Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-07-2010, 10:15 PM   #1
kinder
Member#: 222761
2007 SpecB
Grey
Default Dual AVCS conversion even possible?
Is this a mod that can even be done? I know our engines are very modular but still. Had a guy here tell me that was his next mod. 09 STI AVCS system to 06 STI.
kinder is offline   Reply With Quote
Old 01-07-2010, 10:24 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Sure- just swap the heads and install the electronics to control the AVCS.
speedyHAM is offline   Reply With Quote
Old 01-07-2010, 11:33 PM   #3
howfast?
Member#: 102027
BugI Tsx retro lamps
for sale not listed pm me
^lol make it sound so easy... heads, motor harness, and ecu at least what else
howfast? is offline   Reply With Quote
Old 01-07-2010, 11:48 PM   #4
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You can use an aftermarket controller for the cams.
It is easy compared to a STI swap into a 2000 2.5RS. It's cake compared to the EG33 powered Datsun 240Z that someone here is working on.
Old 01-08-2010, 06:52 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
I wouldn't call it easy at all. 09 sti is a can bus ecu. To use that wiring harness will have you pulling your hair out.
Old 01-09-2010, 09:47 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
stock ecu is never gonna work
think link or hydra
Old 02-24-2012, 10:17 PM   #7
OneManArmy
Member#: 36154
2004 WRX Wagon
Has anyone completed a swap with one of these.
I'd like to get a 2010 long block in to my 2004 wrx.
OneManArmy is offline   Reply With Quote
Old 02-24-2012, 10:57 PM   #8
Ballistic1350
Member#: 156877
04 sti
I asked this very same question a while back and got a bunch of silly responses. Hopefully you can get someone to answer the question...
Ballistic1350 is offline   Reply With Quote
Old 02-25-2012, 02:51 AM   #9
cpturbo
Member#: 49175
2004 STI
I did it to a friend's car. Wasn't easy but it got done. His car was a 2004 wrx, so I wired in everything. I mean everything. Used a Hydra 2.7 and done.
Good luck, you should make him sell it to you.
cpturbo is offline   Reply With Quote
Old 02-25-2012, 08:06 AM   #10
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
think link or hydra
I see that there's an agreement about this, just curios why?
Old 10-20-2012, 04:25 AM   #11
Monkey king
Member#: 209401
2005 Sti
Well I guess this answered my question about trying to convert an 05 sti to a dual AVCS system. Sounds like more trouble then it's worth.
Monkey king is offline   Reply With Quote
Old 10-21-2012, 04:40 PM   #12
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
The factory GD STI ECU can't/won't run the second bank of AVCS and the effort to swap an GR STI ECU is prohibitively difficult (if even possible at all). A standalone designed for the GD but with extra outputs for variable cam systems is the only realistic way to make it happen.
lancelucas is offline   Reply With Quote
Old 10-22-2012, 08:38 PM   #13
fullCircling
Member#: 290547
so im planning on running dual avcs in a 97 legacy. if i get a GR STI ECU and full harness can i get it to properly run the dual avcs? can a competent tuner disable the other features (mainly vdc)
fullCircling is offline   Reply With Quote
Old 10-22-2012, 09:52 PM   #14
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
The GR ECU uses CAN BUS. If it doesn't see the other items on the BUS it will throw DTC's. I am unsure if just deleting these codes will keep the ECU happy. If you swapped the whole electrical system (harness and all modules) it should work fine.
jake
KONKILR is offline   Reply With Quote
Old 10-22-2012, 09:53 PM   #15
69subaru360
Member#: 159682
1995 WRX
2015 F150
No. GR is a can bus ecu. You need just about everything from the GR body loop for it to run. It's virtually impossible. ABS, HVAC, all the body controls, it's all integrated.
Buy a standalone.
Old 10-22-2012, 11:04 PM   #16
WhatTurboLag?
Member#: 243992
2006 WRX TR
Not worth it. Hell I want to delete avcs. Simpler is better.
WhatTurboLag? is online now   Reply With Quote
Old 10-23-2012, 01:45 AM   #17
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Buy a standalone.
I do not envision it to be feasible either.
Unless you swap in every module and basically make the car a complete GR STI with a different shell. Not worth it.
EJ257 USDM STI Dual AVCS long block Dugansti Engine/Power/Exhaust 7 03-30-2009 12:59 PM
2006 290HP EJ20 Dual AVCS - Mini autopsy :) Gruppe-S Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 33 08-30-2007 02:30 AM
DUAL AVCS 2.0 wiring??? saab-on-the-cobb Subaru Conversions 4 04-25-2007 11:45 AM
