Old 01-07-2010, 06:38 PM   #1
Yulri
Member#: 162299
2007 Impreza WRX OBP
93 Impreza L, 91 Legacy L
Default Some questions on a 1.8 to 2.2 swap
Hey guys I have a 93 impreza l with a fwd 5 spd and i'm about to pick up a 91 legacy l with the 2.2 and a fwd 5 spd. I've seen some short references to how easy the swap is but is there anything I should look out for? So far I've gathered that the trannys are the same and I should have no issues putting the legacys tranny into the impreza and that the 2.2 is essentially the same engine with larger bore so it mounts the same. I also heard that you can use the 1.8's ecu but I presume you use the 2.2's wiring with the 1.8 sensors.
My question on top of verifying the above is, do they use the same exhaust? can i keep the 1.8's ac condensor? what about the radiator keep the 1.8 or swap the 2.2?
Any other things I should note before I start will be greatly appreciated as well.
On a complete side note, Can you bolt in the 02-03 wrx rear brakes if you have the entire brake assembly and hub? Would you need the parking brake assembly as well if you have the rear drum and no abs? Would the fact that the wrx had abs complicate anything? Also would you need a larger brake master cylinder?
thanks ALOT for any help
Yulri is offline   Reply With Quote
Old 01-11-2010, 08:16 PM   #2
Yulri
Member#: 162299
nothing? where are all the 2.2 swapped guys?
Old 02-07-2010, 03:31 AM   #3
Yulri
Member#: 162299
finished the swap. Wasnt exactly as easy as I thought but at least now I can answer my own question for the most part. Not the most powerful car but its still quite a bit of fun and better than the 1.8.
You can use the 1.8 computer
you can use the 2.2 transmission but youre going to need the half shafts from the 2.2
The EGR was blocked off and I have no check engine
I think we swapped intake manifolds i honestly cant remember right now.
We also had to swap our throttles because of the positioning of it.
Next we're going to see how difficult it is to swap a 1.8 into a legacy that had a 2.2. Hate to see a good engine goto waste
Old 11-01-2013, 03:05 AM   #4
Subanoobe
Member#: 370930
93 impreza
blueish
I have a 93 awd 1.8 impreza and I wanna swap to a 2.2 does it have to be off a awd 2.2 and how much more power did you get because this ej18 is sooo slow
Subanoobe is offline   Reply With Quote
Old 11-17-2013, 05:56 PM   #5
dragonart777
Member#: 373859
same here i have a 1.8 i wont to swap with a 2.5 but i have no ideal if i need a ecu swap and transmission swap im hoping i can swap to a 2.5... at the moment my 1.8 is taken out on engine stand blown head gaskets .vavle spring vavles done clutch plate done
dragonart777 is offline   Reply With Quote
Old 11-18-2013, 08:23 PM   #6
drewmilk1
Member#: 373983
I believe you can use the same trans but I'm not sure if you will have any issues with your sensors or if everything will just plug and play
drewmilk1 is offline   Reply With Quote
1.8 to a 2.2 swap? notasubyguy Normally Aspirated Powertrain 26 01-31-2009 11:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
Timing and detonation on a 1.8 to 2.5 swap.... EcksJay Subaru Conversions 18 09-25-2005 09:21 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
