Old 01-08-2010, 11:08 PM   #1
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Default Headlights come on late and flicker
Within the last 2 weeks I've noticed that my headlights haven't been working as they should. When it's below about 20F outside, the low beams won't come on for a while so I will basically be driving with running lights at night. After a few miles or about 5 minutes, they will just come on by themselves; just as the car gets to operating temps. I try to turn them on and off but nothing happens until they decide to come on by themselves. When they finally do come on, they flicker a little bit for a minute then work fine. What could this be? The car is still under warranty so I'll probably take it in on Monday to have the dealership check it out.
iyzmi is offline   Reply With Quote
Old 01-08-2010, 11:14 PM   #2
changd123
Member#: 233794
'15 STI
Crystal White
yeah.. u should take that to the dealer.. do any mods to her lighting system? HID kit or what not?
changd123 is offline   Reply With Quote
Old 01-08-2010, 11:18 PM   #3
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Not really. The only things that I did were paint the plastic parts inside the headlights like this:
http://forums.nasioc.com/forums/showthread.php?t=957478
and a DRL delete so the driving lights only come on when I put the switch in the driving light position. Both of those mods were done a while ago and have not caused any problems yet. I think it's something cold weather related but I'm really not sure...
Old 01-08-2010, 11:28 PM   #4
changd123
Member#: 233794
'15 STI
Crystal White
it sounds like a loose connection to me..(you might have already tried this..) try checking to see if you installed the bulbs properly after the "blacked out housing" project.. hopefully there will be someone else who can answer your problem better..
good luck~
Old 01-08-2010, 11:48 PM   #5
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
I think that if they weren't installed correctly, I would have noticed within the last >1yr that the project has been done. Could it maybe be that the seal isn't perfect and some moisture is getting inside or would that not be able to cause this problem?
Boost coming on late, found bad upppipe gasket roybfr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-26-2006 12:11 AM
Boost coming on late? Mzacharski Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-13-2005 08:28 PM
FedEx Ship Manager, come on in and help. Fish Off-Topic 2 12-27-2004 07:20 PM
Headlights coming on and off intermittently snow111 Electrical & Lighting 6 12-14-2004 01:38 AM
What's wrong? Boost coming on late. wrxlvr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-18-2003 01:57 PM
