Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 01-06-2010, 05:00 PM   #1
q_dubz
Member Sales Rating: (1)
Member#: 168482
Default FS: FP red 8cm...leaking seals...cheap
Sold.
q_dubz is offline   Reply With Quote
Old 01-06-2010, 06:20 PM   #2
CapeStylz
Member#: 151261
2005 LGTW 5mt stage3
Do you know ball park price on the rebuild?
CapeStylz is offline   Reply With Quote
Old 01-06-2010, 06:22 PM   #3
toyjunkie
Member Sales Rating: (40)
Member#: 177315
2004 sti
wrb
rebuild is 400 and up depending on damage
toyjunkie is offline   Reply With Quote
Old 01-06-2010, 08:29 PM   #4
CapeStylz
Member#: 151261
thanks
Old 01-06-2010, 09:21 PM   #5
q_dubz
Member#: 168482
yup...talked to FP it can go as high as 900 but looking at this turbo which i can get pics of its not that bad.
Plz note i did say OBO
Old 01-07-2010, 07:03 AM   #6
q_dubz
Member#: 168482
before heading to work bump!
Old 01-07-2010, 01:15 PM   #7
C4NiNjA
Member Sales Rating: (10)
Member#: 91964
2003 Impreza WRX WRB
From the FP website.
A typical turbo rebuild is $410.00, and involves the following steps:
* Complete disassembly and inspection - turbos we receive are identified, marked, and torn down to component level. Each part is inspected for wear and/or damage, and cause of failure is identified.
* Cleaning and sandblasting - Turbine and compressor housings, bearing housing, and turbine wheel are stripped and refinished. If your housings are specially coated, we clean them with solvents to avoid damage to the coating. The bearing housing is refinished, flushed with solvent and honed before being cleaned, and the turbine shaft is polished to a mirror finish.
* Blueprinting - Journal bearing bores are honed and sized for proper for oil clearance. All parts and components are checked and verified against specifications.
* Reassembly - Turbo is reassembled with new journal and thrust bearings, o-rings, piston rings, fasteners, thrust collars, and seal plates.
* Balancing - All rotating components are double plane balanced as individual parts prior to assembly. After assembly the CHRA is dynamically double plane balanced as a complete CHRA to less than half the manufacturers allowable limit to verify the integrity of the CHRA and obtain the most perfect balance possible.
If you have questions about getting your Forced Performance turbocharger diagnosed or repaired, drop us a line at [email protected]
C4NiNjA is offline   Reply With Quote
Old 01-07-2010, 05:55 PM   #8
q_dubz
Member#: 168482
bingo^^
home from work bump
Old 01-08-2010, 05:58 AM   #9
q_dubz
Member#: 168482
TGIF Bump!
Old 01-08-2010, 07:36 PM   #10
q_dubz
Member#: 168482
bump!!
Old 01-10-2010, 10:58 PM   #11
q_dubz
Member#: 168482
up up up!
Old 01-11-2010, 07:38 PM   #12
q_dubz
Member#: 168482
pics added... price adjusted
Old 01-13-2010, 07:12 PM   #13
q_dubz
Member#: 168482
Old 01-16-2010, 01:57 AM   #14
q_dubz
Member#: 168482
2 de t0p
Old 01-18-2010, 10:46 AM   #15
q_dubz
Member#: 168482
movin on up
Old 01-21-2010, 05:25 PM   #16
q_dubz
Member#: 168482
Bump...come on people....you can lowball me!
Old 01-21-2010, 09:48 PM   #17
bjohnson_55
Member Sales Rating: (14)
Member#: 216580
I just paid $250 for a blown fpred, if you wanna match that pm me
bjohnson_55 is offline   Reply With Quote
Old 01-21-2010, 10:05 PM   #18
chucker04
Member Sales Rating: (4)
Member#: 193550
2004 Impreza WRX STi
Java Black Pearl
Default Re: FS: FP red 8cm...leaking seals...cheap
Pm sent
chucker04 is offline   Reply With Quote
Old 01-22-2010, 05:41 PM   #19
q_dubz
Member#: 168482
why would you want another one??
PM's responded.
Old 01-24-2010, 01:39 PM   #20
q_dubz
Member#: 168482
bumpitis
Old 02-06-2010, 01:51 PM   #21
chucker04
Member#: 193550
Java Black Pearl
Paid you over a week ago, still have not recieved or heard from you, where is my turbo?
FS: FP red 8cm...leaking seals...cheap q_dubz MAIC Private Classifieds 12 01-24-2010 01:40 PM
FS: *BLOWN* FP Red 8cm yoshi8me Engine/Power/Exhaust 4 01-04-2010 10:05 PM
FS: FP RED w/ 8cm Hotside!!! like new renosfasteststi Engine/Power/Exhaust 11 03-21-2008 10:01 AM
FP red 8cm housings mllrsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 09-07-2006 09:15 PM
FP red 8cm internally gated turbo Peeblesmx445 Private 'For Sale' Classifieds 21 01-16-2006 10:57 PM
