Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-08-2010, 09:23 AM   #1
BajaGermany
Member#: 156902
2003 Baja Sport GLP
yellow
Default Serious engine failure and following problems
Hi together,
some days ago, my Baja starts to have a loud knocking noise from the engine, also to feel on th clutch-pedal, occuring while accelerating. I took it to my subaru-shop and they found some metal-chippings in the oil and for sure there are one ore more bearings broken, probably crankshaft, as ist is feelable through the clutch...
So i hooked up a new shortblock and oilpump and let it be swapped. After starting the engine, the camshaft-sensor failed too, and has been replaced meanwhile.
But there is still a problem: engine starts fine and also is fine while cold. But when temperature reaches about 70į Celsius, it starts to idle bad, CO reaches 10 % and cylinder 1,2 and 4 are much to fat. Nobody in the shop and at Subaru Germany has any idea what the prpblem could be!
Everything possible, esp. ignition-parts and IAT has been changed without result.
Any idea? Anyone?
Regards and thanks for answer,
Chris
Baja Sport 03 MT, 137 Kmiles
BajaGermany is offline   Reply With Quote
Old 01-10-2010, 12:04 AM   #2
frogmonk
Member#: 74489
'04 FXT/05 Baja Tur
'71-FF1/05 Saab-92X-Aero
Do you get a CEL indication?
frogmonk is offline   Reply With Quote
Old 01-11-2010, 12:08 AM   #3
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
A bad temp sensor could make it hard to start or run to rich when the motor is hot. Also maybe they have the injector plugs switched or the timing belt off ?
bobjr94 is offline   Reply With Quote
Old 01-11-2010, 06:11 AM   #4
BajaGermany
Member#: 156902
2003 Baja Sport GLP
yellow
Thanx for your answers,
I did get the CEL for the camshaftsensor and meanwhile crankshaft-sensor, too. Temp-sensor, belt and iginition was checked. Engine started fine and ran good until it gets temperature to warm idling...
And meanwhile the problem was found! There was some bad connection at one of the two engine-main-electrical-plugs! So I think, the rpm-Signal from the camshaft-sensor and/or crankshaft-sensor was interrupted or bad. After cleaning all connections two times, it works now!
Best regards
Chris
Tech Report: 2008 ECM Reflash and Engine Failures Crawford Tec Support Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 11-13-2013 12:26 AM
Help!Serious engine problem parkes Service & Maintenance 3 01-20-2008 03:15 PM
headgasket failure....whats the problem? commador Legacy Forum 10 05-14-2004 02:11 PM
Auto WRX, Engine management, and the following mods? eatwrx Engine Management & Tuning 3 04-07-2004 04:25 PM
Mits tranny and wing problems getting serious. dlowman Off-Topic 16 09-03-2003 12:03 PM
