South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-06-2010, 11:15 PM   #1
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
Unhappy Octane problem in new mexico
i came from washington where they sell 92 octane at every pump, and my maps are for 93. wondering where u can find good gas in las cruces.
michael_cano is offline   Reply With Quote
Old 01-06-2010, 11:16 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
You can't.
fibuz is offline   Reply With Quote
Old 01-06-2010, 11:26 PM   #3
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
lol, i know this place is like satans a**hole!
Old 01-07-2010, 03:03 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Your only hope is too retune for 91 or switch to E85 with what that entails.
blkscooby is offline   Reply With Quote
Old 01-07-2010, 03:30 PM   #5
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I had to get retuned for 91 in Chicago for the lack of 93 here in Cruces :-/ Still put down 300HP on the Dyno at P and L!
wgr73 is offline   Reply With Quote
Old 01-07-2010, 04:27 PM   #6
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
^^^^^^^^^^^^^not to get off topic, i think i saw you last night on triviz, nice exhaust that car is beautiful, i was behind you when i turned right on n.main and you went straight on elks
Old 01-08-2010, 07:49 AM   #7
shwoop_soobie
Member#: 102323
99 power poles
beware
heck i have been to some places in utah and nm that dont even have 91oct
shwoop_soobie is offline   Reply With Quote
Old 01-08-2010, 08:03 AM   #8
SpodeOne
Member#: 229077
2002 WRX Wagon
yeah a lot of the gas stations out here don't even have 91 most of them only go up to 90.
SpodeOne is offline   Reply With Quote
Old 01-08-2010, 10:04 AM   #9
ktmrider
Member#: 125687
2005 Legacy GT - 6MT
If you don't mind the 20 mile drive goto Anthony. The TX side sells 93 ( or at least they did a few years ago ).
FWIW the higher altitude acts as a natural detonation buffer, one reason they don't sell 93 in NM, AZ, or CO.
ktmrider is offline   Reply With Quote
Old 01-11-2010, 03:32 PM   #10
blkscooby
Member#: 44422
2009 G8 GT
How do you figure? Higher altitude means thinner air, means turbo has to work harder to reach same boost target (pre-turbo/ post-turbo compression ratio is higher), means hotter discharge air (due to declining turbo efficiency), means more tendency to knock. That is assuming the same boost is being targeted at all altitudes.
Now, also depends on the tune as there is a compensation table for altitude that reduces the maximum boost, but it has to be used properly. But regardless, it is not a positive effect of higher altitude.
Old 01-11-2010, 04:39 PM   #11
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
I actually talked to the President of Kellerstrass (supplier in Utah for Sunoco race fuel). I asked why Utah doesn't sell 93 octane. He said because of altitude. In Reality, Utah shouldn't even have 91 Octane. I said I highly disagree, what is the reasoning for this?
He then said that for every 1,000 ft in elevation, you gain 1 octane point. You don't have as much oxygen and therefore have less of a need for higher octane that requires a longer burn for the added atmosphere. He then went on to say that if they were to bring the blend of east coast 93 octane to Utah, it would end up being similar to a 97 octane. Vice versa, our 91 at sea level is like there 87 octane.
Welcome to the land of poop gas and no air It is no wonder East Coasters can make so much more power...
Stames_wiltz is offline   Reply With Quote
Old 01-11-2010, 05:59 PM   #12
szeny
Member#: 81383
07 335i e90
TiAG/Dakota Black
screw e85.. just get meth...or start buying race gas and mixing
szeny is offline   Reply With Quote
Old 01-11-2010, 06:22 PM   #13
ktmrider
Member#: 125687
Worded much better than I could have done.
Less Oxygen content per volume of "air". The A in A/F should not really be air, should be Oxygen.
At least we call the sensor monitoring the spend gases Oxygen....
Old 01-12-2010, 01:41 PM   #14
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Lol, yup that was me!!! Lol. I was heading to my gfs (fiance now) house. Thanks I appreciate it!! What were you driving?
Old 01-12-2010, 03:21 PM   #15
michael_cano
Member#: 227643
2008 Stock as Hell
:( STi
2005 wrx limited w/blitz nur spec u can hear from like el paso!! lol.
Old 01-13-2010, 12:32 PM   #16
fistandauntilus
Member#: 145533
2004 STi
no place in the region carries anything above 91. if you are worried about DET best thing would be to get a retune for 91.
fistandauntilus is offline   Reply With Quote
Old 01-13-2010, 06:08 PM   #17
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Lol im surprised I didnt notice you?!
Old 01-18-2010, 01:02 PM   #18
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
E85 is cheap and available in Las Cruces. You'll need bigger injectors than pinks to support a vf on E85 though. I've seen too many motors with meth kits fail. Even with a failsafe, you can lose a motor if the system fails. It's just not worth it in my opinion.
06rexwagon is offline   Reply With Quote
Old 01-18-2010, 10:02 PM   #19
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
How much is an E85 kit, and what all is included? (link?)
Old 01-19-2010, 12:11 PM   #20
06rexwagon
Member#: 114730
[email protected]
There's not really a 'kit' for them. You just need injectors large enough to support your setup on E85. That usually means about 30% bigger than what you need on pump gas. You'll need a walbro for injectors up to ~1000cc and dual pumps beyond that. I run 1100cc injectors with a walbro in tank and bosch 044 inline. Plumbing is all -6 AN lines using the stock return. You'll have to get a custom tune for E85.
EDIT:
Here's a link to an 08 STi like yours that I tuned first on pump gas then later on E85.
http://camtuning.com/forums/viewtopic.php?f=20&t=1184
There are a bunch of other cars in there on e85 if you want to see charts for stock turbo sti's, 2 liter wrx's with VF turbos on E85, etc.
Old 01-20-2010, 05:00 PM   #21
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Hmmm...If I were to do this would I still be able to run 91?...and possibly lower octane like 88, 89??
EDIT:
Old 01-20-2010, 09:00 PM   #22
06rexwagon
Member#: 114730
[email protected]
no, unless you're able to reflash the ecu. You'll have to run a different tune for gasoline. If you have an AP or tactrix cable you can switch maps if needed.
Old 01-21-2010, 12:05 PM   #23
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Hmmm, ok. I may consider doing this. The only thing that scares me is going on a road trip to, say, Phoenix/Tucson (which I make every now and then)...or to Denver...ect, and not finding E85. Other than that in Las Cruces its available pretty easily. I guess I'll have to do more research as to how available it is Thanks!!!
Old 01-21-2010, 02:56 PM   #24
sje323
Member#: 194509
World Rally Blue
just invest in a tactrix cable like he said. you can then have the different octane maps on your laptop and flash them to your ecu when you need/want to.
sje323 is offline   Reply With Quote
Old 01-22-2010, 11:17 AM   #25
06rexwagon
Member#: 114730
[email protected]
Get a cable. You'll be able to switch back and forth easily. You have to drive easy on the 1st tank going from E85 to gas or gas to E85 because the maps are so different and your fuel will be a mixture of the two. Other than that, I say go for it. I come to Cruces occasionally (I'm from there) and can tune your car there. If you want to do the tune on a dyno you can come up to Albuquerque and I'll get you set up.
Apparently, cars in New Mexico have more sexy than cars in regular Mexico. markman Off-Topic 7 08-18-2009 08:26 AM
Octane in New Mexico Turbo4me South West Impreza Club Forum -- SWIC 22 09-12-2002 06:35 PM
SCCA Rallycross in New Mexico Sergeant_V South West Impreza Club Forum -- SWIC 7 12-30-2001 08:42 AM
WRX's in New Mexico... system_s4000 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-01-2001 02:38 PM
