Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 01-07-2010, 11:30 PM   #1
Shady97342
Member#: 184915
2004 Stage 2 WRX
Default 2.0L 2004 WRX on TD04 Dyno
Ambient Temp: 55F
Elevation: 52ft ASL
Car: 2004 WRX
Dyno Info: Dynojet
Peak HP: 233
Peak Torque: 221
Fuel: 93 oct
Engine/Power Modifications: Open Source Tune, TBE, Up-Pipe, Turbo Inlet, GM BCS, Cobb Short Ram, Modded stock injectors
Driveline Modifications: Nada
Drives sooooo much better than stock, lets see how long it takes till i want more
Shady97342 is offline   Reply With Quote
Old 01-08-2010, 01:06 AM   #2
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
give it a month. then the power bug will bite harder.
mongoosaroo is offline   Reply With Quote
Old 01-08-2010, 04:19 AM   #3
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
hahaha, how about a week.
ramair18954 is offline   Reply With Quote
Old 01-08-2010, 10:06 AM   #4
RedRex26
Member#: 133418
2006 DOM3 XTR WRX TR
SRR 407whp 365wtq ppg'd
wow those are awsome numbers for only 16 psi tdo4 and on a 2.0 liter.
RedRex26 is online now   Reply With Quote
Old 01-08-2010, 10:31 AM   #5
scprs
Member#: 172359
2005 STi
yea the thing is you have a lot more room for improvement but it takes A lot of work and money. I have yet to post my build and such but i made 283/335 on a dead bolt td04 on 21. And man o man is it fun.
Good numbers though for a small number of mods
scprs is offline   Reply With Quote
Old 01-08-2010, 06:41 PM   #6
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Nice mods , looks like you went for the conservative tune. When you are ready for more im sure your tuner can give you a more aggressive map pushing the turbo a bit more.
vik_wrx is offline   Reply With Quote
Old 01-09-2010, 12:12 AM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
dynojet reads higher than dynodynamics right? what do stock wrx and sti put down on that dyno?
Nice numbers though. Most stage 2 wrxs put down about 215-225 on dyno dynamics from what i've seen. my accessecu stage 2 put down 207hp and only like 185lbs of torque so your car is very healthy, enjoy!!
scoobystas is offline   Reply With Quote
Old 01-09-2010, 01:04 AM   #8
Shady97342
Member#: 184915
2004 Stage 2 WRX
This is the only base I can find for this dyno, its a stock 08 sti
Old 01-10-2010, 12:33 PM   #9
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
wow is that a stock sti tune? what is with the scarry lean condition that happens around 3300rpm?
anyways, it seems at 215hp, that is a pretty low reading dyno and thus your putting down some serious power with only 16lbs of boost! I guarantee you can turn it up to atleast 19 in the mid range and taper to 13ish or whatever the turbo can do at the top end.
Old 01-10-2010, 04:24 PM   #10
Shady97342
Member#: 184915
2004 Stage 2 WRX
That baseline graph wasn't after a tune, thats just what a bone stock 08 STi puts down on that dyno.
Old 01-10-2010, 05:28 PM   #11
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Thats only ran to 5700 rpm. The stock tune is pure crap, but the powerband linear. If it was pulled to 7k he would have hit the typical 235whp for a stock STi.
Damn, I thought the stock tune was set for 14.0 @ peak torque, then fall to 11.5-12.0. Looks like it wants to hold 14. And people still ask why these cars tend to go BOOM in stock trim
STi Mikey is offline   Reply With Quote
Old 01-10-2010, 06:09 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Something's wrong with the AFR scale, it's bouncing around in the 16-17 range under 3.3k? There's no way that's real.
Concillian is offline   Reply With Quote
Old 01-11-2010, 09:49 AM   #13
Bullwinkle1983
Member#: 172332
2006 WRX
While it does look like the AFR scale calibration is somewhat off, that behavior is normal for a stock Subaru. Google/search "open loop closed loop delay."
Bullwinkle1983 is offline   Reply With Quote
Best Street Turbo for a 2.0L 4EAT WRX? JohnnyWas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 07-12-2006 01:50 AM
2004 WRX w/ axleback dyno sheet QwikRex Proven Power Bragging 14 05-11-2006 02:44 AM
2.5L crawford shortblock on 2.0L 2004 WRX heads mistaboosta Built Motor Discussion 11 04-05-2006 06:27 PM
Fastest 2.0L drag WRX? Mach5WRX Proven Power Bragging 9 09-02-2002 01:06 AM
2.0L 280HP WRX Promax General Forum Archive 24 05-19-2000 12:56 AM
