#1 |
Member#: 169955
SCIC
Vehicle:30R BUILT STI /AREA P no limits/ALLIANCE FABn |
I was thinking of building one & am wondering if anyone truely knows if its all the same stuff? From what Ive been told its 500 cheaper from the dealer, but ALL im using is the case & putting sti internals & forged pistons in the 2 block halves. I was told all the part #'s for parts inside were the same, but I really just need to be %100 sure
Im getting half people saying one thing & half saying the other
#2 |
Member#: 22825
NWIC
Wirelessly posted (Opera/9.80 (J2ME/MIDP; Opera Mini/4.2.14912/1280; U; en) Presto/2.2.0)
Short block sure. No advantages to the sti part # |
#3 |
Member#: 191514
NWIC
Vehicle:'05 FXT |
'08 forester xt has the same shortblock as the legacy gt, 2008+ wrx. Crank and rods have the same part numbers as an 04-07 sti but pistons are different.
Last edited by theotherguy; 01-09-2010 at 12:35 AM. Reason: clarify crank and rods |
#4 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
From the info available here on Nasioc, the only difference between the STi block and the other blocks are a small difference in dish volume in the pistons.
If you're replacing the pistons, there is going to be zero difference. |
#5 |
Member#: 169955
SCIC
^^ yes, the pistons are going to be replaced & I am not buying this new, just a deal on an old shortblock from an 08 forester. that spun a bearing
ANY1 have any other sti or same shortblock cores thats not in bad shape? like spun a bearing, even if its just the 2 block halves, please let me know, would rather not use or take/ buy anything thats in bad shape (like a cracked cyl wall) thats a little too much work I dont feel like doing (replacing the sleeve) thank you |
#6 |
Member#: 192526
Vehicle:2008 WRX FMIC/VF48 Red/Steel Grey |
So what does it mean when a "Specialist" has a fundemental question about short blocks? NASIOC must be giving away that designation like the swine flu!
#7 |
Member#: 5810
Vehicle:2001 S366 2.5RS |
^^ wait till a guru come in and asks a question
#8 |
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
An EJ255 block will not be $500 cheaper than an EJ257 block. Hell, there difference between an EJ205 and EJ257 is only $300. Expect prices to be the same or within ~$50.
Put whoever told you that in time out. |
#9 |
Member#: 169955
SCIC
bump!
#10 | |
Member#: 12281
Vehicle:08 FSXT Tiger's Blood |
![]() for the OP, 04-05 fxt shortblocks are ej257s same as the sti. |
#11 |
Member#: 5810
#12 |
Member#: 207826
#13 |
Member#: 5810
EJ255
DOHC turbocharged, with sodium-filled valves originally designed for North American market, now sees usage in some European Imprezas and Legacies destined for Australia and South Africa. Power 230-265 hp Usage in North America: Impreza: 2006 - present Forester: 2004 - present Legacy/Outback: 2005 - present Baja: 2004 - 2006 Usage in the rest of the world: Legacy/Outback: 2005 - present Impreza: 2006 - present /end |
#14 |
Member#: 5810
DOHC 16 valve turbo. Originally designed for the North American Impreza STI in 2004 with AVCS and DBW. Not the same exact shortblock as EJ255. The EJ255 has a different domed piston vs the EJ257. Subaru of America designates the same part numbers for an EJ255 shortblock, and EJ257 shortblock with the exception of the pistons.
Usage: US Market Impreza WRX STi MY04~MY07 (300 hp, 293 hp (New SAE standard)) US Market Impreza WRX STI MY08~MY10 (305 hp (New SAE standard)) Asian, European Market Impreza WRX STi 05~present (280 hp, 40KGh/m) JDM Forester STI MY05~present |
#15 |
Member#: 207826
Yet, they still have EJ257 shortblocks.
#16 | |
Member#: 199106
Vehicle:PMme 4 Speed Density Patches on OEM ECU |
http://forums.nasioc.com/forums/show....php?t=1667168
This really ought to be a sticky. Quote:
#17 |
Member#: 155466
NWIC
Vehicle:2008 Stg III+ FSXT |
The 04/05 FXTs have the EJ257 block, but it's labeled "EJ255".
The 06+ FXTs have the same block as the 06+ WRX, the EJ255. http://www.subaruforester.org/vbulle...-06-fxt-42549/ http://forums.nasioc.com/forums/show....php?t=1667168 http://www.subaruforester.org/vbulle...a-forum-33387/ |
#18 |
Member#: 169955
SCIC
the block I currently have in my possesion is off an 08 forester sport, that is the fxt isnt it? 2.5L turbo obviously
still trying to figure out if there is any differences with me buiding this up, Ive heard if im replacing the pistons (w forged) then everything else is the same, its just the bare case I have, no internals what-so-ever EJ255? or exact same as sti? |
#19 |
Member#: 207826
Same.
Might want to change your sig/vehicle description. You're not making 500 whp. |
#20 |
Member#: 169955
SCIC
^^?? You might wanna ask b4 assuming. Its all good tho, not too hard to believe, the just about 400whp was on 91 oct alone 23psi
30r stock motor/clutch 11.2/127 1.60 60's made 484.7whp/496.6tq on 27psi c-16 , I can say 500whp cuz at one point while tuning it was up to 530whp before it was backed down for all the stock parts (motor/trans/clutch) clutch never slipped once Last edited by KB'izzle; 01-26-2010 at 11:58 AM. |
#21 |
Member#: 169955
SCIC
| Thread Tools | |
| Display Modes | |
| Will 08 STi injectors work same as STi pinks for Cobb VF39 map? | lotarg | AccessPort | 2 | 01-06-2010 05:12 PM |
| Is an 08 wrx clutch the same as 06-07 wrx? | Scoobs2002 | Transmission (AT/MT) & Driveline | 1 | 10-29-2008 02:43 PM |
| Is the turbo on a 05 legacy Gt the same as STI? | Texy32 | Newbies & FAQs | 7 | 09-12-2006 03:19 PM |
| Is a wrx fuel pump the same as an STI | quickscooby | Impreza Forum | 3 | 01-31-2006 08:29 AM |
| So is a MY98 rs fpr the same as an SVX fpr? | GregBolby | Normally Aspirated with bolt-on Forced Induction Powertrain | 18 | 09-30-2004 08:50 PM |
