Old 01-08-2010, 08:07 PM   #1
drifte
Member#: 209749
06 STI
Aspen white
Question 04 fxt idle/acceleration, also cruise
New to Subarus here but I've been in the DSM game for a good 10 years. Heres a few questions I have for my recently acquired forester.
1. Idle, stumbles a bit (i know its a boxer)
2. acceleration is jumpy as if its having trouble getting into boost (tune issue?)
3. Today my cruise light started flashing and cruise no longer worked...wtf?
Now I have already read about idle issues with those filters in the banjo bolts, went to remove them and someone already had. The SPT intake didnt change anything I went back and forth from stock to it and no changes. I have also read the 04's have an issue going from open loop to close loop, so am I to assume when getting into boost its struggling because of the factory tune? Is their any factory re-maps I could just go to the dealer and get a quick flash/update?
Only thing I have to to replace is the spark plugs, and Im just still researching to see what way is best to go and get a part #. It also doesnt look fun to replace them.
Any help is appreciated.
Thanks,
Colton
drifte is offline   Reply With Quote
Old 01-08-2010, 09:17 PM   #2
antigfk
Member#: 122242
2006 WRX LTD
Read the FAQ's, and go get a tune of some kind. Just a off the shelf Cobb tune made my car run 10 times smoother. A protune made it even better.
Not sure about your cruise control issue.
antigfk is offline   Reply With Quote
Old 01-08-2010, 10:49 PM   #3
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Did your check engine light come on with the flashing cruise? Sounds like you threw a code, which might explain a lot of your other issues.
theotherguy is offline   Reply With Quote
Old 01-09-2010, 12:26 AM   #4
drifte
Member#: 209749
06 STI
Aspen white
No codes or CEL and only code found in the history was for abs relay. I read the faq's but I dont want to spend much money on getting a baseline tune when the car is basically stock. A friend of mine has the Cobb tuning device, but it seems it just pre determines what it thinks is the best map you can't actually adjust it, but it costs something like $500?
I'll continue reading and see what I can find. I may go ahead and get another AEM UEGO for this car and then I can atleast see whats going on.
I am getting more interested in the tactrix cable and maybe running ecuflash.
thanks
Colton
Old 01-09-2010, 01:16 AM   #5
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Did the cruise light go out after you turned the car off and restarted it?
Cruise control indicator light
The cruise control indicator light illuminates when the ignition switch is turned to the “ON” position and turns off after approximately 3 seconds. This light illuminates when the “CRUISE” main switch is pressed.
If you press the main switch button while turning the ignition switch “ON”, the cruise control function is deactivated and the “CRUISE” indicator light flashes. To reactivate the cruise control function, turn the ignition switch back to the “Acc” or “LOCK” position, and then turn it again to the “ON” position.
If it did go out after restart then you may have deactivated the cruise and reactivated it. If not, its going to to be tough to narrow it down with no codes.
Old 01-09-2010, 04:02 PM   #6
drifte
Member#: 209749
06 STI
Aspen white
Thats weird I'll give the full story from using cruise to cruise flashing.
Cruise set at 70mph I touched the brakes preparing for an off ramp cruise stops. I accelerate around the clover leaf on ramp (snowy, icy FUN) i spin through 3rd and hold it steady and shift to 4th, then 5th. About when I shifted to 4th I noticed a flash, looked back down and cruise was flashing. When I came to my next off ramp roughly 3 miles down i shut the car off and turned it back on and cruise light quit flashing. Haven't tested since to see if it works.
on another note, Utec seems like a great option but even at my cost it sure isn't cheap.
Old 01-09-2010, 04:55 PM   #7
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Sounds like it reset itself.
I run ecuflash via a tactrix cable on my Forester and WRX. If you can borrow one, it is extremely inexpensive to get a good tune from one of the many e-tuners out there. An e-tune is a custom tune for your car by sending logs from romraider thru email. I've used a tuner from SoCal and had great service.
Old 01-13-2010, 11:57 PM   #8
drifte
Member#: 209749
06 STI
Aspen white
This will sound strange and although myself, my boss and my friends shop are all capable of a tune; how do you determine who will tune for you online? Is their a list of qualified tuners somewhere?...
04 STI doorcards & also 04 WRX doorcards KB'izzle SCIC Private Classifieds 3 08-25-2009 02:26 PM
Need help...rough idle...acceleration stumbling..... zzzzzzzz Legacy Forum 39 08-19-2007 11:36 AM
idle/acceleration problem rotarypower8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-12-2005 01:33 AM
Google Web Accelerator also an anonymizer? RR Off-Topic 17 05-06-2005 02:23 PM
Irratic FXT idle wadejg Forester Forum 8 03-17-2004 11:23 AM
