and taken out the fuse, the bulbs, or the relay. Or could be sheer coincidence. Bulbs could have been both near their end and a voltage spike could have taken them out at the same time. Try playing around with a voltmeter/multimeter and see what's going on. See if there is any voltage flowing to the bulb socket.
billstein is offline   Reply With Quote
Old 01-10-2010, 11:28 PM   #7
gagliano
Member#: 39541
2002 WRX & 2004 STI
WR Blue
Another possibility could come from running bulbs that are a higher wattage rating than the stockers. This will cause the wiring to burn up.
gagliano is offline   Reply With Quote
Old 12-16-2010, 09:34 PM   #8
Impreza4Life42
Member#: 234461
Sedona Red Pearl
Lightbulb Headlight help
I know this is an old post but it happened to me. I bought my '06 WRX Ltd. in Feb. this year. 5 months later I lost 1 low beam and found both bulbs to be bubbled outward in same spot on bulb. Put 2 new "xenon" bulbs in. Looked/worked great for 6 months til I was leaving work the other night and as I turned my low beams on they both came on and cut out together in an instant. Replaced low beam bulbs now running lights and low beams both have passenger side dimmer than driver side by a lot and both sides have high beam bulb barely lit. When I switch to high beams passenger side low beam goes out completely along with barely lit high beam and driver side high and low are full power. Switch back to low and passenger side low beam slowly gets back up to dim along with high barely lit on both sides. Running lights behave same as lows.
Fuses and relays all seem fine. 12 volts getting to the bulbs. Tried grounding directly but didn't brighten the passenger low beam or change the behavior.
Any ideas?
Impreza4Life42 is offline   Reply With Quote
Old 12-16-2010, 09:51 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Any ideas?
Either the passenger side headlight fuse is blown or the wiring is damaged. Fix it and then stop using crappy bulbs, replace them with OEM-grade standard wattage ones to prevent further problems.
Old 12-16-2010, 10:37 PM   #10
Impreza4Life42
Member#: 234461
Sedona Red Pearl
Question
"Fuses and relays all seem fine. 12 volts getting to the bulbs. Tried grounding directly but didn't brighten the passenger low beam or change the behavior."
and all three sets have been standard wattage
Old 12-16-2010, 10:40 PM   #11
Impreza4Life42
Member#: 234461
Sedona Red Pearl
If it's grounding fine and theres plenty of juice getting there then what other wire damage could cause this?
Old 12-17-2010, 03:07 AM   #12
Cougar4
Member#: 53443
Winestone
The contacts in the bulb socket may be bad. Make sure there is no voltage drop on the ground side of the bulb indicating a bad ground connection.
Old 12-18-2010, 05:45 PM   #13
Impreza4Life42
Member#: 234461
Sedona Red Pearl
Thanx. Will check out the socket.
Old 03-03-2011, 05:47 AM   #14
04ts
Member#: 57517
2010 Impreza WRX Ltd
Satin white Pearl
Any ideas?
bump. i have this problem now on my 2004 ts.
anybody have any ideas?
braved the cold and here's what i found:
there is a clicking noise under the glove compartment when i turn the low beam headlight switch to on position,
maybe the relay is ok (?).
i tested the pass. side low beam headlight with a light tester. when grounded on the chassis, there is power. but, when i use the ground wire that is connected to the bulb, there is no power.
04ts is offline   Reply With Quote
Old 03-03-2011, 10:10 PM   #15
Cougar4
Member#: 53443
Winestone
See if you can manually turn on one side of the low beams by turning the light switch on for them and then tie a jumper wire to chassis ground and touch it to the the GROUND return side of the low beam light. If the light tuns on then the switch connection to ground is the trouble. The click you are hearing is most likely the the DRL relay that switches the ground from the resistor to the ground connection through the light switch. If the DRLs are working then the relay is most likely were the trouble is at. If it isn't then see if grounding the yel/grn wire going to the relay turns the lights on. If that works then the light switch contacts are the trouble and not making the ground connection.
both High beam and Fog light bulb went out at the same time :( Mike7 Electrical & Lighting 1 09-28-2009 11:30 AM
Pulling window/regulator/motor all out at the same time? BlackoutWRX Interior & Exterior Modification 0 09-01-2007 01:08 PM
both low beams went out at the same time, huh? pumpkyn Electrical & Lighting 5 08-28-2007 08:12 PM
V7 Diagram for High and low beams at the same time WRS Electrical & Lighting 1 08-12-2005 10:33 PM
High beams, low beams, & fogs at the same time il96 Electrical & Lighting 0 03-10-2003 10:08 AM
