Old 01-09-2010, 02:28 AM   #1
Soulofdarkness
Member#: 83637
02 WRX PSM
And "Infamous Car #2"
Default What is this thing? And why is it infront of a bolt I need to get to?
Tube circled in red.
It is on an 02 WRX engine, its blocking the 4th bolt to get the A/C compressor off.
I'm trying to pull my engine to do some work on it and I can't get to the 4th bolt to the A/C compressor because of it... Anyone know what its for, and why it is just caped off?
Thanks!
Soulofdarkness is offline   Reply With Quote
Old 01-09-2010, 07:11 AM   #2
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I remember reading in the factory repair manual to not mess with that. You can of course remove it, along with other things and then reinstall it. If I was to make a guess, maybe this is a port used on the assembly line at the factory.
I also think that the engines are bench-started on a special rig, at the factory. At that time, they make "special" connections.
Old 01-09-2010, 10:54 AM   #3
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
its a coolant line. dont know why its there.
scby rex is offline   Reply With Quote
Old 01-09-2010, 11:43 AM   #4
andrew3776
Member#: 172133
2003 vfdirty wrx
rotten banana
Continuum transfunctioner FTW
andrew3776 is offline   Reply With Quote
Old 01-10-2010, 01:01 AM   #5
S&S_IS
Member#: 152871
poke it and call it mean names in a stern voice..
just bend it ' a bit' to get it out of the way, 15 deg is all it takes to gain access with a 1/4 drive socket or ratchet wrench..
S&S_IS is offline   Reply With Quote
What is this for and why is it disconnected? ('05 STi) WRBPHXSTI Electrical & Lighting 5 04-19-2009 10:44 PM
what is this part and why is it broken?! Lordhowe Brakes, Steering & Suspension 23 01-20-2009 12:51 PM
What is this sensor.. and WHY is it not on my car after install n tune. Ray_STi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 03-29-2007 08:49 AM
whats with this Intel Centrino thing and why is it so expensive? GooseMan Off-Topic 12 11-21-2003 03:27 PM
What is this connector, and why is it unplugged?? Kwyjibo Electrical & Lighting 7 09-24-2003 01:21 AM
