#1 |
Member#: 192679
NWIC
Vehicle:2002 WRX Wagon Stage 2 |
Below is the LearningView of my '02 WRX as of a few days ago. Has improved after applying the Stage 2 map.
Also replaced the spark plugs a month ago (NKG plugs). Sept 2009 - Stock map Jan 2010 - After Stg2 map & new NKG plugs Only mod done is a full catless exhaust (up-pipe/down-pipe/3" catback). Still getting readings of low airflow. The filter is a couple years old, but not filthy. Also the stock ram-intake and snorkel was removed (Been removed for years). Any pointers of what may need adjusted or suggestions to a different map would be quite helpful. Thanks ROM used: A4SGE01C - MY02 OSECU Stage 2 r10.hex
#2 |
Member#: 222350
First thing is to get your MAF rescaled mate I think for both OL and CL.
#3 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
How sure are you that it's running lean? Wideband?
If so, post logs. The learning view looks fine, you can remove a little timing in the higher loads. Low load knocks are normal. Should not have to rescale the maf if still on the stock intake. |
#4 |
n00b Moderator
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
you might want to clean or replace air filter..
while you're there clean your maf sensor. |
