Old 01-09-2010, 01:37 AM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default Moving o2 sensor into the header...
Anyone done this? I know it will fit and I can wire it in. However, does moving the o2 sensor forward upset the ECU? The o2 sensor in the rotated downpipe interferes with my WAIC core. Moving it is my only option to one of two places--1.) REALLY far down the downpipe which I know is bad. 2.) pre up-pipe with an 04+ exhaust manifold...which I've never done but I think would work.
Thoughts? I want to use one of these manifolds to relocate it.
HamFist is offline   Reply With Quote
Old 01-09-2010, 02:51 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
The pre-turbo one will be fine since it is a stock WRX location. The only O2 sensor you don't want too close to the engine or pre-turbo is a wideband O2.
PhilSine is offline   Reply With Quote
Old 01-09-2010, 12:32 PM   #3
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Cool. Thanks.
What kind of O2 sensor is in the WRX manifold, though? Putting a narrow-band there from the factory makes less sense. Does the heat kill widebands?
Which Impreza's have O2 sensors on the header? rougeben83 Normally Aspirated Powertrain 3 04-26-2008 06:06 PM
Finally moved O2 sensor to prevent cel BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-04-2003 09:58 PM
Moving O2 sensor in 3rd cat pipe Robimplicit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 02:49 PM
Will moving O2 sensor downstream of 3rd cat prevent cel? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-27-2002 11:45 PM
Moving O2 sensor downstream of 3rd cat? BIGSKYWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-22-2002 09:05 PM
